The Wasteland Survival Guide: Engineering Greta - Page 336 - JeepForum.com
post #5026 of 8099 Old 07-01-2013, 09:47 AM
clintrivera
Today's Jeeping: I'm going to start cleaning up the control arms and trying to remove the old bushings...without a press. I don't think it'll go well, but I'm going to give it a shot anyway. Coverage at 11:00.
Are they rubber bushings? MAP gas torch works good for me.
clintrivera is offline
post #5027 of 8099 Old 07-01-2013, 10:28 AM Thread Starter
Sundowner
They are; I may have to go about it that way if I can't pound them out of place. I'm still looking at replacement sets of bushings, but a lot of them are urethane and require the factory metal bushing shells to be reused.
Sundowner is offline
post #5028 of 8099 Old 07-01-2013, 11:24 AM
SonicR1
No press??? Maybe go rent a ball joint press from an auto shop...
... I guess I'm gonna have to fix that too…….
2005 Wrangler X 4.0/6 speed, Dana 30/Ford 8.8--4.88--Eaton E-Lockers, 35" MT/R, Smittybilt bumpers/rockers/winch, SonicFab tire carrier, RE 3.5 springs, Zone 1.25 BL, FullTraction 3 link upper rear, RE super flex lower rears, UCF ultra high skid and lo/pro mount, brown dog mml.
SonicR1 is offline
post #5029 of 8099 Old 07-01-2013, 11:35 AM
bobthetj03
I wouldn't want poly. Are they the same size Clevites as stock on the JKS arms or proprietary to JKS?
Bob's boring build:
White Jeep club member #2003
bobthetj03 is offline
post #5030 of 8099 Old 07-01-2013, 12:20 PM Thread Starter
Sundowner
Hmm...that might be an option. I could probably rig something up with a vise, as well.
I don't know how much difference the urethane would make, but since the JKS arms have the free-rotating feature there's no reason not to keep a vibration-dampening rubber bushing in place. I'm reasonably sure that the bushings are the same as a factory bushing; they look reasonably identical to my eye.
post #5031 of 8099 Old 07-01-2013, 04:51 PM Thread Starter
Sundowner
Today's Jeeping, Updated: This whole "bushing removal" thing is way easier to type than to complete in reality. I may actually leave the good ones in place and just try to extract the ones that are obviously worn. All of the uppers look intact.
post #5032 of 8099 Old 07-01-2013, 05:03 PM
bobthetj03
This will get you one step closer to TT goodness! Oh, and hopefully solve your suspension conundrum.
Bob's boring build:
post #5033 of 8099 Old 07-01-2013, 06:22 PM Thread Starter
Sundowner
Holy f***... I've been fixated on the suspension issues; the fact that this gets me a long way towards a tummy tuck COMPLETELY escaped me! Bonus! Party!
post #5034 of 8099 Old 07-01-2013, 06:28 PM
bobthetj03
Bob's boring build:
post #5035 of 8099 Old 07-01-2013, 07:57 PM
357transam
Mmmm.... Bacon...
357transam is offline
post #5036 of 8099 Old 07-01-2013, 08:18 PM
my98tj
I usually drill holes in the rubber and cut the sleeve with a hacksaw and it just falls out.
EDIT: or if you need the sleeve, you could burn the remaining rubber out.
Can anyone tell me how the flux capacitor is used to facilitate time travel???
my98tj is offline
post #5037 of 8099 Old 07-01-2013, 08:33 PM Thread Starter
Sundowner
Originally Posted by 357transam View Post
Mmmm.... Bacon...
Yes, bacon indeed. I'll have to start looking for a scrap of aluminum and a couple of pieces of tubing.
Solid plan; I like cutting better than adding heat. I'm pretty broke right now, so I'll probably only replace the bushings that need replacing...but it's progress, either way!
post #5038 of 8099 Old 07-01-2013, 08:52 PM
Scott3140
Junior Member
Scott3140's Avatar
I read some ware about using a hole saw to drill out the bushings.
Scott3140 is offline
post #5039 of 8099 Old 07-01-2013, 10:57 PM
G Beasley
Or after you clean them up bring them over here and we can apply 40 tons of pressure to the bushings .
G Beasley is offline
post #5040 of 8099 Old 07-01-2013, 11:10 PM
SonicR1
Yeah, a press is the easiest way!!! Lots of wd40 or similar, my rubixpress bushings were a breeze and they are figure 8 shaped!
SonicR1 is offline
annabelle , bewbs , chic-fil-a , custom , d&d , fallout , firefly , girly things , guns , half cab , hard tonneau , needs to go wheeling , overbuilt , photography , pin-up , sammiches , starwars , survival , wasteland
  LinkBacks (?)
LinkBack to this Thread: http://www.jeepforum.com/forum/f22/wasteland-survival-guide-engineering-greta-1344782/
Posted By For Type Date
glockforum | BoardReader This thread Refback 08-15-2012 10:17 AM
sears diehard batteries - forum communication | BoardReader This thread Refback 07-31-2012 08:50 AM
go there engineering bumpers austonreeves Jeep Picture Requests 4 07-29-2012 10:54 PM
What makes yours a Survival or Wilderness Jeep? fishinjeeper Jeep Picture Requests 39 07-23-2012 01:02 PM
BOV/Survival Jeeps ttony Jeep Picture Requests 2 09-30-2010 05:47 PM
33 engineering bigj1974 Jeep Picture Requests 2 02-03-2008 09:28 PM
GRETA .... then and now GRETA97 Jeep Builds 6 05-05-2004 09:41 PM
