The Wasteland Survival Guide: Engineering Greta - Page 306 - JeepForum.com
post #4576 of 8099 Old 05-13-2013, 11:20 PM
ashland82391
Out of money yet...Yup!
ashland82391's Avatar
I forgot what the Jeep looks like..... :-P
ashland82391 is offline
post #4577 of 8099 Old 05-13-2013, 11:26 PM
ThatONeJeePeR
1991 XJ Cherokee
From what I can recall, it has 4 wheels. I think it might be a crazy *** purple color? That's all I remember
Originally Posted by misterpookie View Post
*sigh* using a controller for an FPS is like trying to jump start your car with nipple clamps: simply not the right tool for the job.
ThatONeJeePeR is offline
post #4578 of 8099 Old 05-13-2013, 11:44 PM
jbjorgen
jbjorgen's Avatar
Yes! I distinctly remember his male partner Anderson (the one with the nice pecs) working on a purple jeep.
jbjorgen is offline
post #4579 of 8099 Old 05-13-2013, 11:53 PM
TheDoc25
Ok I have a question seeing as the brightest lot are checking in here, does anybody know what this plug is for on my 04 TJ it has a straight 3 pin black plug with a (green, bk/yl, blk wire), there is one on each side next to the headlights. Its a very short tail that would probably only just reach the headlight itself.
Only thing I can think of or have seen in the manual was headlight adjusters, but I have never seen those in a Wrangler.
Thanks,
Nick.
TheDoc25 is offline
post #4580 of 8099 Old 05-14-2013, 04:28 AM
LifeProof
SEMPER FIDELIS
LifeProof's Avatar
what jeep? isnt this the off topic disscusion thread?
SEMPER FI
LifeProof is offline
post #4581 of 8099 Old 05-14-2013, 05:51 AM
ashland82391
The least he could do is throw a few more boobies in this build :-P
post #4582 of 8099 Old 05-14-2013, 07:00 AM
Imped
Imped's Avatar
Would putting a v8 not cause the tranny to be in a different position. And also wouldn't it be a completely different tranny needing a custom crossmember??
Yes and yes.....my statement stands.
OlllllllO
IndyORV
Imped is offline
post #4583 of 8099 Old 05-14-2013, 07:18 AM
redrelyt12
Thanks,
Nick.
Pictures Help
I never make the same mistake twice - it's more like three or four times.
Build - http://www.jeepforum.com/forum/f22/unlimicon-build-1477723/
redrelyt12 is offline
post #4584 of 8099 Old 05-14-2013, 09:55 AM Thread Starter
Sundowner
Today's Jeeping: Catching up on my own thread. To address a few things in no particular order...
- The engine really doesn't have much to do with the transfer case skid. Yes, it can have an impact but as others have said; the solution lies in designing and building a skid with my particular circumstances in mind. The fact that the engine is being swapped is one of the reasons I decided against the otherwise-very-smart Savvy MUA; once I get the swap taken care of I can re-engineer or rebuild whatever skid I've already fabricated. No problem.
- The shirt design seems to be either: large graphic front/small graphic upper back or small graphic front/large graphic back. I like them both. I'm also looking for women's shirts, and yes: Imped noticed that this is the highest-viewed active build thread. I think we all deserve a beer and a sammich.
- Yeah, this thread needs some more metal-cutting and boobs; I've been working and out of town so I haven't even had time to mow my foot-tall grass, yet. However, you can rest assured that if nothing else, there is imminent boobage inbound.
Sundowner is offline
post #4585 of 8099 Old 05-14-2013, 10:02 AM
rusty762
I love boobies, boobs and guns and jeeps. And Bacon...
Rusty
If I had eight hours to chop down a tree, Id spend six sharpening my axe.- Abraham Lincoln
Have you hugged a Firefighter today?
rusty762 is offline
post #4586 of 8099 Old 05-14-2013, 10:08 AM
Steelo805
Steelo805 is offline
post #4587 of 8099 Old 05-14-2013, 10:55 AM
redrelyt12
I Say Small Design On Front, Larger On Rear
post #4588 of 8099 Old 05-14-2013, 11:13 AM
MadLefty
Hey Sundowner, is your name in reference to Sundowners Syndrome?
Also, I seen to be at a stalling point with my tj. I have 3.5 inch suspension lift with 33" tires and 3.07 d30 and d35, so clearly I need to either regear/axle upgrade along with steering and brake upgrades. So my question is this, if you were to do it all again would you do it in the same order?
And any advice on my predicament? Currently I have a budget of $1800
MadLefty is offline
post #4589 of 8099 Old 05-14-2013, 12:34 PM Thread Starter
Sundowner
You and me both.
That's kind of where I'm at with it, right now.
First of all: no, that's not the name reference.
Regarding your predicament: if I had it all to do over again, I'd chase gears, joints and clearance, all other things being equal. Those three things will help you IMMENSELY because they will let you comfortably drive at the speed the terrain requires; that measure of control is the majority part of preventing breakage. Basic upgrades to brakes and steering aren't expensive, so those need to happen; the gears can be done at home, too... just take your time. My advice is to upgrade your brakes with some good pads and rotors and to beef your tie rod, and then look at a regear; use what's left for tummy tuck parts or decent joints... and if you've already got any of that covered, please accept my apologies: I can't read profiles when posting from my phone.
post #4590 of 8099 Old 05-14-2013, 12:59 PM
unholycowgod
An Australian underclass transient worker? They seem to have mastered the epic beardness thing at least.
https://en.wikipedia.org/wiki/Swagman
I always wondered about the name though. It doesn't have an obvious reference, that I'm aware of, relating to any of the typical subjects of discourse: beer, boobs, Fallout, etc.
My general rule of thumb is to maintain enough weaponry to start a small war, and enough ammunition to finish it. -Sundowner
unholycowgod is offline
annabelle , bewbs , chic-fil-a , custom , d&d , fallout , firefly , girly things , guns , half cab , hard tonneau , needs to go wheeling , overbuilt , photography , pin-up , sammiches , starwars , survival , wasteland
  LinkBacks (?)
LinkBack to this Thread: http://www.jeepforum.com/forum/f22/wasteland-survival-guide-engineering-greta-1344782/
Posted By For Type Date
glockforum | BoardReader This thread Refback 08-15-2012 10:17 AM
sears diehard batteries - forum communication | BoardReader This thread Refback 07-31-2012 08:50 AM
go there engineering bumpers austonreeves Jeep Picture Requests 4 07-29-2012 10:54 PM
What makes yours a Survival or Wilderness Jeep? fishinjeeper Jeep Picture Requests 39 07-23-2012 01:02 PM
BOV/Survival Jeeps ttony Jeep Picture Requests 2 09-30-2010 05:47 PM
33 engineering bigj1974 Jeep Picture Requests 2 02-03-2008 09:28 PM
GRETA .... then and now GRETA97 Jeep Builds 6 05-05-2004 09:41 PM
