White YJ Build - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > White YJ Build
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great valueOfficial Chassis Saver Rust Preventive Truck & Auto Un
Unread 04-15-2014, 07:17 PM   #1
Delawdude
Junior Member
White YJ Build
Well, purchased this in February and it's occupied just a wee bit of my time on the weekends. This is my first jeep and I know ZERO about body work or rust repair, pretty good with a wrench though. In hindsight, I probably should have looked for a jeep that was not FROM NEW YORK! But, it's been a fantastic learning opportunity. I can't give enough props to this website for the information that I have obtained to assist with many of the repairs, which I'll walk through shortly.
4.0L, Automatic, White, pretty much stock - PO indicated it had a 2" lift, but can't confirm. did I mention rust?
Delawdude is offline   Reply With Quote
Unread 04-15-2014, 07:17 PM   #2
Delawdude
Junior Member
So after I got it home I proceed to strip the interior ---- ah the things you find in used cars:
Then I looked under the hood and saw the washer fluid bottle, gotta say, the previous owner sure was resourceful - I mean, why throw away a perfectly good protein powder jug????? Hm, what to do, I think I'll retro-fit it on the jeep!
Unread 04-15-2014, 07:18 PM   #3
Delawdude
Junior Member
So after removing the carpet I came across some floors that needed some attention
Drivers Side Before and After repairs:
Passenger Side Before and After:
Unread 04-15-2014, 07:19 PM   #4
Delawdude
Junior Member
And Rockers need some attention
Drivers Side Rocker Before/After:
Passenger Side Rocker Before/After:
Unread 04-15-2014, 07:19 PM   #5
Delawdude
Junior Member
Next came a Prothane 1" Body Lift
Not too many pictures of the install --- but I did break one bolt, have the nut plat spin on the rear mount, and another bolt that would just not come out, so I hacked away:
Here's why you pay attention when working with an angle grinder….honestly thought I had the clearance - ah well, nothing a little weld patch won't fix.
Unread 04-15-2014, 07:20 PM   #6
Delawdude
Junior Member
Next, I found some factory front and rear ends from another jeep that had 4.11's which have to be a better option than my 3.07's (I plan to run 33's for now). So I swapped those bad boys in:
Also installed new greasable shackles and bushings for the springs --- Let's say the rear leaf spring needed a little convincing to line up with the shackles…..
Unread 04-15-2014, 07:21 PM   #7
Delawdude
Junior Member
And here's how it sits today ---
Things I am going to do next include:
1) Replace the drag link, tie rod ends, and steering dampener (ordered, will be here this week)
2) Replace the front 2 leaf springs
3) Acquired new dash plate, need to install and reassemble
4) need a windshield frame, the old one was rusted beyond repair
5) ……don't want to think about the rest yet.
Figure I'll have it on the road in a few weeks
