Weekend TJ Interior Buildup (electronic mods) - JeepForum.com
post #1 of 7 Old 01-15-2010, 10:56 PM Thread Starter
EdsJunk
Weekend TJ Interior Buildup (electronic mods) UPDATE!
So after a long time of debating and finding a wrangler, i came across a 1998 2.5 with 90k miles for 3900. So i jumped on that! It had some bigger tires on it already, and I am more of a interior mod guys myself, so here is what has been done so far! feel free to ask any questions!
So I wanted all of my gadgets (ipod radio, CB, scanner, gps, inverter and such) to be all permanently installed and secure. So tuffy was the best option for me! and i love it! I got everything used on ebay quite cheap, more than half the cost of new. I also added some Hella 500 Lights to the front. So ill type what I have done and will add pics.
-CB Radio. I have a Cobra 29 with Bluetooth Speaker phone system. I definitly wanted to add this to the jeep. I wanted to install it into the tuffy center console radio spot. Well if any of you have tried to put the 29 radios in this center console.. it simply does not fit. Even with nothing plugged into it, it still sticks out about 2 inches from the top, eliminating the use of the lockable door. And after you put on the antenna cable, its about 4 inches out the top. Well long story short, I got it to fit. I had to pull the antenna, mic, power and speaker jacks to inside of the unit and plug them inside the CB. it still being to big, i cut about 2" off of the casing of the CB and maneuvered the circuit boards and such and got it to fit! I then used the bottom of the CB with the speaker, as a speaker box that fits after my center console under the dash (see pics) Looks like it was meant to be there!
-Scanner and Switch Box. I wanted both of these units in the tuffy overhead console. This was in fact very easy. both fit nicely and will have to say that console is by far the best I have bought. The switch box is something I custom made. It has 6 switches. One is a power over ride switch that lets you run all of the accessories along with the factory stereo without a key in the ignition. This helps alot if you want to shut off the engine (getting gas, ext) but do not want to turn off your electronics. All the other switches are also provided power when the wrangler is turned on. the other 5 are for my accessories. Each switch has 1 green and 1 red led under it. Red indicates it is off, green on. I also added a fuse box to the switch panel, so each switch/led set has its own fuse. The whole box has a quick disconnect as well. The scanner had no additional modifications to it.
GPS. I wanted a GPS in the wrangler, but did not want to use a suction mount as it would quickly get stolen. So I made a bracket that allowed me to screw the GPS to the dash frame. Its great and if someone was to try and steal it, they would only bend up the bracket or break the GPS.
Inverter. I mounted a small inverter under the passenger seat. It has a single outlet, but I added 2 outlets to the tuffy center console along with a green LED to tell me if it is on. The Red LED shows me that the Power Over Ride from the switch panel is on.
Garage Door Openers. I mounted in two garage door openers inside my dash board and have LED momentary switches on my dash to control them. The lights come on when the wrangler is on, and they have a Status LED light as well (blinks when you push the button).
Switch Box
CB. Cobra 29 in Tuffy Center Console
Power inverter outlets/CB Ext Speaker
Garage Door Openers
EdsJunk is offline
post #2 of 7 Old 01-16-2010, 12:12 AM
Hobojo
That is nifty!
Very cool!
How do you like that overhead console?
I was debating on picking one up, but I heard it rattles enough to drive you crazy
"You can't be a real country unless you have a beer and an airline - it helps if you have some kind of football team, or some nuclear weapons,
but in the very least you need a beer." Frank Zappa
Hobojo is offline
post #3 of 7 Old 01-16-2010, 09:26 AM Thread Starter
EdsJunk
I love the console. It hasnt rattled much for me to notice yet... dont know what people are talking about? seems fine!
EdsJunk is offline
post #4 of 7 Old 01-16-2010, 10:39 AM
thetrashman
that is BEAUTIFUL!
awesome job!
95' Little Red Yj.
"My Jeep Doesnt Leak, Its Just Marking Its Territory"
Mostly Stock,With A Few Things
thetrashman is offline
post #5 of 7 Old 01-16-2010, 11:11 AM
GroceryGetter01
That looks great
Yellow Jeep Club Member #802
Originally Posted by JLC08JK View Post
Load up all the recovery gear!!!!
We're goin' to the "MALL"
-Jason
GroceryGetter01 is offline
post #6 of 7 Old 01-23-2010, 09:45 PM Thread Starter
EdsJunk
UPDATE!
I installed a new panel where the stock switches/ash trays were and added 3 switches and an atomic clock. I also added some Red LED ambient lighting.
So for the panel. The stock switches were not doing it for me, so I pulled the center dash out and cut out the ash tray. I then cut a piece of sheet metal to the same size as the opening and screwed it down. I then added 3 Switches (One for Fog Lights, The Ambient Lighting (see next paragraph) and the next for some fog lights i will be adding to light up the sides when the doors are open. I also added a atomic clock with inside and outside temp and modded the backlight to come on when the ignition is on and stay on.
Now for the ambient lighting. I was driving the wrangler a few nights ago and thought how i wish i could see the center console and floors without being to bright. So I came up with the LED idea. I had a total of 8 LEDs. 6 in the front and 2 in the back. I made some brackets form sheet metal i had left over and used stock screw holes in the jeep to mount them. They are real nice and are not to bright and are not distracting. They come on with the ignition and do have a cut off switch.
LEDs And the wiring is not as messy now
EdsJunk is offline
post #7 of 7 Old 01-23-2010, 11:58 PM
rubidriver
Too many buttons and switches and lights going on for me.
2005 Black Rubicon - OME 933/942 - 4" Bilstein 5100 (canister up) - JKS Adj Track Bars Front/Rear - JKS Quicker Discos - 285/75/16
Originally Posted by bigj1974 View Post
your money will go farther in College Station.
rubidriver is offline
TJ interior mods TXjeepTJ Jeep Picture Requests 21 02-03-2014 05:50 AM
Post pics of your INTERIOR mods! General Lee Jeep Picture Requests 30 11-26-2009 08:48 AM
My Jeep Buildup Chris_W_2k5 Jeep Builds 5 10-24-2009 07:20 PM
Cool, Unique, Different XJ interior mods The Shoveller Jeep Picture Requests 33 09-23-2009 08:38 PM
Finished my TJ mods this weekend R.Ducky Jeep Builds 19 09-12-2006 07:20 AM
