The Wasteland Survival Guide: Engineering Greta - Page 370 - JeepForum.com
post #5536 of 8099 Old 09-27-2013, 08:31 AM
TexNVa
That is a LOT to carry, even if you have a truck to haul it in! My personal suggestion would be to keep the 9mm, the 12-gauge 870 and consider the .308 as optional. That gives you a sidearm in a common caliber, a reliable shotgun that could do pretty much whatever it's called upon to do, and rifle. If you had to pick just one, pick the shotgun; I'm very, very close to doing that, myself. I may well drop a 590A1 into some form of easy-access mount and be done with it. I know that Samuel L. Jackson suggested the AK47 as the non-substitutable solution for having to absolutely, positively kill EVERY motherf***** in the room, but in real life that honor goes to the humble 12-gauge riot gun.
Now, as for the 10mm Auto...that's not a bad round. It's not the wrist-breaking hand cannon that the Interwebz has cracked it up to be, but it's pretty decent. If you've never shot one, consider it to be a very hot .40...which - for those of you that don't know...is EXACTLY what it is. Again, I'd go a different route, myself, but it's a solid cartridge for those that want something in that genre.
Hahaha yeah it is a lot to carry. Overkill always seems to be just enough.
I'd agree on the trusty 'ol 12 gauge, however I think I'd take my 1911, but you cant really lose either way. As far as the 10mm goes, I've had a slight obsession with that cartridge since the day i shot it.
Ive thought about removing the visors, and seeing if i cant make a shotgun mount in their place, or to the sound bar.
TexNVa is offline
post #5537 of 8099 Old 09-27-2013, 10:23 AM
shortstax33
I don't like the 40 it 10mm because they are such pressure sensitive rounds. 9mm and .45 you can fire slightly defective rounds, or even rounds with a bullet slightly pressed in, and it's still pretty safe. Try that with a 40 and you could very well lose your hand. And seeing as great condition factory ammo could be hard to come by in the wasteland, you really can't beat a 9 or .45.
"And if anyone's curious, the answer is yes. I drink beer before/during all mechanical surgery on my vehicles. " - yours truly.
shortstax33 is offline
post #5538 of 8099 Old 09-27-2013, 10:31 AM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
I try to stick to current and former major military rounds. As such my possession includes chambers of .45 ACP, .22LR, 8mm Mauser, .45-70 Govt. and 5.56 NATO. (None of that .223 bull****)
I'd soon like to add a 12 gauge to the mix
My builds:
and
or follow us on
spyder6 is offline
post #5539 of 8099 Old 09-27-2013, 10:38 AM
84jeepcj7rock
I love my 45-70. Although it kicks like a mule, with quality ammo you can drop anything within 200 yards. Wish it held more rounds.
84jeepcj7rock is offline
post #5540 of 8099 Old 09-27-2013, 10:40 AM
bobthetj03
870 Express with a little tweaking to make it a zombie eater. If you're not in the military, those rounds could be a little harder to come by for us hillbillys. 223 while a bit wimpy, is still a good round and easy to come by IMO.
Bob's boring build:
White Jeep club member #2003
bobthetj03 is offline
post #5541 of 8099 Old 09-27-2013, 10:44 AM
spyder6
spyder6's Avatar
2010
Point is, if it's chambered for 5.56 it'll shoot .223. If it's chambered for .223, 5.56 will blow the action out and burn the barrel
My builds:
and
or follow us on
spyder6 is offline
post #5542 of 8099 Old 09-27-2013, 10:48 AM
bobthetj03
That makes sense. I have so much to learn!
Bob's boring build:
post #5543 of 8099 Old 09-27-2013, 11:14 AM
spyder6
spyder6's Avatar
2010
5.56 uses a slightly larger bullet, as well has heavier weight. The charge is roughly 40% more volatile than .223 as well
Actions built for 5.56 are much more substantial and use military spec components and heavy springs. As well as cold forged chromoly barrels throats and bolts.
My builds:
and
or follow us on
spyder6 is offline
post #5544 of 8099 Old 09-27-2013, 11:17 AM
mike_dippert
hodophobic
mike_dippert's Avatar
While on the subject of guns, I'd carry a Glock 21 (45acp), Glock 17 (9mm), Rem870, and an AK platform. Reliability rules the wasteland.
mike_dippert is offline
post #5545 of 8099 Old 09-27-2013, 11:18 AM
jrallen
I did exactly this with my 870. I've had the same 20 gauge since I was ten and a year or two ago I decided it was time to let it grow a bit so I went down to my lock Academy Sports+Outdoors and picked up an AR style collapsable buttstock and replacement foregrip that were designed for it's 12 gauge big brother. It took a little bit of trimming, but the stock fits perfectly and it's never been more comfortable to shoot or carry
This is the only picture I have of it on my phone... On a side note, I'm thinking about promoting the Winchester 37 12 gauge on the bottom to my so-called "truck gun" and cutting it down a bit. Thoughts?
jrallen is offline
post #5546 of 8099 Old 09-27-2013, 11:22 AM
jrallen
It might help if I add the picture
jrallen is offline
post #5547 of 8099 Old 09-27-2013, 11:37 AM
mike_dippert
hodophobic
And to squash assumptions,
The 30cal relationship is opposite of the 22. A .308 has 24% more pressure than a 7.62x51.
So you want a NATO .22cal action, and a .308 Winchester action. It's all fun and games until you blow your hand off.
post #5548 of 8099 Old 09-27-2013, 12:24 PM
spyder6
spyder6's Avatar
2010
Very good point
My builds:
and
or follow us on
spyder6 is offline
post #5549 of 8099 Old 09-27-2013, 02:23 PM
shortstax33
This isn't all accurate, at least for an AR15 platform. The difference in a .223 chambered rifle vs. a 5.56 chambered rifle is the chamber itself. Buy a .223 AR15, and put a 5.56 barrell on it, it'll fire fine, the components are all identical. The difference is in the cut of the chamber. 5.56 throats are not as tight, and the rifling engages later in the barrel. The reason for that is, if the same powder is used in a 5.56 cartridge, as a .223 cartridge with the same bullet, the 5.56 requires more powder to achieve the approximate 200fps faster muzzle velocity, thus less case capacity. .223 bullets when chambered tend to engage the rifling , while 5.56 do not. This extra resistance is not a problem with .223, but creates potentially dangerous pressure spikes, hence wider cut throat, and a few mm less rifling. If you look up pressure for both rounds they're max pressure is damn near identical because of these slight, but important chamber differences. As for bullet sizes, both calibers use the same .224 caliber projectile. As for different weights, the 5.56 NATO cartridges come in 2 different weights, XM855 is a 62 gn projectile while XM193 is a 55gn projectile.
Additional fun fact: Most commercial 5.56 barrels, and not cut properly. They're actually MUCH closer to .223 than you think, and if you get your barrel specked you'll see this. When I went through my armorer's school major name brand rifles needed to have their chambers reemed, and I saw the reason first hand. Too tight of chambers, lead to pressure spikes, and you suddenly have 5.56 cartridges losing primers into the action of your rifle. Out of spec barrels happened because chamber reamers wear down quickly, and their so expensive, manufacturers don't replace them quickly enough to garuntee spec chambers. PM me if you'd like to know company for certain that have this issue, and if you didn't spend 3k plus for your AR, it's probably out of spec. I will say this, we never saw a problem with Colt, they were all perfect . Probably because of military requirements.
Bonus fact: When firing a proper tactical bullet through ballistic jel, .223 tended to be MORE leathal than 5.56. The slower bullet expands more dramatically up close, causing more damage inside of a few hundred yards than the 5.56. The benefit to loading a cartridge to 5.56 velocities comes with super high ballistic coefficients, so they maintain velocity for longer distances, thus increasing lethal range. The XM855 does have a reasonably high BC, but who's really expecting to engage zombies at 600 yards with an AR platform.
My recomendation for a 223 cartridge: Anything with the Barnes TSX solid copper projectile. When we did ballistics tests in FBI certified jel, testing xm855, xm193, Federal tactical in 55gn and 62 gn, Hornady TAP (crappy useless horrible round, again message me for details), and Corbon TSX, the TSX Was the best, followed fairly reasonably by the Federal Tactical.
post #5550 of 8099 Old 09-27-2013, 04:12 PM
shortstax33
Wow, my spelling is awful. My apologies.
annabelle , bewbs , chic-fil-a , custom , d&d , fallout , firefly , girly things , guns , half cab , hard tonneau , needs to go wheeling , overbuilt , photography , pin-up , sammiches , starwars , survival , wasteland
  LinkBacks (?)
LinkBack to this Thread: http://www.jeepforum.com/forum/f22/wasteland-survival-guide-engineering-greta-1344782/
Posted By For Type Date
glockforum | BoardReader This thread Refback 08-15-2012 10:17 AM
sears diehard batteries - forum communication | BoardReader This thread Refback 07-31-2012 08:50 AM
go there engineering bumpers austonreeves Jeep Picture Requests 4 07-29-2012 10:54 PM
What makes yours a Survival or Wilderness Jeep? fishinjeeper Jeep Picture Requests 39 07-23-2012 01:02 PM
BOV/Survival Jeeps ttony Jeep Picture Requests 2 09-30-2010 05:47 PM
33 engineering bigj1974 Jeep Picture Requests 2 02-03-2008 09:28 PM
GRETA .... then and now GRETA97 Jeep Builds 6 05-05-2004 09:41 PM
