The Wasteland Survival Guide: Engineering Greta - Page 289 - JeepForum.com
post #4321 of 8099 Old 04-11-2013, 01:28 PM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
http://www.ruffstuffspecialties.com/catalog/FIXIT.html
My builds:
and
or follow us on
spyder6 is offline
post #4322 of 8099 Old 04-11-2013, 01:43 PM
Kodiak17
Just something to consider......
Hmmm... I might actually try that.
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline
post #4323 of 8099 Old 04-11-2013, 02:40 PM Thread Starter
Sundowner
Instead of replacing the mounts, add weld washers. 2" dia x 3/16" thick with a 9/16" center hole. Bolt them up, weld them on and trim the remainder of the thin stock mount off. You've now got >1/4" thick contact surface and a little extra clearance without having to cut the stock mounts off. If you really do end up trashing them, then you're only out a few washers. I did that to my stock front LCA frame mounts and ran them that way for quite some time. They held up great.
That's not a bad idea; I hadn't considered reinforcing the stock mount, but it's a pretty sensible notion. Extra clearance is always good...if I'd had another 1/8" or so under the mounts I wouldn't have hit them at all.
There you go, being useful again...
Just when we think we have something figured out...
My replacement plan was to swap in the new control arms and then get everything dialed in nicely - since they're going to be adjustable, I'm almost sure to get one of the lengths adjusted incorrectly - and after having done so, replace two mounts at a time. I can unbolt an arm from the frame side, cut the mount off, bolt the new mount to the control arm that's already length-adjusted, tack the mount in place exactly where it needs to be, and then remove the control arm and burn in the weld. Naturally, if there's a way to screw up what seems to be a screw-proof system, I'll find it...but it's a sound strategy in theory.
Sundowner is offline
post #4324 of 8099 Old 04-12-2013, 10:14 AM Thread Starter
Sundowner
Today's Jeeping: Now, what could I possibly have ordered? Hmmm...
post #4325 of 8099 Old 04-12-2013, 10:17 AM
redrelyt12
Paint to match the hard deck or what?
I never make the same mistake twice - it's more like three or four times.
Build - http://www.jeepforum.com/forum/f22/unlimicon-build-1477723/
redrelyt12 is offline
post #4326 of 8099 Old 04-12-2013, 10:19 AM
The_Eng
There better be pictures of Annabelle installing said louvers....
2002 WJ Limited - Stock except for some 245/65R17's
1998 TJ Sport - 285/70R17 on JK Moabs
Colorado Jeep Club Member #272
The_Eng is offline
post #4327 of 8099 Old 04-12-2013, 10:23 AM
bobthetj03
Oh naw ya dinnint! Your black to white ratio is reaching equivalency! And I mean that in a cosmetic way!
Bob's boring build:
White Jeep club member #2003
bobthetj03 is offline
post #4328 of 8099 Old 04-12-2013, 10:23 AM Thread Starter
Sundowner
The satin black will be close enough for now; remember that I'm going to refinish the deck and that I've not been entirely happy with how the paint has held up. You're on the right page with the eventual plan, though; Bonus Points awarded for Thinking Ahead.
Remember how I said that if people were patient they'd get to see her poking holes in sheet metal...?
Oh yes I did...and I'm still going to do the hinges, too. In fact, I might do those while I have the hood detached for surgery. Greta will be down for a day or three. Hmmm...
post #4329 of 8099 Old 04-12-2013, 12:01 PM
YjStrangler92
Atleast your gettin stuff done. I wish I could say the same.
YjStrangler92 is offline
post #4330 of 8099 Old 04-12-2013, 03:23 PM
rusty762
Nice man, I like the pattern on that louver.
Rusty
If I had eight hours to chop down a tree, Id spend six sharpening my axe.- Abraham Lincoln
Have you hugged a Firefighter today?
rusty762 is offline
post #4331 of 8099 Old 04-12-2013, 03:45 PM
YjStrangler92
Does anyone in the wasteland know what tj fuel filler neck has the same size hose as a yj? Or are they all the same. I had one person say tanks are exactly the same, and another say fuel hose on filler neck to tank different size between tj and yj. The reason im asking is for my quarter panel armor, I want to relocate fuel fill higher, before I buy quarters with tj spot and shape. I appreciate any help. Oh, sorry for hi-jacking sundowner.back to your regularly scheduled program allready in progress.................................
post #4332 of 8099 Old 04-12-2013, 04:29 PM
Bennettj13
Just cut your existing one and splice in a piece of soft gas line from autozone using the metal hose as a splice bit. Some hose clamps and you are done. Be careful changing the angle of the dangle, your gas will start to back up on you.
::SELLING HALF OF MY JEEP::
Bennettj13 is offline
post #4333 of 8099 Old 04-12-2013, 04:49 PM
YjStrangler92
Cut what? Is the tj filler hose the same size as the yj hose? Im not asking shape or length, just diameter.
post #4334 of 8099 Old 04-12-2013, 05:40 PM Thread Starter
Sundowner
It's slow progress, since I haven't yet become Independently Wealthy.
I do too. It's the most pleasing of the panels that I found, and it's also the one that DOESN'T HAVE A BIG, STUPID LOGO CUT INTO IT.
post #4335 of 8099 Old 04-12-2013, 06:00 PM
Bennettj13
So you are trying to use a TJ fuel filler and attach it to a YJ tank?
You clearly haven't pulled it out and looked at it. It's like a cup, with a long metal neck, and then there is rubber hose that increases in size and attaches to the tank. So you cut off the neck/pipe portion and use it as a splice so you can use hose clamps on it without collapsing the new soft hose sections you put in. Then you can make it as long as you want.
I would assume it's the same size. It's about an inch if I remember right. Why? I have used a TJ filler with a YJ bezel before, and I have chopped my TJ filler neck to hell and back to make it work with the TNT stretch corners I ran. The bezel bolt pattern will match up IIRC. I have changed the routing all around making it larger and bigger just like I mentioned to you earlier. You don't have to be so smug. I gave you a solution. Use it or don't. Sorry for trying to help.
annabelle , bewbs , chic-fil-a , custom , d&d , fallout , firefly , girly things , guns , half cab , hard tonneau , needs to go wheeling , overbuilt , photography , pin-up , sammiches , starwars , survival , wasteland
  LinkBacks (?)
LinkBack to this Thread: http://www.jeepforum.com/forum/f22/wasteland-survival-guide-engineering-greta-1344782/
Posted By For Type Date
glockforum | BoardReader This thread Refback 08-15-2012 09:17 AM
sears diehard batteries - forum communication | BoardReader This thread Refback 07-31-2012 07:50 AM
go there engineering bumpers austonreeves Jeep Picture Requests 4 07-29-2012 09:54 PM
What makes yours a Survival or Wilderness Jeep? fishinjeeper Jeep Picture Requests 39 07-23-2012 12:02 PM
BOV/Survival Jeeps ttony Jeep Picture Requests 2 09-30-2010 04:47 PM
33 engineering bigj1974 Jeep Picture Requests 2 02-03-2008 08:28 PM
GRETA .... then and now GRETA97 Jeep Builds 6 05-05-2004 08:41 PM
