The Wasteland Survival Guide: Engineering Greta - Page 145 - JeepForum.com
post #2161 of 8099 Old 08-12-2012, 11:08 PM
92wrongler
Originally Posted by Sundowner
Were they both the same color or did you get one of each?
Both same color, patina green.
Painted it with, free to me, industrial rust-oleum old CAT yellow.
Rims, bumpers and roll bar, I believe even windshield frame, painted industrial rust-oleum Old John Deere Green.
Used best stuff between the two, and sold the rest to finance project.
Welding was done by uncle, I did most of the fabrication and body work.
Ex-father-in-law still drives it.
Says it's his speed, and goes where he wants.
92wrongler is offline
post #2162 of 8099 Old 08-13-2012, 09:42 AM Thread Starter
Sundowner
I think bare aluminum track would look great against the black (assuming it'll end up black) deck.... if you've seen my junker you'll know i'm a big fan of raw aluminum against black. If you want to buy just one quart of the raptor liner I've got an application gun you can use, it's just about the easiest and most forgiving finish to apply that i've ever used.
I'll send you a PM on that.
Nice. I'm hoping to scrounge up an old flat-fender at some point; I have truly horrible things planned for one.
Today's Jeeping: Hole-drilling...
Sundowner is offline
post #2163 of 8099 Old 08-13-2012, 10:37 AM
robd2003
Uhm... Sounds a bit on the personal side eh?
Jeeps:
99' XJ<->5.5" Lift; 35's; SYE; Winch; much more goodies too
02' WJ<->Rebuilt from wreck, still stock
robd2003 is offline
post #2164 of 8099 Old 08-13-2012, 03:59 PM Thread Starter
Sundowner
Pictured: Drilled and countersunk.
I also have the holes drilled in the tub, and although a few of them got a bit off-center at some point I don't think there's anything to worry about. Only two of them will really require any work but I may enlarge them all, anyway. I'll take care of that tomorrow, and also get the C-pillar flange holes located and punched through. With any luck, tomorrow evening will see the first coat of paint!
post #2165 of 8099 Old 08-13-2012, 04:06 PM
MattSteve
Looking very good, been keeping a close eye on your projects, especially this one. Its been inspiring me to do more with my jeep, and to keep the quality up.
Good work
-Matt.steve
MattSteve is offline
post #2166 of 8099 Old 08-13-2012, 04:23 PM
bobthetj03
Looks like someone's gonna have a Duster up for sale soon!
Bob's boring build:
White Jeep club member #2003
bobthetj03 is offline
post #2167 of 8099 Old 08-13-2012, 05:45 PM Thread Starter
Sundowner
Do the best job that you can do, and you'll be satisfied. Half-a**ing something is the best way to rip it out later and do it all over again.
Yep...and two tailgate bars. Also the rear window, roof panel and hardware bows from a soft top and the back seat and all of its associated bits and pieces. The rear seat belts have been gone for awhile but I've never sold them. I've also got to get rid of the front and rear stock bumpers. I'm hoping to get a half-decent price for some of this stuff and thereby offset the cost of having made the modification. If I can do that I can probably afford to get the custom top done before winter hits.
post #2168 of 8099 Old 08-13-2012, 07:29 PM
robd2003
Doing a good job on this project! I went and looked at a wrecked tj, $3,200 as it sits, being it needs all new front sheet metal, new driver side axle control arm mount, and air bags(not needed) so im looking to sell the jeep, and doing something similiar if i can get it.
Jeeps:
robd2003 is offline
post #2169 of 8099 Old 08-13-2012, 07:43 PM
G Beasley
Hidden fasteners tigged in place would have been sweet !
G Beasley is offline
post #2170 of 8099 Old 08-13-2012, 08:55 PM Thread Starter
Sundowner
I thought about it.
post #2171 of 8099 Old 08-14-2012, 12:53 AM
cycleguy04
Installing an aluminum rivet, microshaving flush to the cover, and painting would have had the same effect and would have been much easier. This will look good none the less, but a trained eye will see the center pin in the cherry max rivet.
You're making me rethink the necessity of my rear seat.
'98 Wrangler Sahara - SOLD
'91 Ranger XLT 2WD - 4.0 V6, A4"hell"D, contemplating twin turbo 5.3
'79 C10 Big Ten 2WD - 350, TH350, contemplating rebuilding to 355ci with supercharger and programmable EFI
'12 Subaru Forester (AKA: Arctic Cat) - 2.5, non-CVT, wife's, still begging her to let me get an exhaust system
'01 SV650 - snorkelectomy, ebay slip-on, cam swap and re-jet in the near future
cycleguy04 is offline
post #2172 of 8099 Old 08-14-2012, 09:10 AM
balzer
So is the half cab going to end at the b pillars of the roll bar? and it looks like your door surrounds are a bit to high.
Looks great though if you wasnt putting the tie downs on it it would be a good place for some sort of logo lol.
2001 TJ SE
1971 J4800 gladiator
balzer is offline
post #2173 of 8099 Old 08-14-2012, 10:08 AM Thread Starter
Sundowner
Ditch it!
Yes, it will essentially end at that point. It will wrap across the top of the B-pillar and secure to the upper skirt...the curvature of which we formed to match the curve of the tub corners. The door surrounds might look too high, but they're not. If you notice, there is a pair of orange clamps that are pulling them down tight to the doors frames.
Not a bad thought...but I do need the tie-down tracks.
post #2174 of 8099 Old 08-14-2012, 10:32 AM
rusty762
Sundowner I thought you were going to install the half cab on Anna Belle's rig? What top are you looking at? You know that I just installed a GR8TOPS on my Rubi LJ, not a great fit I have spent a lot of time to get the doors and windshield to fit properly and it still is not a good fit around the doors. Had to remove a fair amount of fiberglass to get it even close to fitting the window frame. I sprayed two coats of Monstaliner in the tub and over the side rails which is probably close to your deck enclosures thickness so you should not have an issue there.
Rusty
If I had eight hours to chop down a tree, Id spend six sharpening my axe.- Abraham Lincoln
Have you hugged a Firefighter today?
rusty762 is offline
post #2175 of 8099 Old 08-14-2012, 11:06 AM Thread Starter
Sundowner
Oh, we are going to do a half-cab on Annabelle's rig...and we're going to do one just like you did; either the GR8Top or an AEV top. That'll be a pickup-style conversion...no bars, open bed, etc.
The top that's going on mine will be a soft half-cab, and it's going to be custom built. Think of it as a combination safari top/wraparound windjammer...and although it's somewhat more difficult than I will here describe, the theory is to replicate the rear-most portion of a factory top right behind the front seats. This will give us a large zip-out window and enclosed corners behind the door surrounds, which should be as close to 100% weatherproof as is possible while still being pleasantly open-air...all one need do is either zip or unzip the big-a** rear window panel. When I run half-doors, it will also look pretty nice...which is more than I can say for most of the configurations that require one to retain the door surrounds.
In order to get this built, I've got a marine canvas/hot rod top specialist lined up. He looked at the sketches for about nine seconds and said "This is easy."
annabelle , bewbs , chic-fil-a , custom , d&d , fallout , firefly , girly things , guns , half cab , hard tonneau , needs to go wheeling , overbuilt , photography , pin-up , sammiches , starwars , survival , wasteland
  LinkBacks (?)
LinkBack to this Thread: http://www.jeepforum.com/forum/f22/wasteland-survival-guide-engineering-greta-1344782/
Posted By For Type Date
glockforum | BoardReader This thread Refback 08-15-2012 09:17 AM
sears diehard batteries - forum communication | BoardReader This thread Refback 07-31-2012 07:50 AM
go there engineering bumpers austonreeves Jeep Picture Requests 4 07-29-2012 09:54 PM
What makes yours a Survival or Wilderness Jeep? fishinjeeper Jeep Picture Requests 39 07-23-2012 12:02 PM
BOV/Survival Jeeps ttony Jeep Picture Requests 2 09-30-2010 04:47 PM
33 engineering bigj1974 Jeep Picture Requests 2 02-03-2008 08:28 PM
GRETA .... then and now GRETA97 Jeep Builds 6 05-05-2004 08:41 PM
