w0mps WJ Build Thread - JeepForum.com
 1Likes
post #1 of 220 Old 11-28-2012, 08:43 PM Thread Starter
w0mps
So I decided to start a build thread not only to share my WJ with everyone here, but to kind of keep a journal for myself on the Jeep's process. My main goal is to make it a nice daily driver/weekend wheeler. I'd like to get it to a capable trail rig, but be able to drive it to work the next day. So here goes.
Factory Specs:
2002 Jeep Grand Cherokee Limited
4.7L V8 Power Tech
5-Speed Automatic 545RFE
Selec-Trac NV242HD
Dana 30 Front Axle
Dana 44 Rear Axle
3.73 Gear Ratio
Stone White in Color
Aftermarket Specs:
K&N Cold Air Intake and Pre-Filter
Flowmaster 40 Series Muffler
JET Chip
Iron Rock Off Road Adjustable Short Arms
Iron Rock Off Road Adjustable A-Arm
Iron Rock Off Road Extended Rear Sway Bar Links
Iron Rock Off Road 4" Coil Springs
Bilstein 5125 Shocks
JKS Heavy Duty Adjustable Track Bar
JKS Quicker Disconnects
Rough Country 1.5" Wheel Spacers
265/70/17 BFGoodrich KM2's
Up Country Skid Plates
Saguaro4xC Front D Shackle Mounts
Warn Rear Reciever Shackle
Optima Red Top Deep Cycle Battery
Current Status: 4/14/13
A little history - I had got the Jeep in November of 2010. Traded my TJ for it because I needed more room and a better ride to work, being that my Jeeps are normally my daily drivers. The WJ was pretty much stock except for the dreaded Rough Country lift.
- Andrew
w0mps is offline
post #2 of 220 Old 11-28-2012, 08:45 PM Thread Starter
w0mps
About a month after I got it, the Jeep came to me like this. Bone stock with the exception of the Rough Country 4" lift, which was getting tossed eventually anyhow:
- Andrew
w0mps is offline
post #3 of 220 Old 11-28-2012, 08:50 PM Thread Starter
w0mps
Tires
Next I went ahead and threw some 265/70/17 BFGoodrich KM2's on it. I was torn between going with a smaller aftermarket wheel or keeping the stock Avila's with some spacers. I'm glad I kept the stockers:
After 1.5" Spacers:
- Andrew
w0mps is offline
post #4 of 220 Old 11-28-2012, 08:56 PM Thread Starter
w0mps
Seguaro4xC Front shackle mounts
I went ahead and changed all my fluids over to synthetic. I run Mobil 1 10W30 fully synthetic motor oil and filter and Amsoil throughout the transmission, transfer case and both axles. Then I decided it was time for some recovery points. I already had the tow package and a warn receiver shackle from my previous rig, so I was good to go in the rear. I decided to spend the extra money on the front and instead of doing tow hooks, go with the shackles. I felt they were a safer alternative and were WAY beefier. I ordered a set from Saguaro4xC and had them installed in no time. Was very impressed with how beefy the mounts were!
- Andrew
w0mps is offline
post #5 of 220 Old 11-28-2012, 10:15 PM Thread Starter
w0mps
Body Armor
I already have a Mopar gas tank skid plate so I decided to pick up a transfer case skid plate from the dealer. $55 out the door and my transfer case was protected:
- Andrew
w0mps is offline
post #6 of 220 Old 11-28-2012, 10:22 PM Thread Starter
w0mps
Roof Rack and Lighting
I was looking at choices for roof racks and heard alot of great things about the Rola rack for the WJ. They were quite common and looked pretty good. I ordered one and set up Hella 500FF and 75FF lighting along with a custom relay box. I used some PIAA round light brackets after making the mistake of drilling it and bolting the lights directly to the front of the rack. They were already sitting at a 90 degree angle and would not adjust anymore, making them shine directly at the hood. The rears worked out fine, but I went and mounted them on the PIAA brackets as well.
* After a month of having the rack, it started collecting rust around the seam, being it was a 2-piece bolt together rack. I took it off the roof and discovered the inside was filled with rust water already, dripping all over my Jeep. Needless to say, I went and got rid of the rack.
- Andrew
w0mps is offline
post #7 of 220 Old 11-28-2012, 10:30 PM Thread Starter
w0mps
Recovery Gear and Tool Carry
So, I have my armor and recovery points, now it was time to get some quality recovery gear to carry with me all the time. Here's what I carry so far, I'm sure the list will keep growing:
ARB Recovery Bag:
ARB 2"x30' Snatch Strap
ARB 2"x10' Tree Trunk Protector
ARB Speedy Seal Tire Puncture Repair Kit
ARB Tire Deflator
Assorted 3/4" D-Rings
Craftsman Case:
1/4" Ratchet/Standard/Metric Sockets
3/8" Ratchet/Standard/Metric Sockets
1/2" Ratchet/Standard/Metric Sockets
1/2"x2' Breaker Bar
Standard and Metric Box Wrenches
Torx/Allen/Screw Driver Sockets
Craftsman Tool Box:
Phillips/Common Screw Drivers
Channel Locks
Regular Pliers
Needle Nose Pliers
Linesman Pliers
Diagonal Cutters
L/M/S Adjustable Wrenches
Pipe Wrench
Utility Knife
Tape Measure
Mini Sledge Hammer
Cold Chisel
Action Packer #1: (Fluids)
(2) Quarts Mobil 1 10W30
(2) Quarts Amsoil 75W90
(2) Quarts Amsoil ATF
(1) Gallon 50/50 Coolant
DOT3 Brake Fluid
Brake Parts Cleaner
WD40
Grease/Gun
High Temperature RTV
JB Weld
Epoxy
Red/Blue Lock Tight
Action Packer #2: (Clean/Repair)
Blue Paper Towels
Garbage Bags
Rubber Gloves
Drop Cloth
Toilet Paper
Terry Towels
Wire Ties
Bailing Wire
Duct Tape
Assorted Mini/Regular Fuses
Sway Bar Case/Spare Clips
Action Packer #3: (Spare Parts)
12V Air Compressor
12V Drop Light
Ratchet Straps
Spare Serpentine Belt
Spare Universal Joints
Spare Tie Rod Ends
Also installed a 12V female plug behind my cargo panel and mounted my rechargeable Streamlight.
- Andrew
w0mps is offline
post #8 of 220 Old 11-28-2012, 10:34 PM Thread Starter
w0mps
Cooling System
So my blend doors were starting to act up, the heat was cold and I popped a hole in the radiator. It was time to tackle the cooling system. I replaced the radiator and pulled the dash. A couple hundred dollars later and about a weekend, my heat was hot and all my blend doors were working. Replacing the radiator and pulling the dash was not too hard, just time consuming. My advice is to keep everything nice and organized and make sure you have enough time to do it! Don't rush!
- Andrew
w0mps is offline
post #9 of 220 Old 11-28-2012, 10:46 PM Thread Starter
w0mps
Suspension and Steering
Started hearing a rattle coming from the rear of my Jeep and found this:
After seeing this, getting death wobble and having my RC springs sag an inch in about a year, I knew it was time to upgrade the suspension. First thing I did was grind off the WELDED track bar drop bracket on the frame side of the Jeep and ditch the drop pitman arm for a stock one. Yes, I did say the drop bracket was WELDED on (PO). Went and upgraded to a JKS heavy duty track bar.
I aligned the Jeep after this and it took care of 80% of my wobbles. After going over EVERYTHING in the front end and confirming all the wearable parts were in good shape, I decided to get some control arms and play with the caster. Installed all Iron Rock Off Road adjustable control arms in the front and rear and was off to the alignment shop again. Had my guy adjust the caster to a sweet 3.8 degrees and all my wobbles were gone.
I had previously installed JKS quick disconnect sway bar links up front and decided to upgrade the rear sway bar links to the longer IRO ones, to get rid of the drop brackets.
While I was installing the rear sway bar links, I had to use the supplied nut and bolt from IRO. The stock WJ brackets have a welded nut on them, so I was forced to grind it off and hit it with some paint.
Took the Jeep over to my buddy's shop to torque everything down and took some undercarriage pictures.
The last couple suspension modifications (coming soon) include Iron Rock 4" springs and Bilstein 5100's all around.
After a few trips offroad, I got fed up with using my rubber marks on my front bumper as a guideline to trim the plastic, so I decided to cut the lower half of the bumper off. I used some frog tape and a very fine tooth sawzall blade to cut, and a nice sharp razor knife to clean up the burrs after:
No more rubbing!
- Andrew
w0mps is offline
post #10 of 220 Old 11-28-2012, 10:48 PM Thread Starter
w0mps
Husky Floor Liners
Installed some floor liners in time for winter
- Andrew
w0mps is offline
post #11 of 220 Old 11-28-2012, 10:52 PM Thread Starter
w0mps
Birthday Cake and SNOW!
My girlfriend and family threw me a suprise birthday party and made me this kick-*** cake.
Also, the first snow of the season has hit NJ!
- Andrew
w0mps is offline
post #12 of 220 Old 11-28-2012, 10:53 PM Thread Starter
w0mps
New Camera
Picked up a Nikon Coolpix S9300. Played around with the HDR feature.
Also, slapped my new sticker on
- Andrew
w0mps is offline
post #13 of 220 Old 11-30-2012, 01:12 PM
BenHoleton
Looking good! I love the WJ platform!
BenHoleton is offline
post #14 of 220 Old 11-30-2012, 01:23 PM
richsandwich
The bumper looks nice trimmed like that!!
richsandwich is offline
post #15 of 220 Old 11-30-2012, 01:56 PM Thread Starter
w0mps
Thanks! I was looking at different ways to trim it, and took the chance with just chopping the bottom half off. Glad it came out looking good!
- Andrew
w0mps is offline
