The Wasteland Survival Guide: Engineering Greta - Page 151 - JeepForum.com
post #2251 of 8099 Old 08-19-2012, 01:05 PM
balzer
Originally Posted by cycleguy04 View Post
Is he serious?
I wish I was serious, I can hardly fund my projects alone lol.
however I have put serious thought into something amazing happening like winning the lotto. build a big shop stock it full of tools and equipment then hire out of work jeepers to build jeeps. Ahh to dream!
2001 TJ SE
1971 J4800 gladiator
balzer is offline
post #2252 of 8099 Old 08-19-2012, 03:13 PM
Zjones1994
Id do it for free if i could haha
1998 Chili Pepper Red Jeep
USN Hull #233
Check out my build!
Zjones1994 is offline
post #2253 of 8099 Old 08-19-2012, 04:15 PM Thread Starter
Sundowner
Originally Posted by tony4311 View Post
Always a chance they did it before upgrading everything else to that point.
That's very true, but those rigs have a purpose-built "did it all at once" look to them and this was the basis of my commentary. With that said, I do have to admit that there could be some tire interference with the tub even with that large of a lift; there's so much potential uptravel that one of the tires could arc inwards far enough to cause trauma.
Originally Posted by GunHo198 View Post
The rims have the shops logo cut into them,
Oh, now that's just gauche...
Originally Posted by balzer View Post
How is the soft half top going to mount to the decks front lip? If you discussed this I missed it, I looked back a bit but didn't see it.
Snaps. We're going to run three or four snaps around the corner of the upper skirt, and that will form the attachment for the corners of the soft top side panels. The rear window - which is as large as a factory soft top rear window, mind you - will also snap into the skirt. We'll just mark and drill the proper holes and then install the through-bolted snaps. Simple.
I will pay you minimum wage to help fund your build. All you have to do is come help me 1) get my comanches home 2) help me do the drivetrain swap on my gladiator. 3) help me build one of the comanches using GM drive train and FSJ narrow track cherokee axles and finally 4) help me swap a 4.3L GM V6 into my TJ. I may be temped to throw in the leftover comanche and associated parts for a end of year bonus......
An entertaining offer...and since I don't really have a full-time job of any sort it's tempting.
On a more serious note: that GM 4.3L swap is a very smart plan. Light, compact...most of its mass further down and more rearwards than the factory six...you'll be more than happy with your weight balance, there.
Pictured: Speaking of being happy with things...
We had 100% relative humidity today, and against my better judgment I applied a bit more paint...mostly because I needed a break from stripping/polishing the aluminum logistic track and I wanted to see how it would look in a finished state against the textured black paint of the deck. I'm pleased with the results; the trim blocks are not ostentatious in the least, and the satin exterior of the aluminum track sections looks pretty slick against their black interiors and the deck surface itself. I think the stainless hardware will be the perfect finishing touch.
Sundowner is offline
post #2254 of 8099 Old 08-19-2012, 05:19 PM
Yarz
Looks Awesome!
"Build a man a fire, and he'll be warm for a day. Set a man on fire, and he'll be warm for the rest of his life."
1990 White YJ TBI350, SM465, NP231, SOA, RE 1.5" SOA springs, Ford 8.8, D30, 4.10's, JBConversions SYE, XJ shaft, Bilstein 5150s, jb4x4 steering, MORE SS brakelines, 35x12.50 15 MT's, '95 YJ Brake Booster, '78 Grand Marquis MC, ZJ Prop. Valve
Yarz is offline
post #2255 of 8099 Old 08-19-2012, 06:19 PM Thread Starter
Sundowner
Originally Posted by Yarz View Post
Looks Awesome!
Thank you! I hope it will turn out exactly that way.
post #2256 of 8099 Old 08-19-2012, 06:35 PM
balzer
Yes the more I look into it the more I am comvinced that the GM 4.3L V6 is the best engine for wranglers and cherokees and comanches. At least from a mild to moderate build point of view. The 4.0 is fine if you have one already but there is far more potential in other options.
In other news your deck is looking awesome. very well done sir!
2001 TJ SE
balzer is offline
post #2257 of 8099 Old 08-19-2012, 07:17 PM Thread Starter
Sundowner
I've seen some nicely-done supercharged four-cylinder powerplants as well, but the location of the V6 mass is choice. That's why I'm so hung up on the V8 configuration, myself...it's less weight than the six, and it's further back and down. The 4.3 is a more refined iteration of that idea...and with some tuning they can make decent power; 300+ isn't hard to do. And believe me...I've considered going that route.
Thank you!
post #2258 of 8099 Old 08-20-2012, 07:45 AM Thread Starter
Sundowner
Today's Jeeping: We've got drier weather and sunshine...and that means PAINT.
post #2259 of 8099 Old 08-20-2012, 10:26 AM
andy02
Originally Posted by snakedriver View Post
I teach CCW here in NC That is the class we all - DREAM - about
Turned out to be a great class! The instructors daughter took me to dinner that night and I got four other phone numbers. With the exception of one, all the girls in the class were
Originally Posted by Hendrix
September 11 2001
Never Forget!
andy02 is offline
post #2260 of 8099 Old 08-20-2012, 03:37 PM Thread Starter
Sundowner
Well, the results of painting the deck surface are in: it looks absolutely f****** terrible.
The texture that works so well on curved features - i.e. fender flares - works against itself on flat surfaces; the paint either piles up or dries and thins out, and the end result is a blotchy effect. Thus, there's no way to get an even coating on a large surface...that's the simplest way to explain it. I've got an HVLP gun with which I could apply a separate finish layer of paint, but I think the uneven texture beneath it is just going to show through and leave me with another sub-par, soft, weak finish.
At this point I don't really know what to do, aside from sanding the paint I applied today to a smooth finish and starting over with another type of finish. So much for having it done this week.
post #2261 of 8099 Old 08-20-2012, 03:47 PM
bobthetj03
It's tough to spray that much flat surface area with a rattle can for sure! I think you're right about grabbing the HVLP gun and go with maybe a HotRod black or something.
Bob's boring build:
White Jeep club member #2003
bobthetj03 is offline
post #2262 of 8099 Old 08-20-2012, 04:03 PM
cycleguy04
I had the same experience with my rock rails, but I am not as anal as you and just piled the paint on.
If I have problem a with it I'll repaint it. First paint jobs are known to be a learning experience.
'98 Wrangler Sahara - SOLD
'91 Ranger XLT 2WD - 4.0 V6, A4"hell"D, contemplating twin turbo 5.3
'79 C10 Big Ten 2WD - 350, TH350, contemplating rebuilding to 355ci with supercharger and programmable EFI
'12 Subaru Forester (AKA: Arctic Cat) - 2.5, non-CVT, wife's, still begging her to let me get an exhaust system
'01 SV650 - snorkelectomy, ebay slip-on, cam swap and re-jet in the near future
cycleguy04 is offline
post #2263 of 8099 Old 08-20-2012, 04:53 PM
G Beasley
I am not a fan of the textured paint , but I love the hammered finishes . Sounds like you have some sanding or stripping in your near future ... I feel for ya .
G Beasley is offline
post #2264 of 8099 Old 08-20-2012, 05:20 PM Thread Starter
Sundowner
If I go that route, I'll have to sand down the texture to an even level.
It's a learning experience...that's for sure.
Well, I'm thinking of it this way: I've got a really good base coat of black laid down...and that's certainly not any kind of loss. I think I'll take a block to it tomorrow and just sand it down uniformly and see where that gets me. The skirts and smaller areas look great...it's just the big, open patches that are causing the problem. The main issue is getting a solid coat applied without the texture piling up and turning into a gel-like mass. Likewise, a thinner coat only causes a coarse, soft sandy build-up that has no adhesion to itself. I've got plenty of 220-grit paper, and that'll knock it down to a flat surface pretty quickly...and it'll also give me some time to think on a better course of action. Ideally, I can find a way to apply the textured paint in an even, smooth fashion...I just don't know what that will be.
post #2265 of 8099 Old 08-21-2012, 06:46 AM
johnrmclean
You could roller over it somehow???
A Kid can never have enough sets of wheels!!!
98 TJ, 82 El Camino tactical support vehicle, 2001 supercharged S 2000, 1979 MGB 350 ci/400hp small block Chevy, 1947 Studebaker pick up/future Rat Ride, 2001 Sebring Convertible, 28' Baja Offsore, 2 seados and a 17' fishing boat...
johnrmclean is offline
annabelle , bewbs , chic-fil-a , custom , d&d , fallout , firefly , girly things , guns , half cab , hard tonneau , needs to go wheeling , overbuilt , photography , pin-up , sammiches , starwars , survival , wasteland
  LinkBacks (?)
LinkBack to this Thread: http://www.jeepforum.com/forum/f22/wasteland-survival-guide-engineering-greta-1344782/
Posted By For Type Date
glockforum | BoardReader This thread Refback 08-15-2012 09:17 AM
sears diehard batteries - forum communication | BoardReader This thread Refback 07-31-2012 07:50 AM
go there engineering bumpers austonreeves Jeep Picture Requests 4 07-29-2012 09:54 PM
What makes yours a Survival or Wilderness Jeep? fishinjeeper Jeep Picture Requests 39 07-23-2012 12:02 PM
BOV/Survival Jeeps ttony Jeep Picture Requests 2 09-30-2010 04:47 PM
33 engineering bigj1974 Jeep Picture Requests 2 02-03-2008 08:28 PM
GRETA .... then and now GRETA97 Jeep Builds 6 05-05-2004 08:41 PM
