The Wasteland Survival Guide: Engineering Greta - Page 327 - JeepForum.com
post #4891 of 8099 Old 06-13-2013, 10:46 AM
Hendrix
TJOTY 2013
Hendrix's Avatar
Originally Posted by REDLYNER
It really sounds like some beefed up JK axles would be your best option. Cost efficient, strong, wide, light'sh. Easy to find, cheap to mod.
That being said, I listed my built TJ Rubi axle for sale this morning that I know would handle anything you threw at it. Just saying
Yes and yes. JK axles or your TJ rubi axle would keep him happily cruising in the wasteland.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #4892 of 8099 Old 06-13-2013, 10:57 AM
clintrivera
Honestly, the axle he has plus some alloys (maybe a regear) would be perfect for him. Maybe an ARB or a front Rubi locker in the back if he is feeling paranoid.
But it sounds like he really has his mind set on building an axle.
Building axles, body work, and bleeding brakes are personally my least favorite things, but to each his own.
clintrivera is offline
post #4893 of 8099 Old 06-13-2013, 11:57 AM
olysteve
I have never understood why people have such an issue with bleeding brakes. I've done numerous ones, mostly by myself, and not had issues.
olysteve is offline
post #4894 of 8099 Old 06-13-2013, 12:10 PM
clintrivera
My issue is that its messy, tedious, and not a particularly satisfying thing to accomplish.
post #4895 of 8099 Old 06-13-2013, 12:26 PM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
I've never had a mess with it. I use a brake bleeder kit. Easy as pie.
My builds:
and
or follow us on
spyder6 is offline
post #4896 of 8099 Old 06-13-2013, 12:44 PM
clintrivera
The only time I need to bleed brakes is when I replace lines or calipers and such. I'm not aware of any technique that stops brake fluid from getting everywhere once you loosen a line. I've even tried the rubber seal over the master cylinder cap, and while that helps, there is still a mess.
I've toyed with getting the Motive brake bleeder but I don't bleed brakes enough to justify it. For now I just use a vacuum bleeder.
post #4897 of 8099 Old 06-13-2013, 04:12 PM Thread Starter
Sundowner
Originally Posted by REDLYNER View Post
It really sounds like some beefed up JK axles would be your best option. Cost efficient, strong, wide, light'sh. Easy to find, cheap to mod. That being said, I listed my built TJ Rubi axle for sale this morning that I know would handle anything you threw at it. Just saying
The 100% smartest plan would be to regear my 44's, throw some chromoly shafts in them, and then truss/sleeve them...in that exact order. That's actually what I planned on doing for a long, long time. When I started thinking about alternate solutions the JK44's came up; swapping a set of those in would also be a 100% smart solution...especially if the set in question should happen to be the Pumpkin-built pair that someone really should be buying, even if that someone isn't me. However...
There's also this part, and it's very true; I honestly want to try my hand at building one...mostly just for the sake of learning about axles, differentials, lockers, ring and pinion setup, etc. It's basically a learning opportunity for me, and as such I'm willing to do things in a not-quite-100%-smart fashion. That's the same reason that I'm looking for a high-mileage engine; I don't have to rebuild it...I get to.
Sundowner is offline
post #4898 of 8099 Old 06-13-2013, 07:33 PM Thread Starter
Sundowner
So, an interesting thing happened, this evening...
Pictured: Tonight's Jeeping.
This is the view from the driver's seat, zoomed in just a bit for clarity...and the light is every bit as glaring as the photo makes it out to be. I'm thinking that I can either block the light at the source - i.e. sealing the housing, somehow - or put some sort of opaque/diffusing barrier in the way. The indirect glow under the hood doesn't bother me, but glare off the back of that bulb is not kosher at all.
post #4899 of 8099 Old 06-13-2013, 08:00 PM
spyder6
spyder6's Avatar
2010
Mine broke within 10k miles and I never fixed it
My builds:
and
or follow us on
spyder6 is offline
post #4900 of 8099 Old 06-13-2013, 08:05 PM Thread Starter
Sundowner
Your headlight?
post #4901 of 8099 Old 06-13-2013, 08:16 PM
spyder6
spyder6's Avatar
2010
Oh I was looking at the thumb nail, I thought it was the under hood light. Carry on
My builds:
and
or follow us on
spyder6 is offline
post #4902 of 8099 Old 06-14-2013, 04:19 AM
Offshoredrillin
Just take some of your black paint and paint the back of the bulb.
Offshoredrillin is offline
post #4903 of 8099 Old 06-14-2013, 05:56 AM
Danno6102
My PSC did that as well. However, I don't think near as bad. Hard to tell from a pic. I notice mine on the inside of the roof. I've just gotten used to it.
"Evolution through carnage, the Jeep will keep what it needs."
Danno6102 is offline
post #4904 of 8099 Old 06-14-2013, 10:08 AM Thread Starter
Sundowner
I can has burned paint.
At the right angle it's pretty bright...and I just happen to sit at the exact right angle.
post #4905 of 8099 Old 06-14-2013, 10:15 AM
spyder6
spyder6's Avatar
2010
Time to buy my trucklites from me
My builds:
and
or follow us on
spyder6 is offline
annabelle , bewbs , chic-fil-a , custom , d&d , fallout , firefly , girly things , guns , half cab , hard tonneau , needs to go wheeling , overbuilt , photography , pin-up , sammiches , starwars , survival , wasteland
  LinkBacks (?)
LinkBack to this Thread: http://www.jeepforum.com/forum/f22/wasteland-survival-guide-engineering-greta-1344782/
Posted By For Type Date
glockforum | BoardReader This thread Refback 08-15-2012 09:17 AM
sears diehard batteries - forum communication | BoardReader This thread Refback 07-31-2012 07:50 AM
go there engineering bumpers austonreeves Jeep Picture Requests 4 07-29-2012 09:54 PM
What makes yours a Survival or Wilderness Jeep? fishinjeeper Jeep Picture Requests 39 07-23-2012 12:02 PM
BOV/Survival Jeeps ttony Jeep Picture Requests 2 09-30-2010 04:47 PM
33 engineering bigj1974 Jeep Picture Requests 2 02-03-2008 08:28 PM
GRETA .... then and now GRETA97 Jeep Builds 6 05-05-2004 08:41 PM
