The Wasteland Survival Guide: Engineering Greta - Page 333 - JeepForum.com
post #4981 of 8099 Old 06-23-2013, 06:28 PM
G Beasley
Originally Posted by unholycowgod View Post
Stupid question time (hand raised from the dimly-lit back of the class)
Are you referring to the shaft of the shocks, or axle shafts?
I'm quite a bit interested in how this turns out - your comment about handling over pot holes got my attention. As I'm relatively new to the Jeep thing (at least with a TJ), I had just assumed it was a combination of short wheel base and "it's a Jeep, of course it rides rough." But ever since I bought mine it's had a pretty rough ride; even after changing all my shocks last year it's still pretty rough going over holes and bumps. Jarring, I think, is the best word to describe it. So this has me thinking, is it something else? Something in the axle?
I doubt its anything in the axle , if it was you would hear it . When I had stock shocks , stock springs and the stock sway bar my jeep was rough . The ride after I lifted it and added the antirock was much better , less choppy is the description I would use .
G Beasley is offline
post #4982 of 8099 Old 06-24-2013, 08:51 AM Thread Starter
Sundowner
Originally Posted by Cuder View Post
It's been over a year ago since I made this picture. I thought it was pretty damn good, so I'm posting it again. Your beard matches the tail.
The closest Chick-fil-A to me had a sign up saying they were going to be closing for remodeling. I drove by the next day after seeing the sign and the whole building was gone.
Now that's just mean; I demand that they compensate you.
Stupid question time (hand raised from the dimly-lit back of the class) Are you referring to the shaft of the shocks, or axle shafts?
Any question that helps you or someone else to better understand a concept is NOT a stupid question. I'm referring to the shocks, here; if there was an axle issue, I don't think it would manifest in a rough/jarring ride. I think I'm likely dealing with a combination of damaged shocks, heavier-than-they-should-be spring rates and stock control arm bushings that are absolutely dead. Also, the stock swaybar in the front probably isn't helping.
I'm with Beasley on this one; if you had an axle issue you would probably know it just as clearly as you knew about that pinion bearing you fixed. Ride quality issues are usually suspension-related.
Sundowner is offline
post #4983 of 8099 Old 06-24-2013, 09:14 AM
clintrivera
When your back gets better just pull a shock off and push it down and see if it seems normal.
clintrivera is offline
post #4984 of 8099 Old 06-24-2013, 10:12 AM Thread Starter
Sundowner
That's the plan.
post #4985 of 8099 Old 06-24-2013, 01:33 PM
ThatONeJeePeR
1991 XJ Cherokee
I don't know if it's the same with your rig as mine, but my stock CA bushing are in dire need of replacement, but my ride isn't rough, the zj just likes to wonder across the road not giving a hoot who's around or how drunk it makes you look. But then again, I don't have a front sway bar either
Originally Posted by misterpookie View Post
*sigh* using a controller for an FPS is like trying to jump start your car with nipple clamps: simply not the right tool for the job.
ThatONeJeePeR is offline
post #4986 of 8099 Old 06-24-2013, 03:05 PM Thread Starter
Sundowner
I don't know that mine are worn too badly, but I do know that they don't support the concept of "articulation"...so they might be having some kind of effect on the ride quality.
post #4987 of 8099 Old 06-24-2013, 06:12 PM
ThatONeJeePeR
1991 XJ Cherokee
Makes sense!! Thanks for helping "special" wheeler
post #4988 of 8099 Old 06-25-2013, 08:32 AM Thread Starter
Sundowner
Special wheeler...
Today's Jeeping: HOPEFULLY pulling a front shock, as my back is doing a bit better...but I haven't gotten an e-mail back from ARB after answering their last round of questions. I think I'll post another one to them when I have something to report about the condition of the shocks.
post #4989 of 8099 Old 06-25-2013, 08:44 AM
G Beasley
Your pile o'parts is building up over here , when are you heading over ? Take it easy on your back , don't re-gimp yourself .
post #4990 of 8099 Old 06-25-2013, 11:13 AM Thread Starter
Sundowner
I guess I need to turn some pig into barbeque and bring it your way, then.
post #4991 of 8099 Old 06-25-2013, 01:23 PM
G Beasley
I dearly love good bbq ...we are here all week . If you come over can you grab a t case in Pfafftown for me ?
post #4992 of 8099 Old 06-25-2013, 02:29 PM
unholycowgod
[quote=Sundowner;15600500]
Many thanks for the input good sirs. Once this blasted (read: costly) wedding is over with I'll see if I can scrape a few pennies together for some new springs and shocks.
My general rule of thumb is to maintain enough weaponry to start a small war, and enough ammunition to finish it. -Sundowner
unholycowgod is offline
post #4993 of 8099 Old 06-25-2013, 05:04 PM Thread Starter
Sundowner
I sure can.
She's keeping you? I thought she had better taste than that...
post #4994 of 8099 Old 06-26-2013, 08:56 AM Thread Starter
Sundowner
Today's Jeeping: I didn't get around to pulling a shock yet, but since I'm a bit more mobile - at least for today - I'm going to take a stab at it as soon as the weather cools later. Wish me luck with that.
post #4995 of 8099 Old 06-26-2013, 09:03 AM
G Beasley
Its nice out til 10 am or so then its sizzling . I guess your waiting until 7pm or so now ?
annabelle , bewbs , chic-fil-a , custom , d&d , fallout , firefly , girly things , guns , half cab , hard tonneau , needs to go wheeling , overbuilt , photography , pin-up , sammiches , starwars , survival , wasteland
  LinkBacks (?)
LinkBack to this Thread: http://www.jeepforum.com/forum/f22/wasteland-survival-guide-engineering-greta-1344782/
Posted By For Type Date
glockforum | BoardReader This thread Refback 08-15-2012 09:17 AM
sears diehard batteries - forum communication | BoardReader This thread Refback 07-31-2012 07:50 AM
go there engineering bumpers austonreeves Jeep Picture Requests 4 07-29-2012 09:54 PM
What makes yours a Survival or Wilderness Jeep? fishinjeeper Jeep Picture Requests 39 07-23-2012 12:02 PM
BOV/Survival Jeeps ttony Jeep Picture Requests 2 09-30-2010 04:47 PM
33 engineering bigj1974 Jeep Picture Requests 2 02-03-2008 08:28 PM
GRETA .... then and now GRETA97 Jeep Builds 6 05-05-2004 08:41 PM
