w0mps WJ Build Thread - Page 2 - JeepForum.com
 1Likes
post #16 of 223 Old 11-30-2012, 03:03 PM
The_Eng
I've got to do a blend door fix on my 02 dub. How hard was it getting the dash off? is there a write up online that you followed?
The_Eng is offline
post #17 of 223 Old 11-30-2012, 05:47 PM Thread Starter
w0mps
It was just time consuming. Otherwise real easy. I followed: http://www.wjjeeps.com/hvac_ip_remove.htm
Takes about 4-5 hours to remove and it went in even faster. Have an extra set of hands around to help pull the dash out and put it in.
- Andrew
w0mps is offline
post #18 of 223 Old 11-30-2012, 07:48 PM Thread Starter
w0mps
Tentative future upgrades include:
Rock Rails/Hi-Lift
CB Radio/Antenna
Front and Rear Coil Springs
Front and Rear Bump Stops?
Shocks and Rear Mounts
Head Lights
Tail Lights
LED Interior Lighting
Rear Bumper/Tire Carrier
Front Bumper/Winch
Roof Rack
Off Road Lighting
On Board Air
- Andrew
w0mps is offline
post #19 of 223 Old 11-30-2012, 07:57 PM
mjWJ12
I like how you cut your front bumper. I was going to trim it like that or take it off all together....
I saw a ZJ build thread where a guy attached his hi-lift jack to the front where his bumper used to be.
(04 WJ Laredo)3" IRO +3/4" front spacers; Custom rear bumper +d-rings; universal front tow hook; plasti-dipped 16" silverblades; premium sliders; custom hi-lift mount; 265/75/16 Cooper Discoverer ATP.
mjWJ12 is offline
post #20 of 223 Old 11-30-2012, 08:31 PM Thread Starter
w0mps
Thanks. I've always rocked my Jeeps with no front bumper until I bought an after market. I was feeling daring and liked how it turned out just chopping the bottom half on this one.
- Andrew
w0mps is offline
post #21 of 223 Old 11-30-2012, 08:32 PM Thread Starter
w0mps
Had to get rid of the lights on the bumper because there was no more stability left in it after cutting it. So if you plan on chopping it like mine, be prepared to make some reinforcements to run your lighting.
- Andrew
w0mps is offline
post #22 of 223 Old 12-02-2012, 04:22 PM Thread Starter
w0mps
I bought a small tire inflator last week to air up after hitting the trails. I was going to just wait and save for an OBA set up, but that's pretty far down the line and this thing was on sale for $20, originally $50, and I couldn't pass it up. It beats dumping change into a air compressor on the way home. It's a Masterflow MP-140, bought at Pep Boys Auto.
Nice little carrying case for compressor and hose
Finally put the rear 12v to good use
Used my ARB EZ Deflator and aired down to my normal 15PSI that I run on the trail. I run 32PSI on the street
Timed, from 15PSI to 32PSI it takes 6 minutes per tire. The compressor gets pretty hot, along with the 12v plug. I'm not too worried about it though, we'll see how long it holds up.
- Andrew
w0mps is offline
post #23 of 223 Old 12-09-2012, 11:42 AM Thread Starter
w0mps
Well, some ***hole decided he didn't like me laying on my horn after cutting me off in the rain and almost causing a wreck. Threw something at the front of my Jeep and put some chips on my fender. Any suggestions on how to fix this so it's invisible?
- Andrew
w0mps is offline
post #24 of 223 Old 12-09-2012, 12:02 PM
devilswj
Attachment 522016
build a bumper & hunt him down
devilswj is offline
post #25 of 223 Old 12-22-2012, 02:00 PM Thread Starter
w0mps
I can't win. Another guy hit my Jeep last night. Police report filed and waiting on insurance. Hopefully the insurance check can buy me a tactical group rear tire carrier!
- Andrew
w0mps is offline
post #26 of 223 Old 01-03-2013, 10:31 PM Thread Starter
w0mps
Not too much going on, did an oil change and tire rotation. Replaced my wipers with some Bosch Marathons. While I was at it, I painted the arms with some flat black fusion and the trim piece above the hood with some Duplicolor trim paint.
- Andrew
w0mps is offline
post #27 of 223 Old 01-04-2013, 08:03 AM
The_Eng
I need to do the same thing on mine. My wiper arms look terrible and I'm sure it would look 100% better if all that were black again. Gonna have to wait until it's a little warmer than 19 though
The_Eng is offline
post #28 of 223 Old 01-04-2013, 09:21 AM Thread Starter
w0mps
All I did was sand everything with some scotch bright, clean it up with some acetone, hang it up and shoot it. It all came out great, what a difference.
- Andrew
w0mps is offline
post #29 of 223 Old 01-04-2013, 09:39 AM
onyxthecat
Nice jeep!
onyxthecat is offline
post #30 of 223 Old 01-04-2013, 10:24 AM
Wj168900
How did u take the arms and the plastic part off?
Wj168900 is offline
