The Wasteland Survival Guide: Engineering Greta - Page 233 - JeepForum.com
post #3481 of 8099 Old 02-23-2013, 06:41 PM
mp15dc
1989 XJ Cherokee
Originally Posted by Sundowner;
[B
Edit: [/B]I could probably run an external regulator instead of a regulated fuel rail...that would likely be simpler.
Like a fuel filter from a C5 Corvette. It has a built in regulator.
Wix 33737.
mp15dc is offline
post #3482 of 8099 Old 02-23-2013, 07:37 PM
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
I've put a little thought into the fuel tank myself. Beasley has a good a point, even in my rock strewn world in the Sierra's my Savvy skid works good and my tank scraping is a minimal issue (although I scrape it A LOT).
What I have always thought is that there has got to be another tank, out of another vehicle (maybe even a dodge with a common fuel pump) that is SMALLER or shaped in a manor so as to provide better clearance that could be adapted to the stock location. All it would take is some leg work in the junkyard, some measurements and a little trial and error. After that, a skid could be fabbed up using factory mounting locations and you're done!~ I KNOW this tank exists, and the guy who figures this out is going to start a VERY popular trend.
gst95dsm is offline
post #3483 of 8099 Old 02-23-2013, 09:45 PM Thread Starter
Sundowner
You may be over thinking the gas tank . I run a Savvy skid in the raised position , and I have only hit it once . I suspect you would hit it less as you have a better departure angle .
I don't think I'd hit it much either...but I just don't want to see any more of it than is necessary.
Originally Posted by Danno6102 View Post
Exactly why I said hell with it! Lol! Besides with the new plans, i'll be installing a cell before too long.
I hear that, man...and if I didn't need all the cargo space available (and more) that's what I'd be doing, too. Swap the pump/sender/regulator/filter - which will now forevermore be known as the Fluid Catalytic Cracking Unit* - into the cell and be done with it.
Originally Posted by mp15dc View Post
Like a fuel filter from a C5 Corvette. It has a built in regulator. Wix 33737.
You learn something new every day.
You're all over my thought process; shallower tank in stock location. The issue - and in case nobody knew this, it's a HUGE issue - is the sending unit. The TJ uses - and correct me if I'm wrong, here - a sending unit with a resistance of 20 to 220 ohms...which seems to be rather odd, aside from other Mopar stuff from similar years. This is one big reason that people use the back-of-the-tub fuel cell and stuff the TJ's FCCU - that's the Fluid Catalytic Cracking Unit, for those of you that don't remember - into the cell...you don't have to worry about your gas gauge f****** up on you because the resistance is the same. There are ways to make another sending unit function, but I honestly don't know the in's and out's of them at this point; thus, the trick would be to:
- Find a sending unit that has the same resistance but will fit in an aftermarket fuel cell or shallower tank.
- Find a tank/sending unit combination that will bolt into the stock location that gives better clearance and plays nicely with the TJ gauges.
- Discover the in's and out's of altering sending unit resistance, and thus rendering the stock sending unit capable of being placed in another cell/tank.
Either way, I want a high-clearance tank that doesn't give away too much fuel capacity...and knowing that I'm not going to do a rear stretch at any foreseeable point helps me a bit. I may go with a basic high-position Savvy for awhile, but this seems like a fun side project to me. It's worth some Muppet Labs time.
*It makes shoes for orphans. Nice job breaking it, hero.
Sundowner is offline
post #3484 of 8099 Old 02-23-2013, 09:56 PM
Bennettj13
Stop trying to re-invent the wheel. Or be different just for the sake of being different. Believe me it's not worth it. If I wouldn't lose my ***, I'd go back to stock and start over in a heartbeat. Why piece all that **** together? Stop overthinking it. Either rock your current set up, but with a tucked skid like Savvy, replace the tank with a purejeep tank and modify it like I did for a LOT more clearance, or just break down and run a fuel cell like I ended up having to do.
::SELLING HALF OF MY JEEP::
Bennettj13 is offline
post #3485 of 8099 Old 02-23-2013, 10:12 PM Thread Starter
Sundowner
I only re-invent wheels when I feel the need to do so; if I thought I could get mucho clearance with the Savvy skid and all of the junk on top of an '03 tank, I'd do that. Do you have either a link or a quick synopsis for what you did you yours in order to get the clearance?
No fuel cell in the tub! Arg!
post #3486 of 8099 Old 02-23-2013, 10:38 PM
gst95dsm
gst95dsm's Avatar
He's not trying to re-invent the wheel. He's thinking outside the box. And currently inside the box is an aftermarket that has provided very few options for the people who NEED the tank under the Jeep.
My thoughts are that there HAS to be similar Chrysler vehicles of the era with with similar hardware to make it all work. The auto makers success depends on parts similarities across models. It's just gonna take someone to do the legwork. For example I would gladly take a Neon tank, with a smaller capacity but 3 inches more clearance and possibly the ability to stretch my wheelbase for pennies compared to a $700+ purejeep or gen-right tank..... a trip to the junkyard just to see how feasible this all is might be in order.
What we have going for us, in a TJ, is that the tank mounting area could not be more simple, flat, and easy to work with. 7 easy to reach nuts and the tank is down, The filler neck is right there..... the catch... is that we need a shallow tank.
gst95dsm is offline
post #3487 of 8099 Old 02-23-2013, 10:40 PM
gst95dsm
gst95dsm's Avatar
There's only one thing you can do with a stock tank to get it up higher than a Savvy skid.....and that's cut out your floor. Unless you're magic!
gst95dsm is offline
post #3488 of 8099 Old 02-23-2013, 10:50 PM Thread Starter
Sundowner
I have no problems with trying something innovative... but I want the floor intact. Savvy did an awesome job engineering that skid, and it gets me a nice chunk of clearance. I'd actually be happy to run that setup and try to find a shallower tank in my off-time... and that kind of thing is fun, for me. I like trying new things even if they don't work out perfectly; the worst that can happen is spending time grave-robbing and learning a LOT about the TJ fuel system!
post #3489 of 8099 Old 02-23-2013, 10:52 PM
Bennettj13
If you are willing to do a good bit more than minor surgery, I'll bother digging up pics if I have them. In case you didn't know, I vowed to keep my PJ tank under my Jeep and still get 104" of WB until I gave up and got a fuel cell "to get the Jeep done faster". Hendrix now has the PJ tank. I still feel that I could have done it. Essentially, the PJ tank mounts the same as the stock tank. However it has a slanted back. I cut out the rear valance sheet metal, bent a new piece to match the angle, and even went so far as to build a 2x4 rectangle bumper/crossmember with recessed mounting for the tank mounts. My tank actually sat flush with the tailgate. I had it tucked up all the way within 1/4" of the tub. You'll also have to (you'll want to) cut out the stock shock crossmember and build a new one. It's not difficult.
And I have an 05. The same pump and **** as you. You are barking up the wrong tree. I've been there, done that. And I'm telling you, it's not worth it. But don't take my word for it. (queue Levar Burton)
post #3490 of 8099 Old 02-23-2013, 11:04 PM Thread Starter
Sundowner
Where's Mr. Scott when we need him?
Pictures would be good, but only when you have a chance. No rush... I'm still doing my homework.
post #3491 of 8099 Old 02-23-2013, 11:22 PM
gst95dsm
gst95dsm's Avatar
Honestly your build, unless you decide to go in a completely new direction is PERFECT for the Savvy skid. Until I got mine I fantasized regularly about only seeing the rear bumper back there and then air Since I bought it though, until I read this exchange, I haven't given it another thought and am still enamored with the curved design and the look of the raw aluminum. Now on a side note..... before I ponied up the $329, I did modify my stock skid by cutting about an inch off the top of the skid, and rebending the mounting flanges. Worked beautifully until I realized I was slamming it so hard I was bending it and it still was rubbing my track bar after tweaking my pinion angle. (the Savvy fixed all that).
Some things are easy...... sorry man!
gst95dsm is offline
post #3492 of 8099 Old 02-24-2013, 07:43 AM Thread Starter
Sundowner
Going with the Savvy skid is a great option for many reasons - most of them having been pointed out in the last few posts - and that's very likely what I will do in order to get some cheap/easy clearance under the gas tank. However, I already know that I'm not going to be completely satisfied with it because I have the feeling that the gas tank could go higher without a huge deal of work; in fact, I know that can happen through some modification of the factory sending unit, which would enable it to be used in a shallower tank in the same location. Finding the shallower tank might be a bit tough because there very well may not be a bolt-in/drop-in solution...but if it takes building a tank to get what I want, I'll just have to build a tank. Having someone like Mark The UberWelder close at-hand makes that kind of thing a lot easier; I won't do a custom setup anytime soon - again: finances - but there's no reason not to plan it out and do some cheap research.
post #3493 of 8099 Old 02-24-2013, 08:51 AM
KateKGB
And building your own could even be cheaper. I wish you less frustration than the top. And spare.
'05 Unlimited Rubicon - Sahara Edition #431
We are the diamonds that choose to stay coal
A generation born, to witness the end of the world
KateKGB is offline
post #3494 of 8099 Old 02-24-2013, 09:17 AM Thread Starter
Sundowner
If I can modify the factory sending unit, all things become possible. That's a project for my spare time, though; for now, I'm busy hoping that the top isn't as expensive as was quoted.
post #3495 of 8099 Old 02-24-2013, 09:28 AM
KateKGB
I didn't know you even had spare time over there. Personally, im very busy with an appointment to not get dressed and stay in bed. Important stuff.
KateKGB is offline
annabelle , bewbs , chic-fil-a , custom , d&d , fallout , firefly , girly things , guns , half cab , hard tonneau , needs to go wheeling , overbuilt , photography , pin-up , sammiches , starwars , survival , wasteland
  LinkBacks (?)
LinkBack to this Thread: http://www.jeepforum.com/forum/f22/wasteland-survival-guide-engineering-greta-1344782/
Posted By For Type Date
glockforum | BoardReader This thread Refback 08-15-2012 09:17 AM
sears diehard batteries - forum communication | BoardReader This thread Refback 07-31-2012 07:50 AM
go there engineering bumpers austonreeves Jeep Picture Requests 4 07-29-2012 09:54 PM
What makes yours a Survival or Wilderness Jeep? fishinjeeper Jeep Picture Requests 39 07-23-2012 12:02 PM
BOV/Survival Jeeps ttony Jeep Picture Requests 2 09-30-2010 04:47 PM
33 engineering bigj1974 Jeep Picture Requests 2 02-03-2008 08:28 PM
GRETA .... then and now GRETA97 Jeep Builds 6 05-05-2004 08:41 PM
