The Wasteland Survival Guide: Engineering Greta - Page 55 - JeepForum.com
post #811 of 8099 Old 05-13-2012, 09:31 PM Thread Starter
Sundowner
Originally Posted by balzer View Post
Pass on the inline all together and go with a v8 in your prefered flavor...
All are very, very good suggestions...but all are also, unfortunately, not easily (if at all) permitted by the emissions laws in my particular corner of Paradise. If Greta was a trail-only rig I'd have a small V-8 in her in a heartbeat, but I drive her every day...and around here, even going to the 5.7 Hemi - a newer, cleaner Chrysler engine - can be a pain in the a**, legally. For that reason - and for the small amount of down-time the actual switch would take - a large-cube stroker is one of the best possible "go big or go home" solutions.
Sundowner is offline
post #812 of 8099 Old 05-13-2012, 09:43 PM
GoGetEmTurbo
I didn't think there was anywhere that was worse than Cali in regards to Smog. This place is ridiculous.
Go here to watch my truck burn...
www.dirtjunk.com
GoGetEmTurbo is offline
post #813 of 8099 Old 05-14-2012, 01:13 AM
tdavid14
Short-term, you can try anything from Autozone with the word "miracle" in it to slow the inevitable.
tdavid14 is offline
post #814 of 8099 Old 05-14-2012, 07:20 AM
balzer
Boo on emissions! I would try it anyway and see if anyone even notices its not the stock engine LMFAO. But I dont have those rules to deal with.
2001 TJ SE
1971 J4800 gladiator
balzer is offline
post #815 of 8099 Old 05-14-2012, 07:43 AM
Skeets682
http://www.novak-adapt.com/knowledge...p_yj_87-95.htm
Also pertains to the TJ....
Has me thinking about Grey Ghost II engine swap....
Noooobie to Jeeps!
Dalmatian Owner (well they own us!)
Skeet and sporting clays shooter.
Retired AF
Skeets682 is offline
post #816 of 8099 Old 05-14-2012, 09:25 AM Thread Starter
Sundowner
That is an excellent link...mostly because I happen to have not only a freshly-prepped 5.0 roller-cam block laying around and doing nothing with its life, but because I alsohave a complete, working, fuel injected 5.8 in a '94 Bronco. And I've thought more than once about trying to cram that second one under Greta's hood...but that's really hard to do when you call the emissions people and say "Okay, here's what I'm going to do...now, how do I title it and get it inspected?" and have them not be able to tell you. California may have more restrictive laws, but at least they're standardized and the enforcers are well-informed. Here, nobody has a f****** clue, and you're likely to get a swap done under the instructions of one person and have another determine that it's illegal and cannot pass inspection.
In any case, I'm going to give that link a thorough read. Thanks again!
post #817 of 8099 Old 05-14-2012, 09:33 AM
GoGetEmTurbo
Initially, this surprised the heck out of me but now contemplating it for a few, makes complete sense. They want to control everything about it here, making a pretty hard line in the sand.
www.dirtjunk.com
post #818 of 8099 Old 05-14-2012, 01:10 PM
Mallanaga
TJ Wrangler
How is this possible? The engine creates emissions. Why does it matter what vehicle it's in? California has smog tests, which consist of someone slapping a big tube to your exhaust, and analyzing the parts per million of CO2. I've seen techs that don't even open the hood...
Sooooo... I'm a little confused about your concern...
Mallanaga is offline
post #819 of 8099 Old 05-14-2012, 01:13 PM
narnwv
narnwv's Avatar
Because it's against Federal law to put an older model engine into a vehicle. For instance, you can't put a '96 4.0 into a 99 or newer Jeep. You can use the block, but that's about it. (if you're following the rules) The '96 doesn't match the emissions that the 99+ design does.
~Aaron
narnwv is offline
post #820 of 8099 Old 05-14-2012, 01:50 PM
Skeets682
From my understanding of "Engine swaps" as long as you put in a same model year or newerengine than the recepient body is then you are good per federal standards. I mean, a brand new Ecoboost V-6 is MUCH more efficient than a 2005 4.0L. It's a win/win. Also, there are companies out there that will make new wire harnesses for the swaps. All you do is supply the new engine harness and the old body harness. In theory, takes all the spark chasing out of the equation. (yeah right).
Also, I call dibs on the BD motor mounts if you do a swap!
Noooobie to Jeeps!
Retired AF
post #821 of 8099 Old 05-14-2012, 01:50 PM Thread Starter
Sundowner
Here we have counties that test emissions and counties that don't test emissions. We have exemptions for certain vehicles and certain years and certain modifications. We have Federal laws with which me must comply - such as the "older engine" law stated above - and also state laws...some of which seem to countermand the Federal stuff. If you're building a trail rig, then you're happy because all bets are off at that point...but when it's titled and registered for highway use, all kinds of retarded stuff gets involved. Believe me when I tell you that it isn't easy: the best suggestion that the DMV could give me was to attempt to title it as a one-off custom vehicle and then hope that my insurance would still cover it. So you and I are in the same boat...the concern is totally pointless, but the state can easily make it a huge hurdle because of ambiguities in the written laws and their subsequent enforcement.
Either way, it's a down-the-road project...unless Greta's engine kicks out suddenly. Then there's going to be a lot of profanity.
Yep, that's the Federal guideline. And we have some retarded state laws that render that otherwise-clean blanket statement totally useless...i.e. the engine must come from the same "category" of vehicle, and the replacement engine must have been available in vehicles of that "type" from the manufacturer...it's truly idiotic. I've called the DMV on it before and been told one time that a V-8 swap was fine as long as it met the emissions test for the original vehicle, only to be told when I next called that swapping in the engine wasn't allowed at all under state law. Neither seem to be true.
So noted.
post #822 of 8099 Old 05-14-2012, 02:20 PM
hallsofstone
Them engines got year numbers on them. You remember your number and always run the ones that has your number. Any man forgets his number spends a night in the box. These here emissions regulations you keep with you. Any man loses his emissions regulations spends a night in the box. There's no hillbilly fixin' or booty fabbin' in the garage. You got a problem with your vehicle, you fix it Saturday afternoon. Any man hillbilly fixin' or booty fabbin' in the garage spends a night in the box. Annabelle tells you when you will get in your bunk. Annabelle has word #1. Any man not in his bunk at Anna's word spends a the night in the box. There is no smoking out the tailpipe in this state. To smoke out the tailpipe you must have a trail only rig. Any man caught smoking out the tailpipe on the road... spends a night in the box. You get two sammiches for most fixes. Every Saturday, you put the first sammich in your mouth... finish the fix... and the second sammich in the microwave then, in turn, in your mouth. Any man eats the second sammich cold spends a night in the box. No one'll sit in Anna's bunk with dirty pants on. Any man with dirty pants on sitting on Anna's bunk spends a night in the box. Any man don't wash out his empty beer glass spends a night in the box. Any man caught talking crap about Jeeps spends a night in the box. You got questions, you come to me. I'm hallsofstone, the thread jacker. I'm responsible for disorder in here. Any man keepin' order spends a night in...
Jeeping Ohio Every Day
00 TJ Sport - Ever evolving DD/Rig
85 Suzuki GS700 - ugly
K.C.C.O.
hallsofstone is offline
post #823 of 8099 Old 05-14-2012, 02:40 PM
driggity
Well played boss. Well played.
driggity is offline
post #824 of 8099 Old 05-14-2012, 04:51 PM
Kodiak17
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline
post #825 of 8099 Old 05-14-2012, 04:57 PM
B2CARPEN
.... the box??
Founder of
B2CARPEN is offline
annabelle , bewbs , chic-fil-a , custom , d&d , fallout , firefly , girly things , guns , half cab , hard tonneau , needs to go wheeling , overbuilt , photography , pin-up , sammiches , starwars , survival , wasteland
  LinkBacks (?)
LinkBack to this Thread: http://www.jeepforum.com/forum/f22/wasteland-survival-guide-engineering-greta-1344782/
Posted By For Type Date
glockforum | BoardReader This thread Refback 08-15-2012 09:17 AM
sears diehard batteries - forum communication | BoardReader This thread Refback 07-31-2012 07:50 AM
go there engineering bumpers austonreeves Jeep Picture Requests 4 07-29-2012 09:54 PM
What makes yours a Survival or Wilderness Jeep? fishinjeeper Jeep Picture Requests 39 07-23-2012 12:02 PM
BOV/Survival Jeeps ttony Jeep Picture Requests 2 09-30-2010 04:47 PM
33 engineering bigj1974 Jeep Picture Requests 2 02-03-2008 08:28 PM
GRETA .... then and now GRETA97 Jeep Builds 6 05-05-2004 08:41 PM
