The Wasteland Survival Guide: Engineering Greta - Page 385 - JeepForum.com
post #5761 of 8099 Old 11-05-2013, 12:02 PM
bobthetj03
The wheels won't fit over my brakes.
Huh? Different offset factory wheel on the LJ?
Bob's boring build:
White Jeep club member #2003
bobthetj03 is offline
post #5762 of 8099 Old 11-05-2013, 12:06 PM
redrelyt12
Greta has a big brake kit designed for 16" wheels, while the LJ sits on 15" wheels
I never make the same mistake twice - it's more like three or four times.
Build - http://www.jeepforum.com/forum/f22/unlimicon-build-1477723/
redrelyt12 is offline
post #5763 of 8099 Old 11-05-2013, 12:10 PM
bobthetj03
Ahh, I had to do a double take of his wheels cause I thought they were canyons. Makes sense now.
Bob's boring build:
post #5764 of 8099 Old 11-05-2013, 01:19 PM
357transam
Oops. Forgot about the big brake kit.
357transam is offline
post #5765 of 8099 Old 11-05-2013, 06:24 PM Thread Starter
Sundowner
Yeah, I can't fit 15" wheels...but if that's the price of really good brakes then so be it; I'm happy with what I have and if I ever get around to an axle swap I'm going to be hard-pressed to get brakes as good as what I have right now...and on this subject, Jankoid, you are sworn to silence.
Audio Digression
In completely unrelated news, I've been picking away at making a factory sub console into something that's halfway useful: a sealed enclosure for a 6.5" driver. It's really not been difficult, thus far; all I had to do was find a way to repair the big triangular hole that's left in the box when you remove the nigh-useless factory amp. To accomplish that, I cut out of piece of scrap 3/16" 5052 and epoxied it in place.
Pictured: Not a bad fit.
After the epoxy cured overnight I pulled the mounting bracket off of the box, shot a coat of Umbrella Gray™ on it, and then hit the box and aluminum cover plate with a coat of flat black.
Pictured: The box now looks vaguely menacing, for some reason.
The epoxy likely didn't form a 100% perfect seal - mostly because I didn't have quite enough on hand to do the job and therefore spread it a bit thin - so I'll probably mix up a batch of something that's a bit thinner and apply it to the inside of the aluminum/plastic joint. That should hold everything together pretty solidly...and if I can't find a thin epoxy, I can always default to 3M 5200. Here's a shot of what the inside looks like, at current:
Pictured: The inside, at current.
I don't really see too many problems with getting a 6.5" or 6.75" driver mounted here, except for that little recessed area on the mounting deck, adjacent to the molded-in wire tunnel; I might have to work a bit to seal that up. It'll be awhile before I have the caps to afford a speaker to fill the hole - I have an AntiRock to buy, after all - but I'll get there sooner or later, hopefully without resorting to begging. Penny for the Guy?
Sundowner is offline
post #5766 of 8099 Old 11-05-2013, 10:24 PM
davewjcook
Just to add a possible option to your list - it's possible, dare I say easy, to fit a shallow 8" Kicker sub there with only some minor trimming to the plastic splines in the back. I'm sure other brands' shallow-mounts would fit as well. Might give you some more easily-sourced options for that mid-range base...
davewjcook is offline
post #5767 of 8099 Old 11-06-2013, 12:49 AM
bobthetj03
I tried!
Bob's boring build:
post #5768 of 8099 Old 11-06-2013, 06:41 AM Thread Starter
Sundowner
I'm actually going to fit a true 8" sub elsewhere and use it for my lower-end stuff; it won't give me the same results as a 10" but it will take up FAR less room and do what I need it to do. To my way of thinking, the biggest problem that exists in a TJ is the level of ambient noise that drowns out the middle frequencies; it's easy to get the highs to where you need them and it's easy to create bass, but the middle range is so easily killed off that it needs all the help it can get. To that end, I figured that a single 6.5/"6.75" driver running in bridged mono on the rear channels - sort of an "L-R" thing - would be good for fill/volume and help the missing midrange to show back up.
I tried!
That's the important part.
post #5769 of 8099 Old 11-06-2013, 08:14 AM
jbjorgen
jbjorgen's Avatar
Penny for the Guy?
Remember, Remember...
jbjorgen is offline
post #5770 of 8099 Old 11-06-2013, 11:29 AM
SocialScot
A day late on this one.
Nope. I am.
-SocialScot
SocialScot is offline
post #5771 of 8099 Old 11-06-2013, 05:02 PM Thread Starter
Sundowner
Today's Jeeping focused on price-shopping AntiRocks and a few other odds and ends; cable for Greta's wiring upgrade - upgrayedd - was high on the list, as was a cable shifter. I also thought really hard about buying a set of chromoly shafts...
post #5772 of 8099 Old 11-06-2013, 05:10 PM
bobthetj03
I'll be interested in what you find for wiring upgrades, specifically headlight wiring.
Bob's boring build:
post #5773 of 8099 Old 11-06-2013, 06:27 PM Thread Starter
Sundowner
I'm going to run the heaviest cable I can get away with for all of my main power and ground wires...probably 2 for everything except an amplifier, which will be 4. I'm not sure what I'll need for a winch, yet, but I think 2 would actually be somewhat undersized for the amperage that most winches draw under full load. As far as headlights are concerned, I'll be replacing the entire headlight wiring harness; none of the stock wires are up to the task of powering any H4 bulb that's worth the trouble to install. I haven't sized those wires yet, either; I need to go back over my e-mails with Daniel Stern and see what he was suggesting and then decide whether I want to order components and build it all myself, or simply purchase it from him, pre-made. The decision will rest on whether or not I expect to use similar wire gauges in other locations...and I don't know that, yet. Either way, all of that information will be posted as it becomes relevant.
post #5774 of 8099 Old 11-07-2013, 06:34 PM Thread Starter
Sundowner
Today's Jeeping: Not much, on the whole. I'm still looking around for a good deal on an AntiRock, and I'm price-shopping a few other things, here and there. I did, however, lay claim to...something. More details on what that "something" might be will be posted as said details firm up. This is the part where I'm terribly mysterious...on purpose.
post #5775 of 8099 Old 11-07-2013, 08:13 PM
G Beasley
Tease , just post it up .
G Beasley is offline
annabelle , bewbs , chic-fil-a , custom , d&d , fallout , firefly , girly things , guns , half cab , hard tonneau , needs to go wheeling , overbuilt , photography , pin-up , sammiches , starwars , survival , wasteland
  LinkBacks (?)
LinkBack to this Thread: http://www.jeepforum.com/forum/f22/wasteland-survival-guide-engineering-greta-1344782/
Posted By For Type Date
glockforum | BoardReader This thread Refback 08-15-2012 10:17 AM
sears diehard batteries - forum communication | BoardReader This thread Refback 07-31-2012 08:50 AM
go there engineering bumpers austonreeves Jeep Picture Requests 4 07-29-2012 10:54 PM
What makes yours a Survival or Wilderness Jeep? fishinjeeper Jeep Picture Requests 39 07-23-2012 01:02 PM
BOV/Survival Jeeps ttony Jeep Picture Requests 2 09-30-2010 05:47 PM
33 engineering bigj1974 Jeep Picture Requests 2 02-03-2008 09:28 PM
GRETA .... then and now GRETA97 Jeep Builds 6 05-05-2004 09:41 PM
