The Wasteland Survival Guide: Engineering Greta - Page 486 - JeepForum.com
post #7276 of 8099 Old 07-14-2014, 08:30 AM
84jeepcj7rock
If you're not comfy welding on it.
Use a Dremel or die grinder to flatten the exposed bolt
Center punch
Get a set of left hand drill bits. Start small and take your time.
The drilling will build heat which will free the bolt
By your third drill bit, it will probably come out w the drill bit
If not, have an easy out ready to go
Measure the depth of your other bolt holes and set a stop so that you don't drill too deep
84jeepcj7rock is offline
post #7277 of 8099 Old 07-14-2014, 09:19 AM Thread Starter
Sundowner
Originally Posted by clintrivera View Post
Well, it's not the only process but it's the easiest and fastest for me. The first two I tried to do I center punched the bolt and drilled it out. Somewhere in the process it got into the aluminum and screwed the threads up so I had to deal with that.
The whole process too, an hour to fix. Next time I did the weld method and it only took 5 minutes.
Some people have success with a left hand drill bit, but I don't have any of those.
It seems like a LOT of weld inside the threading of the head; that's my concern. If there's no danger to the head from the molten metal, though... well, it may be a pointless worry.
Originally Posted by LA-Sahara View Post
I feel like you could find a small enough metal spacer like these from lowes: and weld through it to the leftover of the bolt. Then maybe a nut over that to turn it out?
That's what I was talking about when I mentioned a pin; using something hollow. I thought I might be able to keep the heat on the bolt and not let the weld ever touch the threads.
Originally Posted by kawi358 View Post
Only issue would be the spacer might be too small to get the gun in to weld it to the bolt.
Sundowner I'm of the opinion that a very accurately drilled bolt and quality easy-out would work the best. That's what I use to get broken bolts out. I would be worried that welding a nut to the bolt would melt part of the head down resulting in more headache ( see what I did there?) If you turn the heat way down it can be done but the weld may break under the torque.
Okay, first of all, that was a bad pun... but more importantly, I kind of feel the same way about welding through the center of a hollow pin; if I had some better skillz it would probably work, but I'm more likely to screw it up. If there was any bolt showing beyond the surface of the head I think I would feel more comfortable... so maybe drilling is a better option. I don't know.
Originally Posted by CEScuzzy View Post
Maybe you could build a jig that would force the bit to remain perpendicular to the hole and do a good center punching to keep it from wandering across the surface....or...
Marry the two plans. Drill a shallow hole in the head bolt (1/4" deep or so). Friction fit a steel dowel in the hole, then weld that to the bolt shank. weld a nut to the exposed end of the dowel and crank it out that way.
a complicated plan, yes, but it gets you out of the "broken off in the head" problem and gives you room to weld in the spacer/extension.
-Scuzz
That might work, too... but there's still going to be a lot of hot metal inside those aluminum head threads. Again, though, if that's not dangerous...
Center punch
I don't know that I can get anything inside there to flatten it... and if I can, it will have to be a TINY grinding die on a Dremel. Stupid bolts, breaking off where nobody can reach them...
Sundowner is offline
post #7278 of 8099 Old 07-14-2014, 01:04 PM
Magatetzz
I've used both methods to extract studs and I personally prefer to weld a nut onto it. Use just a little super glue to hold the nut in place, it will melt when you weld. I have to do this all the time doing exhaust manifolds on new Hemi engines
... and see what it's really going to take to build one...and then I'm going to triple that cost/time estimate and see how I feel.
Best gas milage from my Jeep to date: The time I pushed it across the lot at work.
Magatetzz is offline
post #7279 of 8099 Old 07-14-2014, 02:09 PM Thread Starter
Sundowner
That's a good suggestion; I suppose I fill up the threaded cavity and get the weld up to the head surface and then glue the nut in place, yes?
post #7280 of 8099 Old 07-14-2014, 03:00 PM
Magatetzz
I've always done the nut first, then just make the puddle up until you have penetration of the nut and it should come right out
post #7281 of 8099 Old 07-14-2014, 03:34 PM
Zjones1994
I'd just put the but over the hole with the glue do a quick little plugish weld and bam. Aluminum is pretty good about not messing up so if you do a relatively low setting you'll be good.
1998 Chili Pepper Red Jeep
USN Hull #233
Check out my build!
Zjones1994 is offline
post #7282 of 8099 Old 07-14-2014, 06:53 PM
TheDoc25
Even if you mess the first couple of threads up you can countersink the mess out, or put a helicoil in which will double the strength of you bolt. But also they come out real easy when a stud breaks off.
TheDoc25 is offline
post #7283 of 8099 Old 07-14-2014, 09:37 PM Thread Starter
Sundowner
Messing up and/or melting the aluminium is my biggest worry; I mean, it seems like it should melt if there's molten steel directly adjacent to it. If it'll withstand the heat and liquid metal, though... well, there shouldn't be any problems. I'll look to see what I can find that's small enough to reach inside the threaded hole and clean the sheared bolt faces without smurfing up the surrounding metal.
post #7284 of 8099 Old 07-15-2014, 06:51 AM
takirc02
How about a few small nuts, small enough to fit inside the bolt hole (I am sure some of you could have come up with an inappropriate joke here...wit is not my forte)...plug weld one on top of the other. Similar to the roll pin/spacer idea but without worrying about welder reach and better grip when you go to extract.
Owning a Jeep of any sort is an experience rife with opportunity to expand one's knowledge...
takirc02 is offline
post #7285 of 8099 Old 07-15-2014, 10:28 AM
CEScuzzy
What manner of welder do you have, Sundowner?
-Scuzz
"Some Assembly Required" is a target, not a deterrent.
CEScuzzy is offline
post #7286 of 8099 Old 07-15-2014, 05:55 PM Thread Starter
Sundowner
That's not a bad idea at all! Thanks!
Muppet Labs is currently equipped with a Miller 210; I think I've currently got .030 wire in it and 75/25 gas... but don't quote me on that.
Also - and be forewarned that this is totally unrelated - Today's Jeeping was me getting a lead on a job... so everybody needs to keep their fingers crossed, and if anyone has a spare chicken to sacrifice I'd be much appreciative; we're all out, here.
post #7287 of 8099 Old 07-15-2014, 08:57 PM
CEScuzzy
The things I could do with something like that...
Now if I only had the cash for a set of unibody stiffeners...
...but don't quote me on that.
I did anyway...
You've got my support. I hate job hunting, so here's to hoping that your job hunt has come to a successful close
I'll buy you a beer if you get the job, and two if you don't.
-Scuzz
CEScuzzy is offline
post #7288 of 8099 Old 07-15-2014, 09:08 PM
Mulvihill64
I'm fresh out of chickens, but how far would a monkey sacrifice get me
Instagram: Mulvihill64
Mulvihill64 is offline
post #7289 of 8099 Old 07-16-2014, 01:15 AM
91AzXJ
Break a leg and then get the job!
2000 XJ 4.0L/ Auto
04 TJ 4.0L- RIP 06 KJ Ltd
11 KK 70th Anniversary
91AzXJ is offline
post #7290 of 8099 Old 07-16-2014, 06:24 AM Thread Starter
Sundowner
And all the things that I can't seem to do with it...
I'll take that deal.
I don't know, honestly; I mean, we sacrifice monkeys constantly around here and there's no measurable impact that we've been able to document...and we keep meticulous documents. This tells me that monkeys have no value whatsoever, aside from their obvious use as pre-killed scientific testing material.
The funny part is that I'm ridiculously well-qualified for the position...which means that I'm almost sure to not get it.
annabelle , bewbs , chic-fil-a , custom , d&d , fallout , firefly , girly things , guns , half cab , hard tonneau , needs to go wheeling , overbuilt , photography , pin-up , sammiches , starwars , survival , wasteland
  LinkBacks (?)
LinkBack to this Thread: http://www.jeepforum.com/forum/f22/wasteland-survival-guide-engineering-greta-1344782/
Posted By For Type Date
glockforum | BoardReader This thread Refback 08-15-2012 10:17 AM
sears diehard batteries - forum communication | BoardReader This thread Refback 07-31-2012 08:50 AM
go there engineering bumpers austonreeves Jeep Picture Requests 4 07-29-2012 10:54 PM
What makes yours a Survival or Wilderness Jeep? fishinjeeper Jeep Picture Requests 39 07-23-2012 01:02 PM
BOV/Survival Jeeps ttony Jeep Picture Requests 2 09-30-2010 05:47 PM
33 engineering bigj1974 Jeep Picture Requests 2 02-03-2008 09:28 PM
GRETA .... then and now GRETA97 Jeep Builds 6 05-05-2004 09:41 PM
