Waldorf MD's White Rubi Build - Page 7 - JeepForum.com
post #91 of 241 Old 01-15-2013, 08:18 PM Thread Starter
tonkatrucksryan
2014 JK Wrangler
My 75 CJ5 I have been working on for 14 Mo
New build
26 Years USAF Retired 1MAY14
Past Jeeps:
04 TJ Rub,05 TJ, 75CJ5, 88YJ
tonkatrucksryan is offline
post #92 of 241 Old 01-15-2013, 08:19 PM Thread Starter
tonkatrucksryan
2014 JK Wrangler
This was the before picture!!!! So Much left to do. Still isn't registered and I have only driven it about 200ft come on spring. I have all new gauges and the fuel and temp gauge aren't working since I put the new gauges in it.
http://www.jeepforum.com/forum/attac...d-dsc00471.jpg
New build
Past Jeeps:
post #93 of 241 Old 01-15-2013, 08:55 PM Thread Starter
tonkatrucksryan
2014 JK Wrangler
This is the now (so far) Pictures
New build
Past Jeeps:
post #94 of 241 Old 01-15-2013, 09:25 PM
ScottD16
both jeeps looking good, wish my cj5 was nearly as clean as yours
JEEP BUILD better late than never
I like to do the photography Flickr-
wheeling pictures and other random stuff Photobucket
ScottD16 is offline
post #95 of 241 Old 01-17-2013, 07:27 AM Thread Starter
tonkatrucksryan
2014 JK Wrangler
Yesterday and today I went out to the rubi to drive it to work and there was a puddle on the drivers side. Crap!!!! This didn't happen till I took off the cowl to wire some fog lights. I decided not to wire them up and closed it up and put all the screw back and now I have a leak. Any suggestions!!!!
New build
Past Jeeps:
post #96 of 241 Old 01-18-2013, 07:06 AM Thread Starter
tonkatrucksryan
2014 JK Wrangler
When I got home it was sprinkling and I didn't have much time. I found that one of the screws and washer on the windshield side had a gap and didn't cover the hole. I grabbed some silocone and reset the screw and washer and the hole was then totally covered. I hope that this does the trick. Of Course the weather dudes were way off and we didn't get any real rain or snow. oh and they did call for 5 inches. WOW I haven't driven this one in the snow yet and I am still waiting.
New build
Past Jeeps:
post #97 of 241 Old 01-22-2013, 11:43 AM Thread Starter
tonkatrucksryan
2014 JK Wrangler
Spent last weekend on standby for the Inaugural and getting ready for our first grandbaby. Baby Averie is do to show up a week from today. We all can't wait. Oh and thank you weathermen for being absolutely wrong again and no snow.
New build
Past Jeeps:
post #98 of 241 Old 01-22-2013, 12:04 PM
rchase559
You should really get rid of the drop pitman arm on the TJ.
rchase559 is offline
post #99 of 241 Old 01-22-2013, 12:50 PM Thread Starter
tonkatrucksryan
2014 JK Wrangler
Why is that?
New build
Past Jeeps:
post #100 of 241 Old 01-22-2013, 01:27 PM
rchase559
Drag link and track bar need to be parallel and in the same plane. Dropping one (drag link) and not the other changes this. Bump steer is a result.
post #101 of 241 Old 01-22-2013, 03:32 PM Thread Starter
tonkatrucksryan
2014 JK Wrangler
Guess I don't follow you .... You are the first person to say this to me.
New build
Past Jeeps:
post #102 of 241 Old 01-23-2013, 09:13 AM
rchase559
Do some research on bumpsteer and drop pitman arms. I thought it was common knowledge that the drop pitman arms supplied in some lifts are worthless.
I'm sure others have explained it a whole lot better than I can. As the axle moves up and down it follows the arc set by the trackbar. The drag link needs to follow this same arc as closely as possible. If it doesn't, unwanted knuckle movement or steering wheel movement will result as the suspension cycles.
post #103 of 241 Old 01-23-2013, 11:26 AM Thread Starter
tonkatrucksryan
2014 JK Wrangler
I am planning on getting a Currie setup up front. It does ride ruff but oh well. but when I hit a bump the steering wheel can jerk out of my hand. I am sure it isn't a death wobble. I guess when the funds are available I will order that and a standard pitman then.
New build
Past Jeeps:
post #104 of 241 Old 01-23-2013, 06:14 PM
rchase559
That's what bump steer will do. It's very different than death wobble. Sounds like you're on the right track. Good luck with the rest of the build.
post #105 of 241 Old 01-30-2013, 04:43 PM
djflyy
Might as well get a pitman arm in the mean time. They're literally $20 online brand new for the stock (non-drop) one. It might help some of the issues you mention before you spend the $500 on the Currie steering system.
djflyy is offline
