03-19-2012, 09:06 PM
#16
I'm a big meanie head
I thoroughly appreciate the fallout references and the bewbs! More builds should have more of both. Keep up the good work!
:: SELLING HALF OF MY JEEP::
http://www.jeepforum.com/forum/f33/?uid=152304
03-19-2012, 09:27 PM
#17
Part-Time Swami
The build, the gear, and the mileage: The Wasteland Survival Guide
03-20-2012, 03:36 AM
#18
Oh I am so subscribing to this.
03-20-2012, 03:57 AM
#19
This.
Love the build, it sure is entertaining to read through!
03-20-2012, 05:24 AM
#20
Diggin this! Any suggestions on the 4wd linkage adjustment after BL?
2002 TJ Sport RED Jeep #648 30-44/3.73
Trail rider and DD
I need some red full size doors for a TJ
03-20-2012, 08:02 AM
#21
You inspired me to change my avatar picture. this was the most offensive one I could find. Enjoy that $%!&.
I'm excited for your build!
#22
I destroyed mine and ended up getting the Novak aftermarket one.
03-20-2012, 08:23 AM
#23
Overkill is underrated, subbed.
'90 YJ with some stuff
[URL="http://www.jeepforum.com/forum/f22/1990-yj-iriwn-1151195/"]Build[/URL]
I'm a pic whore, get over it.
03-20-2012, 08:24 AM
#24
Part-Time Swami
Funny story, there...
Since I'm running on such a tight budget right now, I basically decided to keep my hands off the t-case shifter until I could just send $150 to Novak. If I could send 150 caps to Novac and get a shifter, I would.
Seriously, though...I hate doing things twice, so neither bending the linkage to work nor installing the bracket that Daystar gave me were good solutions. However, after disconnecting my battery for a bit during The Saga of The Fuel Injectors (that's a coming installment, as well) I noticed that the four-wheel drive light went absolutely HAYWIRE when I connected the battery and cranked the Jeep back up again. It was sort of a random "on/off/blinking/off/blinking" pattern...and then it came on and stayed on. I decided to try to shift the t-case, just for the hell of it, to see if I had maybe touched a wire or a sensor or something, and see what happened. This is when things got surprising, because two events transpired: 1) the light went off when I shifted into four-wheel high, and 2) the t-case shifted into four-wheel high flawlessly.
So I figured that something was still screwy, and I tried to go into low-range. And I got that familiar, staccato clunking noise before she dropped right into low-range as well. If anything, the case shifted better than it did before. The light started functioning again normally, as well. No issues since then, and I've got full t-case functionality.
So, I have NO F****** IDEA what is going on with that. I'll know when I get inside it here in a few weeks and install a cable shifter. I suppose that my final answer to your question is to not muck around with the bracket at all, and just go to the better solution up front. If you're going to tear into that area, put in something you won't have to worry about ever again.
03-20-2012, 09:02 AM
#25
Sweet build. Any ideas to prevent radiation poisoning?
03-20-2012, 11:09 AM
#26
This is what I dream my build could be like. I love this. Keep it up. Deff subscribed!
My Build Thread:
[url]http://www.jeepforum.com/forum/f22/ians-1993-jeep-wrangler-yj-sarah-1225169/[/url]
03-20-2012, 11:39 AM
#27
Do you have plans for a Fat-Man launcher?
USAF
03-20-2012, 01:18 PM
#28
turn up the AC next time anna helps
but seriously like where this is going. I want too do the same thing with my xj.
1999 Jeep Cherokee.
2"BB for now.
03-20-2012, 01:25 PM
#29
Looking good, keep it up.
03-20-2012, 01:37 PM
#30
Looks like a good start. Love your humor.
annabelle
chic-fil-a
custom
d&d
evil chicken
fallout
firefly
guns
half cab
hard tonneau
overbuilt
photography
pin-up
sammiches
starwars
survival
wasteland
