The Wasteland Survival Guide: Engineering Greta - Page 345 - JeepForum.com
post #5161 of 8099 Old 07-23-2013, 04:05 PM Thread Starter
Sundowner
Originally Posted by rusty762 View Post
Not sure if you have seen the 37 quart ARB fridge, its a sweet setup friend has one. Here are the dimensions, External dimensions: H16.9' x W15"' x D27.8"' It sure is nice to be in the desert for a couple of days and grab an ice cold beer. I am saving my pennies for a 50 quart, hope to purchase it by next summer. Now that my rig is drivable, I will be starting on our paperweights soon and will keep you posted on progress.
You know I like me some paperweights.
I've seen the baby ARB fridge and it's oh-so-nice...and it's just a bit too tall. Depending on what we do with the back of Annabelle's LJ we may or may not have room for something this size; naturally, that also depends on whether or not I actually have the money to buy it. Things are tight right now, so I'm going to have to go with a more basic cooler and also content myself with some hopefully-not-too-expensive projects that have been on the back burner for a long time. With that said, here's what I got started on today:
Locker Compressor Relocation
I've been meaning to move the factory lockers to a more protected location for some time, now; with the tummy tuck coming in the not-too-distant future and the lack of significant Jeep funding, I figured that this is as good a time to relocate them as any other. I've also reached the near-end of the factory air lines' service life; when I was underneath Greta a few days ago getting the control arms installed I noticed that the ends of the air lines were yet again cracked and split and basically coming apart. I cut the damaged part off and re-attached the line to the locker compressor, but I realized that I was physically running out of extra air line after having done this a couple of times in the past, already. Since it would make NO sense to run new air lines and then have to move the compressors to make room for the tummy tuck - and thereby spend more money by running more new air lines to the compressors' new locations - I thought I'd just go ahead and get started on moving the lockers themselves. Removing them isn't difficult; I started by labeling everything in Sharpie™ so that I won't get overly confused when "cut the plug off and move it somewhere else" time comes along.
Pictured: And when I say "everything" I mean "even the tray that I won't be using for much longer."
Pictured: The plugs, however, WILL get re-used.
Believe it or not, taking that second picture was a lot easier than getting the tray itself loose. Once the plugs are separated and the air lines CUT - I'll explain those capital letters momentarily - there are only four small bolts to remove in order to detach the compressor tray from the transfer case skid. Three of these bolts - they require a 13mm socket or wrench, incidentally - can be extracted easily and without issue, but the last one is in a blind spot and is covered by clipped-to-the-frame wiring; this makes it - and by proxy, the compressor tray itself - only marginally more difficult to remove than a Catholic schoolgirl's skirt. Patience is your ally, here; a few minutes of dedicated effort with the proper tool and everything will be loosened and ready for removal...which is also true of skirts.
Pictured: However, if you remove a girl's skirt and see a bunch of wires and electrical connectors, you're probably making out with a T-X. Run.
I used a couple of pieces of electrical tape to temporarily tie the hanging plugs up and out of harm's way; they won't be in this location long enough to even warrant a cable tie, as I'm going to pull them out of the wire loom and extend the wiring harness all the way to...well, wherever the compressors end up. I really haven't figured out exactly where I'm going to put them - I was considering the ABS tray but I want to save it for a second battery or the OBA system - but the one place I know they will not be located is anywhere even remotely near the factory location.
Pictured: Also, they probably won't stay on the floor.
Remember when I said that one needs to CUT the air lines from the compressors? I wasn't kidding about that; the compressor nipples are made of a plastic that can be easily broken - that's a phrase one should never have to type, incidentally - and putting any sort of significant side-load on them could snap them off. If this happens, you either have to replace the pump or find a way to thread a new nipple into it; I've read more than a few install threads where this problem occurred...and that's kind of retarded because preventing it is very, very easy. All you have to do is cut the lines apart before you remove the compressors, and then carefully cut the remaining air lines away from the nipples.
Pictured: And as a general rule, be careful around any and all nipples.
The only "gotcha" is cutting too deep and scoring the plastic; to prevent this, cut with as little pressure as possible, and then gently remove the line. It should pop right off with no resistance, but if it doesn't, you can do a little more surgery - cutting a little deeper, rather - and remove it that way. If the plastic gets scored it probably won't leak - the compressors put out almost no pressure - but there's no reason to tempt fate unless you have to do so. After I got the remainder of the rubber air line removed, I gave the compressors a quick bath and inspection.
Pictured: Ah, freshly-washed parts...perfect.
Well, not entirely perfect; I haven't painted them yet, and I also haven't figured out one other puzzling question: how do the five wires from the compressor manage to transform themselves into only three by the time they reach the connector plug? Somewhere along the way we seem to be losing the green wire, and also one of the red ones! What the f*** is that all about?
I seriously have no idea about what's going on with those wires...and I also seriously have no idea about an eventual location for the compressors themselves. Suggestions? Stay tuned.
Sundowner is offline
post #5162 of 8099 Old 07-23-2013, 06:41 PM
G Beasley
You dont want to hear it , but the ABS tray makes a great home for the pumps.
G Beasley is offline
post #5163 of 8099 Old 07-23-2013, 08:18 PM
TheDoc25
They are only tiny little baby pumps, tuck them up inside the rear fender behind the lights ????
TheDoc25 is offline
post #5164 of 8099 Old 07-24-2013, 06:19 AM Thread Starter
Sundowner
I'm a lot more receptive to that idea after you having mentioned the Ready Welder. However...
This idea has a lot of merit; they are really small, which means that they can be tucked into out-of-the-way locations...much like they were from the factory. So, it looks like Today's Jeeping will focus on finding some potential compressor locations...and also figuring out how that green wire manages to vanish. I might also build a jumper for the locker switch if I feel especially productive.
post #5165 of 8099 Old 07-24-2013, 07:19 AM
Offshoredrillin
just thinking out loud here, being as they are just small air pumps and longer lines means much more space to pressurize, will having longer air lines make them less efficient? meaning not engage a full lock. if so then wouldn't it make sense to have them closer to said lockers and the wiring be elongated? or is a moot point.
Offshoredrillin is offline
post #5166 of 8099 Old 07-24-2013, 09:07 AM Thread Starter
Sundowner
I haven't heard of that issue in particular being any kind of problem; the operating pressure in the system is very low - just a few PSI above atmospheric - so it's not hard to get them to engage, regardless of line length. However, if that information is in error, someone please correct me. My main concern is that because they are so small, I could theoretically tuck them out of the way somewhere and thus keep use of my ABS tray...but I also don't really want to reinvent the wheel if I don't need to do so. There's a time and place for being creative and custom and what-not; this may not be it, though.
post #5167 of 8099 Old 07-24-2013, 09:17 AM
rusty762
With the low pressure the stock lines require I doubt line length will come into play,not to derail but you mentioned a ready welder? I have always been interested in one, you also mentioned Beasley with the ready welder. Is there another plan for that ABS tray?
Rusty
“If I had eight hours to chop down a tree, I’d spend six sharpening my axe.”- Abraham Lincoln
Have you hugged a Firefighter today?
rusty762 is offline
post #5168 of 8099 Old 07-24-2013, 11:11 AM Thread Starter
Sundowner
You know how this thread works, man...derails happen all the time. Most of them are my fault.
I mentioned a ready welder because Beasley suggested that I go with that instead of a twin-battery setup if I was looking to do some stranded-in-the-Wasteland-welding. Until that moment I wasn't really familiar with the Ready Welder, but after examining it I really like the idea; it would be MUCH nicer than the makeshift 24v stick welding made possible by using two batteries wired together. However, even having a Ready Welder really doesn't alleviate me from the two-battery situation because I'd still like to have a second one for other purposes...and if I go that route I'll probably locate the second cell near the ABS tray. I've never liked cramming two batteries over on the passenger side, one on top of the other; I'd rather distribute the weight a bit...and if I can manage to move/alter the A/C lines a bit, I could conceivably run a pair of 65's, or something larger. So, both the twin-battery setup and the on-board air situation (A/C lines) and the engine swap are somewhat bearing on where these little compressors end up.
post #5169 of 8099 Old 07-24-2013, 12:50 PM
Jrob05
Have you considered putting the second battery in the back instead of under the hood?
I mounted my pumps on the ABS tray. Came out good and have no problems with either the front or rear pump engaging their locker. I have a pic around somewhere I'll see if I can dig it up.
Jrob05 is offline
post #5170 of 8099 Old 07-24-2013, 01:32 PM
rusty762
I mounted my ARB pump on the ABS tray after looking at multiple locations, its so small and the tray would make a great location for a second battery but the ease of running airlines to both lockers and into my dash mounted pressure gauge helped push me over the edge. A second battery is on my list also and someday a ready welder, I might just forgo the Miller 211 I was looking at and get a ready welder instead. The second battery would be easy to mount in the bed.
You have me rethinking my welder needs/purchase
Rusty
rusty762 is offline
post #5171 of 8099 Old 07-24-2013, 05:20 PM
G Beasley
I will add this to the discussion about the ready welder . I had one and it worked great with flux core wire , it really had a lot of power for what it was . With that said I sold it because it never got used , but it was a neat tool to have .
post #5172 of 8099 Old 07-24-2013, 05:34 PM Thread Starter
Sundowner
Actually, I considered putting one in each footwell, behind the seats...but I use that space for stuff all the time, so I thought that keeping them both against the firewall would be simpler and easier. Also, less expensive wire would be required.
Yeah, if you can find that, I'd be quite interested in seeing it.
Yeah, the tray is the obvious and smart location...I just hate to waste it. Real estate in the cargo bed is premium, though...which is why I was considering some out-of-the-way locations for the compressors.
So entirely not my fault. Blame Beasley.
The basic flux-core setup was what I looked at last night after you suggested it; for the size and weight, I'd rather have one available than not even if I don't really foresee the necessity.
post #5173 of 8099 Old 07-25-2013, 06:25 AM Thread Starter
Sundowner
Today's Jeeping will consist of finding replacement lines for the compressors at the very least. If I decide on a location, I'll cut the plugs off of the harness and start relocating stuff.
post #5174 of 8099 Old 07-25-2013, 09:22 AM
janesy86
What about hanging them from the strut that goes from the firewall to the grille. Ive seen it done before and it looks like a great solution.
Here ya go:
Originally Posted by Vinman View Post
I relocated mine a while ago. I didn't want to use the ABS tray so I did this:
03' Rubi: 2" BDS, 1.25" BL/MML, Hylined rollin' on 35" MTR's
janesy86 is online now
post #5175 of 8099 Old 07-25-2013, 09:34 AM
clg82
I'm loving this thread thanks for making it so entertaining!
clg82 is offline
annabelle , bewbs , chic-fil-a , custom , d&d , fallout , firefly , girly things , guns , half cab , hard tonneau , needs to go wheeling , overbuilt , photography , pin-up , sammiches , starwars , survival , wasteland
  LinkBacks (?)
LinkBack to this Thread: http://www.jeepforum.com/forum/f22/wasteland-survival-guide-engineering-greta-1344782/
Posted By For Type Date
glockforum | BoardReader This thread Refback 08-15-2012 09:17 AM
sears diehard batteries - forum communication | BoardReader This thread Refback 07-31-2012 07:50 AM
go there engineering bumpers austonreeves Jeep Picture Requests 4 07-29-2012 09:54 PM
What makes yours a Survival or Wilderness Jeep? fishinjeeper Jeep Picture Requests 39 07-23-2012 12:02 PM
BOV/Survival Jeeps ttony Jeep Picture Requests 2 09-30-2010 04:47 PM
33 engineering bigj1974 Jeep Picture Requests 2 02-03-2008 08:28 PM
GRETA .... then and now GRETA97 Jeep Builds 6 05-05-2004 08:41 PM
