The Wasteland Survival Guide: Engineering Greta - Page 439 - JeepForum.com
post #6571 of 8099 Old 04-05-2014, 08:07 AM
G Beasley
Come over and we can swap the Tera 2.5's in pretty quickly and that will answer your question .
G Beasley is offline
post #6572 of 8099 Old 04-05-2014, 08:10 AM
357transam
Trust me when I say if I had those, I would be swapping out my rough country springs. And I totally forgot about your brakes. Doesn't Jankoids sig say something about a set of curries he has for sale?
357transam is offline
post #6573 of 8099 Old 04-05-2014, 08:51 AM
357transam
post #6574 of 8099 Old 04-05-2014, 09:20 AM
cfmiller58
this is pretty cool, i havent been on the forum in a really long time because of work, but sundowner's thread is still going. keep it up!
Black Jeep Society
cfmiller58 is offline
post #6575 of 8099 Old 04-05-2014, 10:13 AM Thread Starter
Sundowner
Today's Updated Jeeping: The Elusive Accessory Drive Noise is, in fact, a dying fan clutch. When I popped the fan out and started the engine there was no screeching/rattling whine at all; I could hear the internal rattles and knocks a lot better, but the the mysterious noise in question was gone. So, that leaves me with a decision: do I replace the clutch or go electric with a Taurus fan?
Sundowner is offline
post #6576 of 8099 Old 04-05-2014, 11:32 AM
357transam
I run an electric on my other wheeling rig. There has been more than one occurance where the fan, relay, or wiring has failed ending my wheeling day early. I vote stick to the far more reliable mechanical setup. You don't do deep water crossings that I have seen, so no need to worry about the fan contacting the radiator.
post #6577 of 8099 Old 04-05-2014, 12:27 PM
84jeepcj7rock
I would bet that the shocks are responsible.
Have you driven the jeep without shocks? It won't hurt anything to do so.
84jeepcj7rock is offline
post #6578 of 8099 Old 04-05-2014, 01:57 PM
CEScuzzy
You sure you want to do this? We can't guarantee your safety, you know; steak and beer and Jeeping tends to make certain parts of the Wasteland even more dangerous than usual...
Would a man with any regards to his own safety study electrical engineering and settle on snowboarding as his favorite "athletic" hobby?
Also...steeeeaaaaaaak
-Scuzz
"Some Assembly Required" is a target, not a deterrent.
CEScuzzy is offline
post #6579 of 8099 Old 04-05-2014, 02:43 PM
dongalonga
First, find a friend and swap springs (you will have to be nice for a day to accomplish this task).
Second, never say electric fan or Blaine will find you.
That is all.
dongalonga is offline
post #6580 of 8099 Old 04-05-2014, 04:06 PM
1989comanche
1989 MJ Comanche
[QUOTE=Sundowner;21875801]Did...did you get that with pickles???? Where's the "Vomit"
Yep with pickles!!
1989 Comanche
Mostly stock except homemade custom bumpers
1989comanche is offline
post #6581 of 8099 Old 04-05-2014, 04:53 PM
mp15dc
1989 XJ Cherokee
I went with the Taurus fan upgrade. It has not given me any problems for several years, But..
my electrical is Factory Jeep wiring. Relays, sensors, plugs. Its non-computer control and no aftermarket temp sensors.
It does have a temp sensor in both the upper and lower rad hoses, to allow low and high speed control.
I have enjoyed reading your thread.
mp15dc is offline
post #6582 of 8099 Old 04-05-2014, 05:06 PM Thread Starter
Sundowner
I may do that...
The Nth stuff can still be had, if you know where to look...
I was bored, so here's links to several springs for sell on the forum.
Not bad at all, price-wise; I wish I could use a 4" spring!
No worries, man...we're not slacking off anytime soon. If anything, it's about to get much, much worse.
The mechanical fan is a marvel of reliability, and reliability trumps pretty much everything in the Wasteland...so that's a very solid point that you make. I wish I could find a mythical seven-blade, though; even if I didn't use it, I'd like to have one just for the sake of having it.
Sadly, you would lose that bet; I've swapped the fronts out for a brand-spanking-new set that OME sent to me when I contacted them about the increasing firmness, and there was no real improvement. I've also driven with the shocks removed from the front, and while that was a terrifying roller-coaster of a trip around town it only showed how much ride-control the shocks were providing; the stiffness and harshness were still there.
I suppose that all depends on the amperage and slope of the hills.
Wanna guess what I'm having for dinner tonight?
I keep telling you guys - and girls - that I'm Neutral Evil; that doesn't mean that I'm callous, or that I'm not nice. Alignment doesn't dictate behavior; it mostly only dictates which warding spells will give you a problem at the most inopportune time.
I thought about swapping mine with Beasley's, just to see what happened; either way, he has the aforementioned 2.5" Tera springs...so that swap would pretty much eliminate the springs as a candidate. The only thing that might tell us more - as in, whether or not there's a problem with my particular set of springs - is to swap his identical OME 2.5's into Greta's front end and then go hit a bump or three.
I'm think I'm safe because I'm pretty sure that Blaine doesn't read this thread...but there's no telling, with him.
As it stands, I don't have to worry about it just yet because I found a fan clutch in-stock at one of the local parts houses and decided to go ahead and swap it in; I can still go electric later on if I like, but for now I've got one potential failure point eradicated. I'll post some photos of the whole process - tensioner and all - tomorrow at some point. Maybe. Time for beer and steak, now.
post #6583 of 8099 Old 04-06-2014, 11:29 AM
tdavid14
Let's see if your springs produce that bad ride on someone else's Jeep that has a known "good" ride.
tdavid14 is offline
post #6584 of 8099 Old 04-06-2014, 12:33 PM
YjStrangler92
If this fails too, only ideas I have is Greta may be possessed. ......... hopefully not
YjStrangler92 is offline
post #6585 of 8099 Old 04-06-2014, 02:43 PM
Melissas6570
If it is true then mine is too.
I DO IT WITH MY TOP OFF!
Melissas6570 is offline
annabelle , bewbs , chic-fil-a , custom , d&d , fallout , firefly , girly things , guns , half cab , hard tonneau , needs to go wheeling , overbuilt , photography , pin-up , sammiches , starwars , survival , wasteland
  LinkBacks (?)
LinkBack to this Thread: http://www.jeepforum.com/forum/f22/wasteland-survival-guide-engineering-greta-1344782/
Posted By For Type Date
glockforum | BoardReader This thread Refback 08-15-2012 10:17 AM
sears diehard batteries - forum communication | BoardReader This thread Refback 07-31-2012 08:50 AM
go there engineering bumpers austonreeves Jeep Picture Requests 4 07-29-2012 10:54 PM
What makes yours a Survival or Wilderness Jeep? fishinjeeper Jeep Picture Requests 39 07-23-2012 01:02 PM
BOV/Survival Jeeps ttony Jeep Picture Requests 2 09-30-2010 05:47 PM
33 engineering bigj1974 Jeep Picture Requests 2 02-03-2008 09:28 PM
GRETA .... then and now GRETA97 Jeep Builds 6 05-05-2004 09:41 PM
