The Wasteland Survival Guide: Engineering Greta - Page 103 - JeepForum.com
post #1531 of 8099 Old 06-27-2012, 01:57 PM
hallsofstone
Not a dumb question really. I cover over the actual conducting parts of the connection to maintain current and block water/junk from getting in the way. Sundowner should do a write-up as only he can do to cover this topic. Visual aid would be.....stimulating.
Jeeping Ohio Every Day
00 TJ Sport - Ever evolving DD/Rig
85 Suzuki GS700 - ugly
K.C.C.O.
hallsofstone is offline
post #1532 of 8099 Old 06-27-2012, 05:34 PM
GunHo198
I put it in all of my connections last year. But I just washed my engine bay for the second time, and when I start it it stuffers for a minute then high idle back to normal. The engine light comes on occasionally. I turn it off and back on and it's fine. After a day or two it's back to normal. I think I need to hit the plugs again, or it could be an injector leak. I pulled the code and it read O2 sensor. So that could be the connector getting water in it. I replaced it last year as well. I think the plug has a crack in it.
Going to pull it now and see if I can seal it up with electricle tape and put more grease in it.
94 Jeep Wrangler 4.0 with AX-15 Trans.
4" Procomp Lift, 3" body lift, 35" BFG Tires, Ford 9" Rearend with NASCAR Detroit Locker, Super 30 Front with ARB, Onboard Air, Dual Optima Batteries,Warn M8274 Winch, and Bushwacker Fender Flares.
GunHo198 is offline
post #1533 of 8099 Old 06-27-2012, 05:52 PM
djflyy
Originally Posted by jsburton84 View Post
I have that same banner now too, just shows how scary data mining and browser tracking is.
You both do realize that the reason that is up there is because Keith (the main Admin of JF) is also the lead admin of Chicken Forum? It's the same way they pushed GlockForum when it launched. They're all owned by the same group of people
djflyy is offline
post #1534 of 8099 Old 06-27-2012, 06:28 PM
GunHo198
Well. That wasn't it and I'm out of grease for now. Ran propane around the enjectors and no leaks. Unplugged each injector 1 x 1 and they are fine and working. Checked the map sensor plug and it doesn't seal right. I replaced it a few years ago. Might have to go to the dealership and get an OEM part to make it seal right. Guess I'll have to go through all the sensors and hit them again with grease. Deffinantly a water issue as it will clear up in a day or two. But I don't want to have issues next time I do a water crossing....
GunHo198 is offline
post #1535 of 8099 Old 06-27-2012, 06:31 PM
racingchester
Tool kit
I followed with great interest on how you can put 10 pounds of tools in a 5 pound bag. I scrounged, bought and borrowed the necessary items and with great antisipation I began to put them in the Bell bike handelbar bag. Much to my suprise they all fit (with the exception of the pry bar and hammer) plus a few not mentioned. Thank you for your time and willingness to put this together. I am hoping the tools stay in the bag unuesed for a loooong time..Chuck
racingchester is offline
post #1536 of 8099 Old 06-27-2012, 07:21 PM
unholycowgod
A bit off topic but they just released the toxicology on the face-chewing guy in Florida: nothing but pot.
So I think we're back to our original assumption: zombie patient zero.
Link
unholycowgod is offline
post #1537 of 8099 Old 06-27-2012, 07:24 PM
JeepinShep
2007 WK
Then there was the guy earlier this week who did K2 (synthetic pot), started chasing neighbors around barking and growling at them... then grabbed, strangled, and started to eat their dog...
Something in that synth stuff is BAAAAAAD for you..
2007 WK Limited, Red Rock Crystal, 3.0L CRD, QD-II. OME HD lift. 255x75x17s. Pinchweld mod. 1.5" Alloy hub-centric spacers. F/R Stillen rotors and pads. 4xG rear diff guard and belly armor. Tuned by Green Diesel.
Originally Posted by bhoch
...you never, ever, skimp on suspension and tires as they will save your *** when you do something stupid - and .. you *will* do something stupid.
Originally Posted by DeansWings
Rock crawling is a whole 'nother animal. To me, the off-camber low rpm negotiation of lines provides a different type of adrenaline than plowing through mud. It's terrifying at times, but the pride of looking back at what you just climbed over is what is addictive.
JeepinShep is offline
post #1538 of 8099 Old 06-27-2012, 08:44 PM
NBFarmboy
As if my normal desktop background wasn't chicken enough
well here you are
As if the Chick-Fill-A talk wasn't enough to make me happy
This was my Screen as i logged on tonight
I love a dual monitor Setup
Thanks Sundowner for another good Laugh
my Fiance' thought it was funny as well
Now back to your Regularly Scheduled Programming
RAYS 4X4, an Official MCE dealer, Pm me for prices
"Redneck Rooster" 98 TJ with 5.3 Vortec, 4 speed, 37"s
Wifes "Ladybug" 95 YJ 2.5, 3.5" fenders, 33's, 1" body lift, 1" deep skid pan, york OBA 1" shackle lift
"Bullfrog" 88 XJ 4.0, Doorless, 2" lift, 33-10.5 tires, very cut fenders...
NBFarmboy is offline
post #1539 of 8099 Old 06-27-2012, 08:58 PM
misterpookie
Yep...it goes inside. Whenever I pull a connection apart, I dab some f****** dielectric grease in one (or both) sides of it and slide it back together. I've yet to have any issues from using it, and I can think of at least two times when I didn't use it, only to later wish I had. I don't put it on the outside of a connection at all.
I'm proud to be helping with that.
more dumb question: how water resistant is the alternator? and urm.... if the answer is "not a bit", then what to do about that? it seems waaaayyy too open for my comfort.
jeep-sleep: N, V,
1: (verb) to fall asleep in one's jeep, generally in the reclined position or perhaps even on top of the roof. Ex: :I think i may pull over and jeep-sleep for a bit"
2: (noun) the sleep one gets while in a jeep. Ex: "Dude, that wasn't a nap.. it was a jeep sleep."
FOR SALE:
misterpookie is offline
post #1540 of 8099 Old 06-27-2012, 09:41 PM Thread Starter
Sundowner
I'll add it to the list.
The hell with that...tools are made to be USED. Glad you're enjoying the thread!
I've never had an issue with one getting wet. To my knowledge, they're reasonably weather-resistant and I can't really think of much that's inside of one that would be water-soluble, with the possible exception of the regulators. Like most everything else under the hood, the alternator dries out pretty quickly once it gets wet...I hit mine with the hose all the time and there's been no damage. I actually scrubbed it with a brush and soapy water, once.
Sundowner is offline
post #1541 of 8099 Old 06-27-2012, 10:49 PM
GunHo198
I'm guessing there pretty water resistant as most new small engine cars it seems there on the bottom of the motor. I've had mine submerged many times and have yet to have them fail electronically. But I have had the mud eat up the bearings twice.
GunHo198 is offline
post #1542 of 8099 Old 06-28-2012, 06:20 AM
WileEKI-Ody
i registered on this forum just so i could post on this build and say what an incredible job man. your dedication to your jeep, your chicken sandwiches and your attention to microscopic dust removal is as unparalleled as your skill and determination. also the world would be a cooler place if we could all grow beards like yours
also this thread made me put aside battlefield 3 and play fallout new vegas and me and the ex watched all the resident evil movies lol unfortuanetly their were no chicken sandwiches involved
WileEKI-Ody is offline
post #1543 of 8099 Old 06-28-2012, 06:23 AM
Mitchell420tj
Lmfao sounds very very similar to me oh and welcome to the forum
Mitchell420tj is offline
post #1544 of 8099 Old 06-28-2012, 06:30 AM
WileEKI-Ody
thanks much!
i remember when i was 16 with my first truck, an 85 manche. used to wheel it around some private land out in the boondocks. me and my cousin hit a skunk on accident. i said **** how do we get the smell off..he says leave it on thats the best theft detterent ive ever seen i couldnt get it off but im sure sundowner would wave his magic wand and make it disappear!
post #1545 of 8099 Old 06-28-2012, 06:53 AM
Louie4
I am having Chick-fil-a catered in for a lunch and learn with UPS at work.
Sorry, no relevance to the build but exciting nonetheless.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
annabelle , bewbs , chic-fil-a , custom , d&d , fallout , firefly , girly things , guns , half cab , hard tonneau , needs to go wheeling , overbuilt , photography , pin-up , sammiches , starwars , survival , wasteland
  LinkBacks (?)
LinkBack to this Thread: http://www.jeepforum.com/forum/f22/wasteland-survival-guide-engineering-greta-1344782/
Posted By For Type Date
glockforum | BoardReader This thread Refback 08-15-2012 09:17 AM
sears diehard batteries - forum communication | BoardReader This thread Refback 07-31-2012 07:50 AM
go there engineering bumpers austonreeves Jeep Picture Requests 4 07-29-2012 09:54 PM
What makes yours a Survival or Wilderness Jeep? fishinjeeper Jeep Picture Requests 39 07-23-2012 12:02 PM
BOV/Survival Jeeps ttony Jeep Picture Requests 2 09-30-2010 04:47 PM
33 engineering bigj1974 Jeep Picture Requests 2 02-03-2008 08:28 PM
GRETA .... then and now GRETA97 Jeep Builds 6 05-05-2004 08:41 PM
