The Wasteland Survival Guide: Engineering Greta - Page 393 - JeepForum.com
post #5881 of 8099 Old 12-05-2013, 03:48 PM Thread Starter
Sundowner
Originally Posted by TheDoc25 View Post
. I have to shrink them first so I will give you a pictorial of his travels in a few days, he might even be going on a long sea voyage south in a few weeks to The Land Downunder.....
That has much potential for Awesomeness; I, too, have lots of pictures to shrink down and post...I just haven't gotten around to doing it yet.
Sundowner is offline
post #5882 of 8099 Old 12-05-2013, 10:25 PM
91AzXJ
The land downunder is not exactly a quick trip from the middle east.
2000 XJ 4.0L/ Auto
04 TJ 4.0L- RIP 06 KJ Ltd
11 KK 70th Anniversary
91AzXJ is offline
post #5883 of 8099 Old 12-06-2013, 04:26 PM
G Beasley
Update: Much work and appertaining tiredness. I have pictures of axle progress, but I haven't sorted them out yet...mostly because I'm slack. Oh, I also have a red tailgate sitting on my porch; that's Beasley's fault.
Yes , I am an enabler .
G Beasley is offline
post #5884 of 8099 Old 12-07-2013, 08:10 AM Thread Starter
Sundowner
Today's Jeeping: I swear that I'll post a picture of SOMETHING. Really. I wouldn't lie about this.
post #5885 of 8099 Old 12-07-2013, 10:29 AM
ashland82391
Good lookin ladies working on your Jeep??? :-)
ashland82391 is offline
post #5886 of 8099 Old 12-09-2013, 03:11 PM
unholycowgod
Originally Posted by sundowner View Post
today's jeeping: i swear that i'll post a picture of something. Really. I wouldn't lie about this.
Lies!!!
My general rule of thumb is to maintain enough weaponry to start a small war, and enough ammunition to finish it. -Sundowner
unholycowgod is offline
post #5887 of 8099 Old 12-10-2013, 07:14 AM
CaveyDM
Yup
CaveyDM's Avatar
This may have already been covered, but you just reminded me to look for the answer. What did you do to fix the gas puking problem? Seems I'm plagued by the same thing.
Best Regards,
Dale
2006 2DR LJ RUBICON UNLIMITED / Old Man Emu (OME) 2.5" HD Lift / ARB Quadratec Edition Front Stubby / LOD Signature Series Rear Bumper & T/C
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
CaveyDM is offline
post #5888 of 8099 Old 12-10-2013, 07:26 AM
unholycowgod
You'll need to get a replacement GM gas hose that has a flapper valve inside it. Best fix is to remove the flapper from the new hose and insert it into your OEM hose. Easiest way is to heat up the hose in warm/hot water to expand it a bit and insert the valve.
Quoted from: http://www.jeepforum.com/forum/f9/05...w-fix-1335243/
Originally Posted by SHoppe715 View Post
look up GM TSB: 04-06-04-003A for a list of vehicles to try and score one from a salvage yard.
[UPDATE: Adding this list because it's looking like we're depleting the NOS supply of these old hoses. Salvage yard hunting may have to start happening.]
2003 Chevrolet TrailBlazer with 83 L (22 Gallon) Fuel Tank (RPO NNK)
2003 GMC Envoy with 83 L (22 Gallon) Fuel Tank (RPO NNK)
2003 Oldsmobile Bravada with 83 L (22 Gallon) Fuel Tank (RPO NNK)
2002-2003 Chevrolet TrailBlazer EXT
2002-2003 GMC Envoy XL
2004 Buick Rainier
2004 Chevrolet TrailBlazer, TrailBlazer EXT
2004 GMC Envoy, Envoy XL, Envoy XUV
2004 Oldsmobile Bravada
Built Prior to December 2003
post #5889 of 8099 Old 12-10-2013, 08:24 AM
CaveyDM
Yup
CaveyDM's Avatar
Awesome! Thank you kind sir!
Best Regards,
Dale
CaveyDM is offline
post #5890 of 8099 Old 12-10-2013, 11:01 AM
TheDoc25
No it will be a slow boat ride for sure,,, especially my waiting time for it to arrive....
TheDoc25 is offline
post #5891 of 8099 Old 12-10-2013, 11:02 AM
TheDoc25
Time, where does it go. Especially around the silly season....
TheDoc25 is offline
post #5892 of 8099 Old 12-12-2013, 08:34 AM Thread Starter
Sundowner
Well, I've learned my lesson about saying I'll get around to something: every time I do it, I don't get to slow down for five or six days. Here's some late-game coverage of the last bit of work I did on the HP44 housing.
So it turns out that removing the axle wedges is WAY easier than I thought it would be; it really is just as simple as cutting 90% of the way through the welds, beating the ever-living s*** out of the wedges to crack the last bit of the weld on one side or the other, and then prying them off and cleaning up the remains. I probably should have been a bit more careful with the whole "wear some gloves while operating a tool that spins an abrasive wheel at a couple thousand RPM" thing, but I couldn't really feel much with gloves on and I was more concerned about the housing than my fingers, so, whatever.
Pictured: Besides, you can buy new fingers for like, three dollars apiece, these days.
Although it's a bit hard to see in that picture, the important part of cutting the welds is to NOT angle the cutting wheel towards the center of the axle tube any more than is necessary; if you can keep the angle of the wheel very shallow relative to the nearest surface of the tube the chance for gouging the tube itself is minimized and the weld can be cut with minimal effort. Here's a better shot of what the shallow-angled cut looks like; notice that if I'd kept cutting or accidentally gone too deep, I would have only skimmed the surface of the tube and not put a deep slice into it that would necessitate repairs.
Pictured: Also, note the crack at the base of the weld...
The crack in the picture above comes from the repeated usage of a cut-depth gauge...a device which is known as "a big-a** hammer" in the common parlance. I'm totally not kidding about that, either; I periodically stopped cutting and gave the wedge a few vicious smacks with a 3-lb. cross-peen to see if I'd cut deeply enough to break the weld instead of cutting all the way through it. Once there was a paper-thin layer of weld remaining, a crack would start to form and I knew to not cut any deeper, and the result was an unmarred axle tube. I also found out that I only had to break the weld on one side; once one side or the other is cracked and broken, the other side will give way with MUCH less cutting.
Pictured: All that's required is a large pry bar and a bit of leverage...
Pictured:...and the wedge will pop right off.
After repeating that procedure three more times I was left with a somewhat-cleaner-and-lighter housing than I'd started with. I also figured out that making the very shallow cuts to remove the wedges had the unfortunate effect of leaving a LOT of weld still attached to the housing...but a hard grinding disc and an hour or so of labor took care of the extra metal.
Pictured: And it also made a horrific mess...but, whatever.
Pictured: ""Wedges? We ain't got no wedges. We don't NEED no wedges!"
After I got through with the remains of the wedge welds, I went ahead and ground off the sheet metal brake line clips and then took a 60-grit flap wheel to all of the areas that I'd worked on; I could have skipped that part entirely but I was having a good time and didn't have anywhere else to be.
Pictured: Shiny.
I actually got the remains of the carrier and the ring gear out, as well, but I figured I would save those pictures until I pulled the pinion gear out, which I haven't done. That's my next step, along with removing the desiccated remains of the inner axle seals; they're literally rusted/cracked apart. After all of that stuff is removed I'll take the housing to get cleaned up - not sure about how to do that, yet - and then take it to The UberMark for work on the inner C's, which I've decided to replace entirely. I found a good deal on some beeftastic ones from Crane, so I'll probably go with them. In between all of that work, I'll get the factory front swaybar removed - yeah, I still haven't done that - and get the AntiRock installed, and I'll also get an Annabelle picture posted because I'm starting to think that I'm going to get burned at the stake if I don't do so in short order...
Stay tuned...
post #5893 of 8099 Old 12-16-2013, 09:07 AM
misterpookie
OH GOD IT'S BEEN SO LONG AND NOW YOU'RE DISASSEMBLING AXLES. WHAT HAVE I MISSED?
also, hi.
jeep-sleep: N, V,
1: (verb) to fall asleep in one's jeep, generally in the reclined position or perhaps even on top of the roof. Ex: :I think i may pull over and jeep-sleep for a bit"
2: (noun) the sleep one gets while in a jeep. Ex: "Dude, that wasn't a nap.. it was a jeep sleep."
FOR SALE:
misterpookie is offline
post #5894 of 8099 Old 12-16-2013, 02:12 PM
CaveyDM
Yup
CaveyDM's Avatar
Did I hear mention of farming tools, bonfires, and sack cloth masks? We could throw rotten vegetables and scream profanities as well, but that might seem a bit over the top.
Best Regards,
Dale
CaveyDM is offline
post #5895 of 8099 Old 12-16-2013, 08:08 PM
contdevelop
subscribed
contdevelop is offline
annabelle , bewbs , chic-fil-a , custom , d&d , fallout , firefly , girly things , guns , half cab , hard tonneau , needs to go wheeling , overbuilt , photography , pin-up , sammiches , starwars , survival , wasteland
  LinkBacks (?)
LinkBack to this Thread: http://www.jeepforum.com/forum/f22/wasteland-survival-guide-engineering-greta-1344782/
Posted By For Type Date
glockforum | BoardReader This thread Refback 08-15-2012 09:17 AM
sears diehard batteries - forum communication | BoardReader This thread Refback 07-31-2012 07:50 AM
go there engineering bumpers austonreeves Jeep Picture Requests 4 07-29-2012 09:54 PM
What makes yours a Survival or Wilderness Jeep? fishinjeeper Jeep Picture Requests 39 07-23-2012 12:02 PM
BOV/Survival Jeeps ttony Jeep Picture Requests 2 09-30-2010 04:47 PM
33 engineering bigj1974 Jeep Picture Requests 2 02-03-2008 08:28 PM
GRETA .... then and now GRETA97 Jeep Builds 6 05-05-2004 08:41 PM
