The Wasteland Survival Guide: Engineering Greta - Page 330 - JeepForum.com
post #4936 of 8099 Old 06-17-2013, 08:57 PM
HONDOK9
In regards to the headlights, what is H4? My stock ones suck and I want something better but I can't stomach $300 a piece for the LED conversion.
You can have cheap, and you can have quality, but you can't have both!
HONDOK9 is offline
post #4937 of 8099 Old 06-18-2013, 07:38 AM Thread Starter
Sundowner
The H4 is just a different type of bulb than the stock ones that we have; it's a twin-filament halogen that fits a slightly-different housing. Also, it makes use of a replacement harness that can supply a LOT more power to the bulbs themselves; the stock wiring to the headlights is pretty skimpy so the H4 setups replace it with some direct-from-battery wiring and a switched relay that can power some high-output bulbs. Overall, it's a clean, easy and simple way to upgrade - upgrayedd - your stock headlights; the bad news is that the conversion will still cost you somewhere around $200 per unit, or slightly less if you build your own harness. Wiring ain't cheap.
Sundowner is offline
post #4938 of 8099 Old 06-18-2013, 02:14 PM
HONDOK9
Wow! Thank you for the reply. I'm gonna look those up. Great work on the hood and hinges and stuff. Greta is looking good. I don't comment much but I'm always here reading (since day one). Awesome thread man. Keep it up!
HONDOK9 is offline
post #4939 of 8099 Old 06-18-2013, 08:09 PM Thread Starter
Sundowner
No problem, man... I'm glad to help, and I certainly appreciate the compliments on Greta's latest updates. I hope you keep reading, and enjoying.
post #4940 of 8099 Old 06-19-2013, 04:32 AM
Offshoredrillin
There is an h4 wiring set up that comes w relay, plugs and everything needed for just about 100-130ish bucks. I did it and love it, was the first mod i did on my daughters 05 rubicon. It will make reg lights brighter as well.
Offshoredrillin is offline
post #4941 of 8099 Old 06-19-2013, 06:59 AM
redrelyt12
You have more info on this?
I never make the same mistake twice - it's more like three or four times.
Build - http://www.jeepforum.com/forum/f22/unlimicon-build-1477723/
redrelyt12 is offline
post #4942 of 8099 Old 06-19-2013, 08:11 AM
Imped
Imped's Avatar
http://www.danielsternlighting.com/
I built a harness using his components, run OSRAM 60/65w bulbs, and Hella housings. I have ridiculously adequate headlights.
OlllllllO
IndyORV
Imped is offline
post #4943 of 8099 Old 06-19-2013, 08:33 AM
Steelo805
I forget what brand my harness for the xj is but it was only about $35. I don't know if there's a difference.. The whole swap only cost me about $75. Ill do some research when I'm on the computer and see what I can find for TJs.
Steelo805 is offline
post #4944 of 8099 Old 06-19-2013, 08:38 AM
clintrivera
There really isn't much to the harness. You can cut the plug off your headlights, wire it to a $5 relay and get a $8 H4 plug pigtail and you are in business. Get some decent size wire and a fuse or keep it factory looking and run it through an unused spot in the factory under hood fuse box.
clintrivera is offline
post #4945 of 8099 Old 06-19-2013, 11:16 AM Thread Starter
Sundowner
That's the plan on my end; he's been very helpful. I'm going to opt for the Cibie housings, but aside from that it sounds like we'll have similar setups.
Let us know what you find!
I think it's really a matter of the sorry-a** factory wiring, more than anything else; the factory stuff just can't supply a high-wattage bulb. If you can find some decent hardware to go with adequately-sized wire you can assemble a harness for not-a-great-amount. I was planning on getting my components from Stern, mostly because I've heard exactly zero complaints about them and because I'd like to give the guy a bit of business for having helped me out with innumerable questions. I may buy housings from him as well, depending on what I find when it's time to purchase them.
post #4946 of 8099 Old 06-19-2013, 04:01 PM
Offshoredrillin
this is what i got, took more time to open the box than to install it. http://www.amazon.com/Putco-230004HW...3+jeep+rubicon
post #4947 of 8099 Old 06-19-2013, 05:33 PM
ThatONeJeePeR
1991 XJ Cherokee
How long have you run this? Any issues? Some of those reviews kinda turned me a bit
Originally Posted by misterpookie View Post
*sigh* using a controller for an FPS is like trying to jump start your car with nipple clamps: simply not the right tool for the job.
ThatONeJeePeR is offline
post #4948 of 8099 Old 06-19-2013, 05:47 PM
Offshoredrillin
Been on mine over a year no issues, on my daughters since november and no issues at all. When reading reviews be open minded, i read them too before i posted the link, the one guy "did this stuff for a living" and the next two were railing on chinese relays.
Before i did the upgrade with my new kc lights i melted a harness and plugs, new front harness was 360 bucks. Now no worries at all.
post #4949 of 8099 Old 06-19-2013, 10:10 PM
Steelo805
Same harness I have. I've had to replace one relay but no complaints. If you replace the relays with ones that fit its like 25. However you can just buy $5 relays and transfer the wires if you're savvy
post #4950 of 8099 Old 06-20-2013, 02:44 PM Thread Starter
Sundowner
Today's Jeeping: No response yet from OME, although they've had my e-mail for...well, a couple of days, now. I guess I'm going to have to try and manage it with a phone call.
annabelle , bewbs , chic-fil-a , custom , d&d , fallout , firefly , girly things , guns , half cab , hard tonneau , needs to go wheeling , overbuilt , photography , pin-up , sammiches , starwars , survival , wasteland
  LinkBacks (?)
LinkBack to this Thread: http://www.jeepforum.com/forum/f22/wasteland-survival-guide-engineering-greta-1344782/
Posted By For Type Date
glockforum | BoardReader This thread Refback 08-15-2012 09:17 AM
sears diehard batteries - forum communication | BoardReader This thread Refback 07-31-2012 07:50 AM
go there engineering bumpers austonreeves Jeep Picture Requests 4 07-29-2012 09:54 PM
What makes yours a Survival or Wilderness Jeep? fishinjeeper Jeep Picture Requests 39 07-23-2012 12:02 PM
BOV/Survival Jeeps ttony Jeep Picture Requests 2 09-30-2010 04:47 PM
33 engineering bigj1974 Jeep Picture Requests 2 02-03-2008 08:28 PM
GRETA .... then and now GRETA97 Jeep Builds 6 05-05-2004 08:41 PM
