The Wasteland Survival Guide: Engineering Greta - Page 282 - JeepForum.com
post #4216 of 8099 Old 04-02-2013, 05:41 PM
357transam
I don't know much about cryo treating, but I do know a lot of guys would do it in their built SHO's. Make the stock trans capable of 350 plus with hard shifting. I imagine 8000 rpm shifts would be somewhere around the same amount of forces as lower toms with loads of torque. I doubt you will do much speed shifting in Greta, but who am I to say?
357transam is offline
post #4217 of 8099 Old 04-02-2013, 06:08 PM Thread Starter
Sundowner
After thinking on the transmission issue for most of the day, I've decided that I'm just not going to worry about it for now because it really isn't an issue, yet. I think I'd be better served to see how the 3550 actually holds up behind a relatively stock-ish LS, and then make some decisions with solid information at my disposal. I've got more pressing issues to consider at current.
Sundowner is offline
post #4218 of 8099 Old 04-02-2013, 06:12 PM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
I can tell you the amount of work getting an lsx and a nv4550 in is unreasonable. To get AC, you need to put a huge notch in the frame and you can kiss any hopes of a low profile skid goodbye
An automatic is a lot easier and cheaper. A lot.
If that's no good then maybe you should look into stroking your engine out. Reliable power
My builds:
and
or follow us on
spyder6 is offline
post #4219 of 8099 Old 04-02-2013, 06:17 PM
bobthetj03
So what is Greta's next mod going to be in the near future?
Bob's boring build:
White Jeep club member #2003
bobthetj03 is offline
post #4220 of 8099 Old 04-02-2013, 06:55 PM Thread Starter
Sundowner
Oh, I agree on the 4500 issues; there's no clearance to be had and I might as abandon all hope of a flat belly. I really dislike driving automatic transmissions, so that would be an absolute last resort. Stroking the 4.0 would either necessitate a ridiculous amount of downtime or the purchase of a second block, and in either case I'd still be left with the same weight in the front. That's why I gravitated towards an LS build in the first place; I can pick away at it over time and get something better than the stock powerplant for my efforts. It's probably six one way and half a dozen the other, though.
Control arms are the next "let's do a huge write-up" item, but before those happen I'll be doing a louvered hood panel...because there seem to be two MAJOR dents in the hood, now, for reasons unknown to me. I have no idea how they got there, but they showed up at some point during the night a few days ago; my guess is that someone decided to try to dent my hood while I was parked at the local Sprawl-Mart, and I noticed them the next morning. They're VERY visible; you can see them from fifty feet away. Needless to say, I wasn't happy. Instead of having them fixed I'm just going to remove them entirely and replace the affected area with a Hyline Offroad panel.
Anyway...control arms are the next big thing, but I'll be taking pictures of Annabelle doing sheet metal work, first.
post #4221 of 8099 Old 04-02-2013, 07:05 PM
G Beasley
Damn mouth breathers . You need a pitbull with cana-syphil-aids to tie under it when you leave it .
What flavor are you leaning towards ?
G Beasley is offline
post #4222 of 8099 Old 04-02-2013, 07:16 PM Thread Starter
Sundowner
Damn mouth breathers.
That's exactly what it was, I think. There was a group of guys in jacked-up mudwagons - and when I say that, I mean that they had 8" lift blocks under their rear springs and mud covering the entirety of their vehicles - at the corner of the parking lot; I could see some of that crowd wandering over and trying to put a dent in the sheet metal just because they fall between "Toaster" and "Grapefruit" on the Intelligence and Ethics Scale. I hate to be judgmental in that way, but that's truly what I think happened. The dents weren't there before and they were visibly there the next day when I walked out of the house; I wasn't paying attention when I left the store and I don't live in a place that gets visitors at night.
Pumpkin.
post #4223 of 8099 Old 04-02-2013, 07:20 PM
G Beasley
I do not like it when people mess with my junk ...
Pumpkin.
Have you been talking to Kimbo ?
post #4224 of 8099 Old 04-02-2013, 07:36 PM
Yarz
Do you need overdrive? I'm sure you've read about the SM465.. VERY beefy transmission, with a DEEP first. Most of the times I use first, I'm goofing around.
It came in heavy duty Chevy's and should bolt right to the LS (they use the same bellhousing pattern as the 350 and 4.3, right?) and hold up to almost anything
But, you don't get OD.. And they shift like a truck; long, slow throw between gears
Looking forward to this
"Build a man a fire, and he'll be warm for a day. Set a man on fire, and he'll be warm for the rest of his life."
1990 White YJ TBI350, SM465, NP231, SOA, RE 1.5" SOA springs, Ford 8.8, D30, 4.10's, JBConversions SYE, XJ shaft, Bilstein 5150s, jb4x4 steering, MORE SS brakelines, 35x12.50 15 MT's, '95 YJ Brake Booster, '78 Grand Marquis MC, ZJ Prop. Valve
Yarz is offline
post #4225 of 8099 Old 04-02-2013, 08:29 PM Thread Starter
Sundowner
Nope! But they really will be pumpkin-flavored. Seriously. I wouldn't lie to you about this.
Originally Posted by Yarz View Post
Do you need overdrive? I'm sure you've read about the SM465.. VERY beefy transmission, with a DEEP first. Most of the times I use first, I'm goofing around. It came in heavy duty Chevy's and should bolt right to the LS (they use the same bellhousing pattern as the 350 and 4.3, right?) and hold up to almost anything. But, you don't get OD.. And they shift like a truck; long, slow throw between gears
Lots of highway miles mean that overdrive is a necessity. With that said, I'm familiar with the four-speeds and they're great transmissions...but I don't think that they'll work for what I need, here.
I think it'll be worth seeing.
post #4226 of 8099 Old 04-02-2013, 09:07 PM
spyder6
spyder6's Avatar
2010
i dont know if you've considered this option, and it might be a heathens statement - but it seems like the easiest most reliable option for getting as close to to perfect weight distribution as you can might be to find something with a 3.6L and manual transmission
just a thought
My builds:
and
or follow us on
spyder6 is offline
post #4227 of 8099 Old 04-02-2013, 10:21 PM
bobthetj03
just a thought
Now, that's thinking outside the box!
Bob's boring build:
post #4228 of 8099 Old 04-02-2013, 11:01 PM Thread Starter
Sundowner
No, that's nothing heathen-ish. I don't know what it would take to procure one or what I would have to do to make it work, but that's not an insurmountable obstacle.
And it's one of the biggest reasons that I enjoy this thread; there are a lot of good, non-linear suggestions and innovative ideas that get thrown about. With that being said, the simplest suggestion is this: use the factory transmission like I originally planned, and see how it goes. It fits, it's rated for 300 lb-ft. at 7,200 lbs. GVW, it doesn't weigh much and it has a 4-ish first gear and overdrive. I know that if I started making an LS into a more healthy engine I'd end up breaking it, but I'm really not going that route; I'd rather shoot for 300-ish torque/horsepower and the best fuel economy I can get. I'm going to give Novak a call tomorrow and pick their brains about how survivable the 3550 really is when behind a mild/stock LS; although the website states that V8 conversions with the 3550 are done with "excellent success" I'd like to see what they think of the idea when given my specific criteria. Honestly, I think that it can work and work reasonably well...but we'll see. I think I'm just over-complicating things by assuming the necessity of a swap.
post #4229 of 8099 Old 04-03-2013, 06:23 AM
redrelyt12
I was going to suggest looking into the NSG370 from my model year, but after some research, it's rated for less torque than the 3550... Didn't really think they would go backwards with the tranny...
I never make the same mistake twice - it's more like three or four times.
Build - http://www.jeepforum.com/forum/f22/unlimicon-build-1477723/
redrelyt12 is offline
post #4230 of 8099 Old 04-03-2013, 06:40 AM
spyder6
spyder6's Avatar
2010
It's severely underrated IMO, its a really solid unit.
When I suggested a 3.6 and manual, I didn't mean stealing the driveline, I meant moving into a jeep that came with one from the factory.
A whole new slew of challenges and outside the box thoughts on that one.
My builds:
and
or follow us on
spyder6 is offline
annabelle , bewbs , chic-fil-a , custom , d&d , fallout , firefly , girly things , guns , half cab , hard tonneau , needs to go wheeling , overbuilt , photography , pin-up , sammiches , starwars , survival , wasteland
  LinkBacks (?)
LinkBack to this Thread: http://www.jeepforum.com/forum/f22/wasteland-survival-guide-engineering-greta-1344782/
Posted By For Type Date
glockforum | BoardReader This thread Refback 08-15-2012 10:17 AM
sears diehard batteries - forum communication | BoardReader This thread Refback 07-31-2012 08:50 AM
go there engineering bumpers austonreeves Jeep Picture Requests 4 07-29-2012 10:54 PM
What makes yours a Survival or Wilderness Jeep? fishinjeeper Jeep Picture Requests 39 07-23-2012 01:02 PM
BOV/Survival Jeeps ttony Jeep Picture Requests 2 09-30-2010 05:47 PM
33 engineering bigj1974 Jeep Picture Requests 2 02-03-2008 09:28 PM
GRETA .... then and now GRETA97 Jeep Builds 6 05-05-2004 09:41 PM
