The Wasteland Survival Guide: Engineering Greta - Page 22 - JeepForum.com
post #316 of 8099 Old 04-16-2012, 09:22 AM Thread Starter
Sundowner
Originally Posted by jermeyg View Post
Great information thus far! As you mentioned there are many ways to do this install. My only suggestion is removing the rear driveshaft at the transfercase reduces the edge factor of sitting close to a freight train.
We considered that, and if you don't have four big-a** jack stands it's a very viable solution. However, we had a few other factors in play:
- we did, in fact, have four big-a** jack stands.
- it was quicker and simpler to pull the tires, rather than the driveshaft.
- the brake system needed a total bleed and fluid replacement...and it was easier to do the bleed at the rear with the tires out of the way.
I was more worried about beard damage than being run over.
Originally Posted by Skerr View Post
I have to assign myself to the Remedial-LD group of viewers, unfortunately, but once I overcame the denial it wasn't hard to make this post!
Aww..that's okay...you just get to spend more time at recess than the rest of us!
I could not find why you are turning the unit bearings. Is this due to the extraordinarily large calipers? sorry... sorry...
Actually, a lot of people can get confused here. First let me clarify that the "unit bearing" is not really just a bearing...it's the entire outer assembly that the hub and bearing form when they're manufactured as one unit. It's bearing/hub combination, essentially...so everything from the knuckle-side flange to the rotor flange is technically all part of the unit bearing. When we refer to turning down the diameter we're talking about the exterior hub itself that actually has rotational movement.
If we'd pulled the castle nuts that you see at the center of the hub flange in some of the pictures, we could have removed the unit bearing and left the axles in place. However, there wasn't much of a reason to do something like that: we'd still have to figure some way to do the diameter adjustment, and the outer stub shaft splines would have been just hanging out and getting debris all over themselves.
As for why we're doing the retardedly-dangerous grinding, it's because the inside diameter of the new rotor hat is smaller than the outside diameter of the stock unit bearing flange. The former fits over the latter, or at least it will once the unit bearing flange is reduced in diameter. So: it's done to clear the new rotor.
And I must add that watching a build conducted by someone who is knowledgeable and skilled, and has a plan, is one of the highlights of this forum.
Finally, Jeff Scherb (if you have not seen it), has a very good thread on building a trailer. In that thread he covers, in detail, creating negative molds, including the release agents he purchased to make his skins. Lots of pics. It could be relevant to your half-door idea.
Thank you for the compliment! And yes, I have seen Jeff's thread...posted in it a few times, as well. Right now we're planning on doing a carbon-over wood skeleton and then skinning it with aluminum...but the idea of a total carbon door has already been discussed.
Sundowner is offline
post #317 of 8099 Old 04-16-2012, 12:30 PM
Skerr
Sheesh... you been spying on me!
Thanks for taking the time to explain that. I will not likely be making the same mods, but I do like to understand what is happening. I think your method of turning the "hubs" (that's what I would call them, although technically incorrect) is pure redneck genius! Something I cater to... Well done.
Looking forward to that part of the build.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #318 of 8099 Old 04-16-2012, 12:39 PM
SonicR1
Originally Posted by GoodasDead View Post
She's wearing an Hk hat while working on a jeep?
mother of god.
Loving the build man, really looking forward to the toolkit/gear writeup!
HAH!!! I was thinking that very same thing yesterday!!!!!!!
... I guess I'm gonna have to fix that too…….
2005 Wrangler X 4.0/6 speed, Dana 30/Ford 8.8--4.88--Eaton E-Lockers, 35" MT/R, Smittybilt bumpers/rockers/winch, SonicFab tire carrier, RE 3.5 springs, Zone 1.25 BL, FullTraction 3 link upper rear, RE super flex lower rears, UCF ultra high skid and lo/pro mount, brown dog mml.
SonicR1 is offline
post #319 of 8099 Old 04-16-2012, 12:58 PM Thread Starter
Sundowner
No problem. I'll go back and make a few edits to make that section more clear.
As far as the method is concerned: you would be surprised as to how often necessity ends up being the mother of invention, my friend. I've heard of things like this being done before so the credit doesn't go to me. In fact, Vanco's instructions show the unit bearings still in place with a scribed line, ready for grinding. Naturally, there's no mention of doing this with the vehicle running, but hey...if you've got a built-in lathe, why not use it?
post #320 of 8099 Old 04-16-2012, 12:59 PM
mhopton
Brilliant!
However, as an LJ owner, I look forward to Annabelle's thread with great interest, too.
For the Jeep....really. Seriously, for the Jeep.
mhopton is offline
post #321 of 8099 Old 04-16-2012, 01:21 PM Thread Starter
Sundowner
I made a few text changes to the "Making Room" post, but nothing serious. Thanks to everyone that has questions: they help me to make things clear and better-written.
However, no thanks go to ARB, whatsoever. Translation: WHERE THE F*** IS MY REPLACEMENT SHOCK?!?!
That's right...it's still not here. Invisible Chipmunk still lives in the wheel well. I haven't even gotten a confirmation from the e-mails I've sent asking for a confirmation of the warranty claim. This kind of thing makes me want to go punt a Pekingese.
post #322 of 8099 Old 04-16-2012, 01:35 PM
willman611
There are just too many forms of sexiness in this thread. It should be illegal. But then again, we wouldn't be able to enjoy it as we have. Give Annabelle a hug for everyone and give Andrew a pat on the back. I'm sure it's nice having such useful helpers.
willman611 is offline
post #323 of 8099 Old 04-16-2012, 03:44 PM
357transam
Being an avid reader for the last couple of weeks, I figured that I would finally make a post. I admit that I took an entirely different approach to building my TJ, (feet first without enough research), and being in the automotive industry myself, many of the subjects you are covering are not new material. However, I can't help but hop on the thread to see what crazy antics you are up to on a daily basis. Bravo for enthralling us all with your Epic stories! And I do have to ask; Do you get your super powers from the Sammiches? Or is it the re-donk-ulously Awesome beard???
357transam is offline
post #324 of 8099 Old 04-16-2012, 04:00 PM Thread Starter
Sundowner
It's completely beard-based. To this end I cite ZZ Top, Kimbo Slice, Chuck Norris, Charles Darwin, Jesus, and perhaps the most impressive hominid that's ever walked the face of the earth: The Awesomeness That Is Former President Theodore Roosevelt, whom is famous for making four different continents his b**** with naught but a '95 Winchester and a mustache.
post #325 of 8099 Old 04-16-2012, 06:50 PM
dongalonga
Ahhh the good 'ol Lever Action. Some things never go out of style.
dongalonga is offline
post #326 of 8099 Old 04-16-2012, 06:52 PM
dongalonga
Oh btw you inspired me after the arduous task of installing my Spartan front locker. Mmmmmm I even sprung for the deluxe spicy chicken.
post #327 of 8099 Old 04-16-2012, 07:19 PM
castorriver
This is a cool thread
Registered Nurse Jeep Club Member #1 (I think...)
Verse 36: And He said to them, "But now, whoever has a money belt is to take it along, likewise also a bag, and whoever has no sword is to sell his coat and buy one.
castorriver is offline
post #328 of 8099 Old 04-16-2012, 07:19 PM Thread Starter
Sundowner
^ Pictured: Life-size waffle fries.
post #329 of 8099 Old 04-16-2012, 08:02 PM
Cuder
Your writing style is a resemblance of The Motor City Madman.
Have you read "Ted, White, and Blue"? Great book, Great man!!! Rock on!!
http://www.goodreads.com/author/quot...022.Ted_Nugent
My Build Thread:
Cuder is offline
post #330 of 8099 Old 04-16-2012, 08:08 PM
45AUTO
If I recall correctly this was a 16" kit. Does the 15" kit require the same clearancing for the unit bearing flange?
45AUTO is offline
annabelle , bewbs , chic-fil-a , custom , d&d , fallout , firefly , girly things , guns , half cab , hard tonneau , needs to go wheeling , overbuilt , photography , pin-up , sammiches , starwars , survival , wasteland
  LinkBacks (?)
LinkBack to this Thread: http://www.jeepforum.com/forum/f22/wasteland-survival-guide-engineering-greta-1344782/
Posted By For Type Date
glockforum | BoardReader This thread Refback 08-15-2012 09:17 AM
sears diehard batteries - forum communication | BoardReader This thread Refback 07-31-2012 07:50 AM
go there engineering bumpers austonreeves Jeep Picture Requests 4 07-29-2012 09:54 PM
What makes yours a Survival or Wilderness Jeep? fishinjeeper Jeep Picture Requests 39 07-23-2012 12:02 PM
BOV/Survival Jeeps ttony Jeep Picture Requests 2 09-30-2010 04:47 PM
33 engineering bigj1974 Jeep Picture Requests 2 02-03-2008 08:28 PM
GRETA .... then and now GRETA97 Jeep Builds 6 05-05-2004 08:41 PM
