Wjidaho's expedition build - Page 3 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Wjidaho's expedition build
Ruffstuff Axle Simple Swap Kit!TJ BDS 2" suspension lift!! FINALLY a GREAT 2" lNitro Gear Packages Now Available at Rockridge 4wd
Unread 02-20-2014, 10:08 PM   #31
ZERO30
Nice work with the clips! Resourceful. Dope dude.
[URL="http://vimeo.com/85134563"]New Exiled Offroad Video[/URL]
[URL="www.facebook.com/exiledoffroad"][COLOR="Blue"]Exiled Offroad on FACEBOOK[/URL][/COLOR]
[URL="www.instagram.com/exiledoffroad"]Exiled Offroad on INSTAGRAM[/URL]
[URL="http://www.jeepforum.com/forum/f22/zer030-rubicon-jk-build-1824306/"][COLOR="red"]ZER030 JK RUBICON BUILD THREAD[/URL][/COLOR]
[URL="http://www.exiledoffroad.com"]EXILED OFFROAD[/URL]
ZERO30 is offline   Reply With Quote Quick reply to this message
Unread 02-23-2014, 12:35 AM   #32
wjidaho
Yeah I really liked it, yes as in past tense, went after a fellow exile member tonight who had a broke axel shaft, and I forgot to take it off and lost it some place out in No Cajones lol. What can I say easy come easy go haha... Btw if anyone sees my plate please call me lol ;-)
[SIZE="4"][url=http://www.exiledoffroad.com]EXILED OFFROAD[/url][/SIZE]
My build thread
[url]http://www.jeepforum.com/forum/f22/wjidahos-expedition-build-1904282/[/url]
wjidaho is offline   Reply With Quote Quick reply to this message
Unread 03-16-2014, 05:00 PM   #33
wjidaho
Well I did a little maintenance on the old Wj today changed oil, cleaned air filter and gave it a recharge, greased the front end, topped all the fluids :-)
Also changed my gps mount to a better spot just hope it's not to bright at night
My build thread
Unread 04-03-2014, 12:14 AM   #34
wjidaho
So over the last few weeks I added more new parts and I still need to do more work before camping this summer. First on my list is axle bearings and seals in the rear, and I have seen the need to make some kind of a skid plate for the front, not really sure what I can do yet but I have to do something. Really want to build a tire carrier but that is getting moved back :-( I really wish I could get a loan to build the heep.
Heck just wish their was more aftermarket support for the Wjs, everything I have to do, is always custom or simi-custom, I lucked out on the winch mount but trying to find a carrier under $1100 is impossible, and everyone wonders why I want to buy a Yj for a toy. With the money I will have into this I could have built a bad azz Yj, oh well I do love the way she rides down the road, and besides rocks it will go were I want to, even places I should have never gone :-)
My build thread
Unread 04-19-2014, 10:42 PM   #35
gorillamel
To answer your question about my shelving, I got it from a friend who drives an FJ.
Here is another pic of it with my stuff on it:
The back of an Xterra has mounting points with slide-able hooks in the tracks on the floor. The shelving unit had mounting bracket loops attached to it at each corner. I simply used (white) paracord (you can see it on the left side of the photo) and tied the shelf to the floor to make it stable since it kept getting jostled around when I went wheeling. It had to be cut to fit inside the wheel wells. It was not a perfect fit since it was made for an FJ, so I simply put my "squishier" survival items on either side of it between the sides of the X and the end of the shelf.
I hope that helps.
Mongol Rally summer 2015: http://mongolianpandaexpress.org/index.html
gorillamel is offline   Reply With Quote Quick reply to this message
Unread 04-23-2014, 11:31 PM   #36
wjidaho
Got her back from the shop today... Had pinion bearings replaced.. So now my Dana 35 is pretty much new. They messed up the axle bearings I had just done, so they ended up replacing then again for no charge. Wyanes transmission off of cole is a really good shop. Wayne took real good care of me:-D
My build thread
Unread 07-08-2014, 12:49 AM   #37
wjidaho
Wow it's been a bit since I updated this lol,,,, I had death wobble pretty bad could not hit any bumps over 35,,, so I replaced my tie rod ends,, been doing a lot of exploring/wheeling. With that I have been getting good use out of my winch, boy I would say that's been one of my best mods, saved my but a couple times. Found a power steering leak, need to replace the hose I think. Added some stickers :-)
And some wheeling pics :-)
My build thread
Unread 07-24-2014, 12:15 AM   #38
wjidaho
Been having some problems with my electrical I have replaced that fricking $60 flasher/relay, and now when my headlights are on the driver side turn single stays on solid and driver side tail/brake light quits, but when the headlights are off my brake light stays,, and now it buzzs every now and then sounds like it's under my dash, I have checked my tail lights and head lights and what wires I could find, nothing, now I have been told it might be my turn single switch. Anyone have another idea hand singles are getting real old and it makes me not want to drive it
My build thread
Unread 07-28-2014, 07:50 AM   #39
4x4Jeep
in this situation i personally would just take it to a shop so they could figure it out.
Build - http://www.jeepforum.com/forum/f197/4x4jeeps-build-thread-1341031
4x4Jeep is offline   Reply With Quote Quick reply to this message
Unread 07-28-2014, 06:55 PM   #40
wjidaho
I am thinking about trading it off for a orange 2011 4door rubi, just drove it but I still have to get it going right again, with that said I got one more part on the way that I will try, if that don't work then off to the shop
My build thread
Unread 08-04-2014, 08:26 PM   #41
wjidaho
Well the part I was waiting for did not work, but I did get my power steering fixed new pressure hose :-) ,, no more leaks :-D
Also found that the "clunk" was my sway bar. I discoed to do some wheeling forgot to put it back on for the drive home no noise, so I say who needs a sway bar anyway lol. Still got to get my blinkers fixed, I am planning on taking it to the shop as soon as I got the money
My build thread
Unread 08-24-2014, 12:34 PM   #42
wjidaho
I went wheeling with the club good day
Lost a coil spring lol good times good times, did a easy trail fix with a high lift
I got to fab up retainers 3" exhaust tube here I come ;-) lol
All in all a great day wheeling with a great group of people
My build thread
Unread 08-27-2014, 08:18 PM   #43
wjidaho
So I am looking at a new lift for my Wj, I think I got it down to two different lifts 1) IROs 3" kit that's $750 and then I can fit almost 32s with trimming and then that's all 32s will be the biggest I will fit. 2) IROs 6.5 critical path long arms that's $1,840 and out of the box fit 33s and after building axles for it on to 35s. The biggest issue I can see is with the long arms I am positive I will see problems down the road, DW and all the stuff, the added expense of building axles I can figure $2,000 or more depends on what I end up going with. I don't know what would be best, all I know is no matter what I am going to spend a ton of money
My build thread
Unread 08-28-2014, 03:58 PM   #44
brouwmat
brouwmat's Avatar
I think both IRO and RC make upgrade kits where you can use the springs and stuff that you have today and then just swap out the springs and shocks later when you decide to go higher. I have heard good things about both kits.
brouwmat is offline   Reply With Quote Quick reply to this message
Unread 08-28-2014, 04:37 PM   #45
wjidaho
If I change out my currant setup I will be going IROs, just herd so much better about IRO vs Rcs
My build thread
