w0mps WJ Build Thread - Page 5 - JeepForum.com
 1Likes
post #61 of 223 Old 02-15-2013, 02:19 PM Thread Starter
w0mps
Was 60 degrees here today, finished up painting the steering and tinkered with my other toy:
- Andrew
w0mps is offline
post #62 of 223 Old 02-24-2013, 02:12 PM Thread Starter
w0mps
Finished up the rear today. Real happy with how everything came out!
The springs are Iron Rock's 4" springs. After measuring, the final hub to fender measurement was 24". Stock is 18", so I'm sitting at 6" of lift. Let's hope the ride isn't too bad with the angle of the control arms!
- Andrew
w0mps is offline
post #63 of 223 Old 02-24-2013, 03:18 PM
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Shield your eyes from the shine! Holy crap that is amazing, it literally looks like it is just coming off the assembly line. I can tell that you are keeping the WJ for the long haul.
Is 24" the front measurement? Maybe it needs some time to settle back in?
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is online now
post #64 of 223 Old 02-24-2013, 03:24 PM Thread Starter
w0mps
Thanks! 24" is the rear measurement. Hopefully the springs settle!
- Andrew
w0mps is offline
post #65 of 223 Old 02-24-2013, 03:28 PM
snobrdrkid07
WJ for Life
Well, the rear is supposed to be 19" from the factory. The front, 18" What is your front hub to fender? Have any pictures of it on its own weight?
-Michael-
post #66 of 223 Old 02-24-2013, 03:34 PM Thread Starter
w0mps
I thought stock rear was 18"? I could be wrong. The measurement now is 24".
- Andrew
w0mps is offline
post #67 of 223 Old 02-24-2013, 04:11 PM
snobrdrkid07
WJ for Life
Stock 18" front 19" rear
Up Country 19" front and 20" rear
So you are around 5" over stock.
-Michael-
post #68 of 223 Old 02-24-2013, 04:16 PM Thread Starter
w0mps
Good to know! Thanks.
- Andrew
w0mps is offline
post #69 of 223 Old 02-24-2013, 05:21 PM Thread Starter
w0mps
Here's a picture for a visual reference:
- Andrew
w0mps is offline
post #70 of 223 Old 02-26-2013, 11:34 AM Thread Starter
w0mps
Finished up the front end today, just need to slap on the steering, bleed the brakes and torque everything down and off to the alignment shop it goes!
- Andrew
w0mps is offline
post #71 of 223 Old 02-27-2013, 05:05 PM Thread Starter
w0mps
Took the Jeep for a ride today. Other than needing an alignment (that's set up for Friday), the truck drives awesome. I'm really impressed with the Bilstein shocks for sure. Took some real sharp turns at high speed and was shocked how smooth it took the turns. Can't wait to get it in the dirt to see how she does.
- Andrew
w0mps is offline
post #72 of 223 Old 02-27-2013, 05:44 PM
The_Eng
Great looking WJ! Now go get it dirty so i can live vicariously through you.
The_Eng is offline
post #73 of 223 Old 02-27-2013, 08:13 PM Thread Starter
w0mps
Ha! Thanks. Alignment day can't come soon enough!!
- Andrew
w0mps is offline
post #74 of 223 Old 03-01-2013, 05:48 PM Thread Starter
w0mps
So, I went and had the alignment done. Specs are posted below. I am sitting at about 1.8* of caster and the Jeep has never drove better. I had the alignment done, front and rear pinion angle set and all four tires balanced. My alignment shop is about 45 minutes away. I had gotten death wobble about 5 times during the trip there, and took it easy the rest of the trip. After a couple hours, they got it set perfect. No vibrations, bump steer or death wobble. Just awesome handling and steering, not one shimmy or wobble the whole way home doing 85 MPH. Hats off to the guys at OK4WD in Stewartsville, NJ, they seem to really know what they are doing. Highly recommended shop and priced very reasonable!
- Andrew
w0mps is offline
post #75 of 223 Old 03-02-2013, 07:46 AM
compcrasher86
So it looks like your toe was off, alot. Whats got me scratching my head though is how your caster is down to rediculously low levels now and its more well behaved. More or less I'm trying to figure out why because I was under the impression that you wanted more positive caster to stabilize the steering.
Matt
compcrasher86 is offline
