w0mps WJ Build Thread - Page 4 - JeepForum.com
 1Likes
post #46 of 218 Old 01-29-2013, 02:19 PM Thread Starter
w0mps
Originally Posted by Capricorn
How are you liking the KM2's so far? I've been debating whether to get those next in the same size you've got, or staying @ 255/75/17 and getting Nitto Trail Grapplers.
I love them. They've been wearing great, look good and preform great off road on any terrain. The trail grapplers are a sexy tire though and very popular.
- Andrew
w0mps is offline
post #47 of 218 Old 01-29-2013, 06:00 PM Thread Starter
w0mps
Did the POR15 base coat on the driveshafts today. Top coat tomorrow.
- Andrew
w0mps is offline
post #48 of 218 Old 02-01-2013, 12:54 PM Thread Starter
w0mps
Final shot of the front axle:
- Andrew
w0mps is offline
post #49 of 218 Old 02-01-2013, 01:03 PM
The_Eng
Shiny
The_Eng is offline
post #50 of 218 Old 02-03-2013, 02:36 PM Thread Starter
w0mps
Not much going on today. Hangin out with my dog watching the puppy bowl until the big game comes on!
- Andrew
w0mps is offline
post #51 of 218 Old 02-08-2013, 02:25 PM
Capricorn
Any progress on the Grand so far?
2002 Grand Cherokee Limited
4.7L Powertech V8 l Iron Rock Offroad 3" Suspension Lift l Bilstein 5125 Shocks l Bilstein 5100 Steering Stabilizer l 17x8 Unique Steel Wheels l LT255/75R17 BFGoodrich Mud Terrain KM l Kevins Offroad Transfer Case Skid l Kevins Offroad Roof Rack Tire Carrier l Hella 500 Black Magic
Capricorn is offline
post #52 of 218 Old 02-10-2013, 01:17 AM
snobrdrkid07
snobrdrkid07's Avatar
You've got one impressive WJ there! I am amazed at how clean it is, I really like it! Great combo too, v8 with the 242!
I have to ask as to why you are running such little caster?
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #53 of 218 Old 02-10-2013, 12:42 PM Thread Starter
w0mps
I'm going to the shop today to finish the paint on the rear axle, then all I have left before re-assembly is some paint on the under body.
- Andrew
w0mps is offline
post #54 of 218 Old 02-10-2013, 12:47 PM Thread Starter
w0mps
Thank you so much!
After lifting the Jeep, I was having problems with steering shimmy. I went over absolutely everything in the front end, pretty much replaced everything and came to the conclusion my caster needed to be adjusted. At that time I was running a Rough Country lift with fixed LCA's. I got rid of all the Rough Country stuff and converted to Iron Rock. Took the Jeep to the shop after I installed all adjustable control arms and had them adjust the caster. Turns out the shop I went to doesn't see too many modified Jeeps and didn't really know what they were doing. They said 3.8 degrees was the best they could get with the drive line angles. Didn't make much sense to me, but helped immensely with steering shimmy and bump steer. I still think it's too low though and they were too lazy to keep adjusting until I had the right angles and as much caster as I could have.
Needless to say after everything gets put back together, I will be bringing it to a known 4WD shop here in Jersey to get it's alignment.
- Andrew
w0mps is offline
post #55 of 218 Old 02-10-2013, 07:39 PM
snobrdrkid07
You're welcome man!
For comparison I was at about ~3 inches of lift and had about 4.2* caster with stock control arms and it had some shimmy on a certain bump and some weird shimmy just because at 55mph on occasion. I increased caster to 6.7* with IRO LCA's and that made driving around town and return to center a lot nicer, along with a better tracking on the the highway. I am running ~6.7* caster now and ~3 in of lift and don't really have any vibes from the front shaft. I do still have some shimmy on the highway but that is probably because of my tires... that is another story though. But, that is so odd that 3.8* was the best that they could do, you should be able to get more caster out of it.
I wonder what caster you were at before the IRO arms, that would interesting to know. I find it impressive that you are able to run that little caster without any issues. Maybe those RC arms just had you at a ridiculously low amount of caster.
-Michael-
post #56 of 218 Old 02-10-2013, 09:33 PM Thread Starter
w0mps
Having the caster set this low definitely makes it hard to keep the Jeep straight, especially at highway speeds. I'm hoping they can set the caster as close to stock as possible with no shimmy! We'll see.....
- Andrew
w0mps is offline
post #57 of 218 Old 02-10-2013, 11:14 PM Thread Starter
w0mps
Did some more paint work on the rear axle today.
New shock mounts welded on after the Rough Country relocation brackets snapped my stock ones:
Axle Prepped for POR15:
Shock brackets and diff cover painted:
Tomorrow I just need to install the cover and I'm good to go. Really waiting on the weather to break so I can finish my under body paint. After that, everything will be put back together!
- Andrew
w0mps is offline
post #58 of 218 Old 02-11-2013, 06:04 PM Thread Starter
w0mps
Rear axle is finished and ready to go in!
- Andrew
w0mps is offline
post #59 of 218 Old 02-12-2013, 05:01 PM Thread Starter
w0mps
The goodies waiting patiently to jump in the Jeep:
- Andrew
w0mps is offline
post #60 of 218 Old 02-14-2013, 08:18 PM Thread Starter
w0mps
Now I'm just waiting for the weather to break so I can get the under body sprayed up. Axles are ready to go in:
- Andrew
w0mps is offline
