WJ West Coast Style - Page 3 - JeepForum.com
post #31 of 148 Old 11-12-2012, 07:53 PM Thread Starter
WJDesertRacer
http://s962.beta.photobucket.com/use...35283893160522
Does this link work to show all the pictures. Browse between the library and jeep build album.
<a href=
WJ dual sport</a>
WJDesertRacer is offline
post #32 of 148 Old 11-12-2012, 09:29 PM
TheSiltSurfer
2012 WK
Awesome build so far, stoked to see how it turns out with the beams up front. Keep the fab coming
Infinite Patience Produces Immediate Results
TheSiltSurfer is offline
post #33 of 148 Old 11-15-2012, 07:08 PM
dino30
How do you subscribe to threads ????
dino30 is offline
post #34 of 148 Old 11-16-2012, 01:26 AM Thread Starter
WJDesertRacer
Its under thread tools. Thanks for the interest.
Update...
After playing with beam arcs and measuring travel in current formation I need to make a rear beam crossmember. Not a huge issue, I have cut the current one into needed shape, just time. Of course if I have a new shiny rear crossmember I cant have used steel front plate. haha so ill be making a duplicate front cross member as well. Hope to have those tacked in and radius arms finalized but end of weekend. Its going well but I have been ignoring the biggest issue...
Steering
Its hard enough to get good steering on ttb to try that on a different vehicle is more tricky. Which reminds me, is there any effect to running your pitman arm in 180 degrees opposite direction?
<a href=
WJ dual sport</a>
post #35 of 148 Old 11-16-2012, 05:13 PM
Climbit
can't see why there would be. you will probably have to file or grind off the key splines on the pitman arm.
Climbit is offline
post #36 of 148 Old 11-18-2012, 08:14 PM Thread Starter
WJDesertRacer
Spent the weekend making radius arm mounts and tying them together with a crossmember. I tacked the mounts to the table to align everything then squared the tube to the mounts so everything was square.
PB175693
I added second plates to the sides of the mounts for strenght. My crossmember is 2" .120 wall dom sleeved with 1-3/4 dom.
PB185698
Ill be making a bunch of updates over the next week. Hoping to get a lot done with the time off work for the hoilday.
<a href=
WJ dual sport</a>
post #37 of 148 Old 11-26-2012, 10:22 AM
Speed-Freek
Looks good! I just got back from OW testing out my suspension, finally have 12" coilovers with hyd. bumps at all 4 corners, now its time for spring and valving tuning. I only have 12 inches... haha. But I can only use about 10 in the rear due to driveshaft angle....still much better than stock.
Keep up the good work, I want a ride in that thing when you take it out!
ASE certified tech, and welder/fabricator for hire, PM me for any of your automotive needs!
Speed-Freek is offline
post #38 of 148 Old 11-26-2012, 10:23 PM Thread Starter
WJDesertRacer
Did a lot of work over the past for days
Ill post pics of the highlights. Look for more later. I have to use flicker instead of photobucket... Mac problems.
I cut a new beam crossmember, made radius arms, finished the radius arm crossmember, started frame plates and fabbed up a motor mount and trans mount. I also cut my fender wells and painted the rear bumper/tire carrier.
PB255728 by xtreamrider06, on Flickr
PB255720 by xtreamrider06, on Flickr
PB255715 by xtreamrider06, on Flickr
PB255718 by xtreamrider06, on Flickr
PB255712 by xtreamrider06, on Flickr
PB255725 by xtreamrider06, on Flickr
Speedfreak. Its a long process but I can see the end now which makes it nice. Im glad to hear your rig is working out. Ill be building this weekend and next weekend if you want to check it out or lend a hand.
<a href=
WJ dual sport</a>
post #39 of 148 Old 11-27-2012, 09:22 AM
AustinTexasXJ
1987 MJ Comanche
badass WJ build.
I wanna see where it goes.
Benjamin
ΜΟΛΩΝ ΛΑΒΕ!
AustinTexasXJ is offline
post #40 of 148 Old 11-28-2012, 09:37 AM
Speed-Freek
I would like to check it out, if I have time I will see if I can get by, can you PM me your addy and Phone# ? I will hit you up!
post #41 of 148 Old 12-03-2012, 09:21 PM Thread Starter
WJDesertRacer
Finished frame mounts and motor mounts this weekend. Started to finish weld the plates today and will finish this week. Hoping to start on engine cage and shock mounts this weekend
PC035735 by xtreamrider06, on Flickr
PC035752 by xtreamrider06, on Flickr
Some Weld Porn
PC035750 by xtreamrider06, on Flickr
<a href=
WJ dual sport</a>
post #42 of 148 Old 12-08-2012, 07:23 PM Thread Starter
WJDesertRacer
Been good couple days. Hope to finish engine cage tomorrow
<a href=
WJ dual sport</a>
post #43 of 148 Old 12-15-2012, 05:44 PM Thread Starter
WJDesertRacer
Got my coil overs yesterday. Mounted them and the bumps and strapped it today. Tomorrow I hope to tackle steering.
<a href=
WJ dual sport</a>
post #44 of 148 Old 12-28-2012, 07:14 AM Thread Starter
WJDesertRacer
Finished it up. I'll post a better picture when its light. So far it drives great through the neighborhood
<a href=
WJ dual sport</a>
post #45 of 148 Old 12-28-2012, 09:29 AM
mJUSTINm
Awesome. Can't wait to see this thing running out in the desert!
-Justin
mJUSTINm is offline
M151a2 TOW 4 month build up then taken coast to coast dc to san fran tmc 2009 convoy diamondjim Jeep Builds 3 01-12-2011 09:05 PM
My 06 TJ on a Coast Guard Budget... ff_emtdehaan Jeep Builds 4 12-29-2010 10:36 PM
West Coast wheeling vs East Coast wheeling outlawjosywales Jeep Picture Requests 31 08-14-2009 10:12 AM
coast guard ast123 Jeep Picture Requests 4 11-25-2008 07:26 AM
East Coast Snow Pics BBJeepXJ89 Jeep Builds 6 03-05-2003 07:49 AM
