Waldorf MD's White Rubi Build - Page 14 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Waldorf MD's White Rubi Build
Forever Wave Flags at JeepHutRubicon Express lift kits w/shocks are on sale!ORS4x4: New Product!
Unread 04-23-2013, 08:26 PM   #196
Hunter7158
One of these days he will convoy up to Rausch with me
[URL="http://www.jeepforum.com/forum/f22/2006-rubicon-first-jeep-1359794/"]My 2006 Rubicon Build Thread[/URL]
Hunter7158 is online now   Reply With Quote Quick reply to this message
Unread 04-25-2013, 08:20 AM   #197
Sac2013
Nice build. Those seats are going to look good in there!
2005 Wrangler X (Sold)
Sac2013 is offline   Reply With Quote Quick reply to this message
Unread 04-25-2013, 08:56 AM   #198
tonkatrucksryan
2014 JK Wrangler
Thanks Now I have to sell my Grey leather seats to recomp some of the cost and there isn't anything wrong with the seats not rip or tears. The passenger side seat bracket is broken. So I convinced the wife I needed new ones.
Seats will be here Wednesday!! and a nice looking weekend ahead!!!!!!!
New build [url]http://www.jeepforum.com/forum/f96/tonkas-first-jku-2014-a-2020929/[/url]
[COLOR="Blue"]26 Years USAF Retired 1MAY14[/COLOR]
Past Jeeps:
04 TJ Rub,05 TJ, 75CJ5, 88YJ
tonkatrucksryan is offline   Reply With Quote Quick reply to this message
Unread 05-01-2013, 07:03 PM   #199
tonkatrucksryan
2014 JK Wrangler
So I got the passenger seat in with no problems. Then I started with the drivers side. I was easily able to take the three bolts out but the torx 50 bolt would budge. I hit it from above and below with penetrating oil multiple times. Please please any advice would be awesome!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Past Jeeps:
Unread 05-01-2013, 08:36 PM   #200
Bedwell
1984 CJ8
Able to use a handheld torch to heat up the bolt? Using air or hand tools?
Subscribe to my YouTube Channel:
http://www.youtube.com/user/RockCrawlinJeeps
Bedwell is offline   Reply With Quote Quick reply to this message
Unread 05-01-2013, 08:38 PM   #201
tonkatrucksryan
2014 JK Wrangler
my air ratchet broke a couple of weeks ago. I don't have a torch. breaker bar was too long. It really is in a crappy location
how much and where could I get a small torch from?
Past Jeeps:
Unread 05-02-2013, 11:44 AM   #202
Hunter7158
Most hardware stores have cheap torches. Small propane tank with a torch nozzle on the top that should hear any stuck bolt up enough to break it loose. If the breaker bar won't fit than just use your regular socket ratchet and put a piece of PVC pipe or a jack handle on the end for more leverage. And if that doesn't work try to hit the ratchet with a hammer to shock it loose.
Unread 05-02-2013, 01:42 PM   #203
tonkatrucksryan
2014 JK Wrangler
Thanks!!!! There isn't room for the PVC idea or the hammer called a local shop and they are going to take a look at it ugh
Past Jeeps:
Unread 05-02-2013, 05:32 PM   #204
tonkatrucksryan
2014 JK Wrangler
Well took Rubi to my buddies shop(jeep owner) and they had the torx bolt out in 5 minutes and didn't charge me. I did give the mechanic a 20 and said beer was on me.
Past Jeeps:
Unread 05-02-2013, 07:22 PM   #205
Hunter7158
Glad to hear man! Now throw up some pics and a review of those seats!
Unread 05-02-2013, 08:02 PM   #206
tonkatrucksryan
2014 JK Wrangler
I didn't have time to install the drivers seat yet. Hope to install them this weekend going to California Md tomorrow and picking up a hood for the CJ. Can't wait!!!! might need to take some vacay and make some real progress on both of them.
Thanks Hunter Have fun this weekend
Past Jeeps:
Unread 05-04-2013, 03:25 PM   #207
tonkatrucksryan
2014 JK Wrangler
Well finally got the seats installed. Had to go to my buddies shop to have the torx bolt removed. The install was ok till I hit the drivers side. Once the seat was bolted down it wouldn't slide back because it hit the seat belt collector. So I put in some large washers to raise it up. Then when I got the seat where I would like it it squeak against the roll bar bad so I cut that out and then ziptied the black outside together. Done
Past Jeeps:
Unread 05-17-2013, 08:44 AM   #208
tonkatrucksryan
2014 JK Wrangler
The seats have taken a little while to get used to. I like them and they are very comfy. Here are the cons..
1) I wish the seat backs were a little higher... oh well
2) The stock seatbelt clips that mount to the seat are a little too short and its a pain.
3) The drivers seat bracket is too tight against the seat belt spool and it now doesn't want to retract to well at all. I already put some spacers in and really don't want to put anymore. The passenger side doesn't have that problem at all. weird
Past Jeeps:
Unread 05-17-2013, 11:33 AM   #209
deinsig
You can get seat belt expander a that will fit for about 20 bucks on amazon. Might be a temporary solution.
deinsig is offline   Reply With Quote Quick reply to this message
Unread 05-17-2013, 11:55 AM   #210
tonkatrucksryan
2014 JK Wrangler
Nice thanks. What should I search for on amazon?
Past Jeeps:
