The Wasteland Survival Guide: Engineering Greta - Page 472 - JeepForum.com
post #7066 of 8099 Old 06-07-2014, 03:40 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
Originally Posted by TheDoc25
Hey thanks again, one more measurement that will help me is the 3 bolt holes for the hardtop. What is the distance between them and does the one closest to the front door start at the same distance as Greta. My thoughts are with the 2 tubs I have, if I cut one top rail at the 15" mark straight down to the top of wheel tub. Then the other at the door jamb, with some tweaking I should be able to join the two on the inside with a little overlap. Then I just need to skin the outside below the rail. By trying this all I would need is a flat sheet without bends and everything as they will be in original body metal? I will try and draw on tubs so you get a better vision of what I'm thinking....
I find the best way to get the tub length correct is order a new pair of LJ belt rails from Jeep.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #7067 of 8099 Old 06-07-2014, 05:34 PM
TheDoc25
Originally Posted by Sundowner
Today's Jeeping: I figured out the answer to the Rear Seat Floorboard Area Question; there is exactly 2" of additional legroom, as measured between the front seat and rear seat mounts. The balance of the LJ's additional room is behind the rear seat; as far as the location of the hardtop holes is concerned....that's a bit harder to measure because there's about a quarter inch of aluminum in the way of me locating them on Greta. Also, unsurprisingly, I still don't have motor mounts...and if I get someone else's when they arrive, I will NOT be laughing.
Thanks, don't worry about measuring Greta, I have mine to compare. Found a good conversion someone is doing called "Another TJ-6 build"... Seeing as the tub will be completely off the frame, I guess I should do all the chopping and modding I can. Coil bucket relocation, track bar strengthening etc etc..
TheDoc25 is offline
post #7068 of 8099 Old 06-07-2014, 06:48 PM
TheDoc25
Not too much damage..
TheDoc25 is offline
post #7069 of 8099 Old 06-07-2014, 07:00 PM Thread Starter
Sundowner
They have those??
That's a good build, and yes...do everything you can do while you have room to do it. When I do the engine swap, I'll get rid of all kinds of stuff just to make a few extra inches of working room; it makes all the difference in the world.
I don't see any damage.
Sundowner is offline
post #7070 of 8099 Old 06-09-2014, 05:37 AM Thread Starter
Sundowner
Today's Jeeping: Calling about the motor mounts and seeing what's become of them...
post #7071 of 8099 Old 06-09-2014, 07:40 AM
Mulvihill64
Who knows - maybe the ones he pulled off the line to send to me were yours
Instagram: Mulvihill64
Mulvihill64 is offline
post #7072 of 8099 Old 06-09-2014, 08:23 AM
G Beasley
DOH !
G Beasley is offline
post #7073 of 8099 Old 06-09-2014, 04:22 PM Thread Starter
Sundowner
Today's Jeeping, Updated: THE MOTOR MOUNTS WERE SHIPPED TODAY!! There's a tracking number and everything! That means LJ-work this weekend! Party!
post #7074 of 8099 Old 06-09-2014, 05:01 PM
CEScuzzy
I wish I had time to partake; I could use the experience.
-Scuzz
"Some Assembly Required" is a target, not a deterrent.
CEScuzzy is offline
post #7075 of 8099 Old 06-09-2014, 07:03 PM
G Beasley
Have fun with the drivers side
post #7076 of 8099 Old 06-09-2014, 08:23 PM Thread Starter
Sundowner
Body lifts and motor mounts are easy, man... there's hardly any experience to be gained. You do the body lift first...
... and this little hiccup becomes stupidly simple.
post #7077 of 8099 Old 06-09-2014, 10:28 PM
bobthetj03
Nothing is "simple" with your endeavors! (popcorn).
Bob's boring build:
White Jeep club member #2003
bobthetj03 is offline
post #7078 of 8099 Old 06-10-2014, 04:34 PM
TheDoc25
We expect,,NO Demand pictures of such said vehicles owner partaking in this work
TheDoc25 is offline
post #7079 of 8099 Old 06-11-2014, 05:16 AM Thread Starter
Sundowner
It's been pretty simple thus far but that's probably only because I didn't have the correct parts in hand...and I may still not have the correct parts; I measured the JK springs that we were planning on running on the front of the LJ and they're about 1/2" shorter than my factory TJ springs. Also, the rates feel about the same...so what gives?
The question of a build thread for the LJ has come up multiple times; with so much else going on and over a dozen projects already in place at Muppet Labs it would be hard to find the time for a decent LJ build. Besides, there's nothing creative going on with that rig...yet.
post #7080 of 8099 Old 06-11-2014, 09:09 PM
TheDoc25
We don't need another thread here, just pictures.
TheDoc25 is offline
annabelle , bewbs , chic-fil-a , custom , d&d , fallout , firefly , girly things , guns , half cab , hard tonneau , needs to go wheeling , overbuilt , photography , pin-up , sammiches , starwars , survival , wasteland
  LinkBacks (?)
LinkBack to this Thread: http://www.jeepforum.com/forum/f22/wasteland-survival-guide-engineering-greta-1344782/
Posted By For Type Date
glockforum | BoardReader This thread Refback 08-15-2012 09:17 AM
sears diehard batteries - forum communication | BoardReader This thread Refback 07-31-2012 07:50 AM
go there engineering bumpers austonreeves Jeep Picture Requests 4 07-29-2012 09:54 PM
What makes yours a Survival or Wilderness Jeep? fishinjeeper Jeep Picture Requests 39 07-23-2012 12:02 PM
BOV/Survival Jeeps ttony Jeep Picture Requests 2 09-30-2010 04:47 PM
33 engineering bigj1974 Jeep Picture Requests 2 02-03-2008 08:28 PM
GRETA .... then and now GRETA97 Jeep Builds 6 05-05-2004 08:41 PM
