#46 | ||
#47 |
did you get that cam sensor??
-Mike I aint got the jeep no more, but I have a 91 f250 turbo diesel!!! :D |
#48 |
naw they didnt have one
Photographer at heart Have questions about something photography related? Click here!Like Coheed and Cambria? Join the club! My Jeep Build My Photography (New as of Jan. 25th) 1982 Motorcycle Build |
#49 |
awh that sucks man,
#50 |
how would i check that? just see if it goes into 4hi/4lo then go from there and check underneath
#51 |
1997 TJ SE - Emeral Green Pearl 2.5L : AX-5 : NP231, D30HP : D44 : 4:88 : Front Aussie 2.5" OME lift, OME LT shocks, 2" BL, Currie Control Arms, Currie HD Steering, Currie Trackbars, Warn M8000 Custom Front and Rear Bumpers, Custom Rock Sliders, OBA 33" x 12.5" x 15" Goodyear MTRs, Black Steelies |
#52 |
J,
I was thinking about removing my t case drop aslo.... I bought the jeep with the lift already installed. Are the new bolts the only thing you needed to replace and or remove? Thanks, Roc I plan on doing a sye the same time... |
#53 |
yup just new bolts. someone mentioned that some kits come with a transfer case linkage drop but mine didnt. i beleive that the bolts are 1/2" x 2" but not quite sure. i have the package at home and can check on that later (im at school)
#54 | |
when you took away the tcase drop maybe all it is is the tcase moving around a bit and its just vibrating something up close to your feet? |
#55 |
well its constant actually. when i first posted about it i had a very short drive so i wasnt able to pay much attention to exactly what it was doing. but i crawled underneath and that rubber thing is missing (if you look at the 4x4xplore link)
#56 | |
Did you install a T-case linkage lowering bracket with your BL? I didn't, and am looking into the AA T-case relocation bracket because shifting into 4hi/lo brings the suck atm. |
#57 |
nope no lowering bracket
![]() i dont know ill start her up today and crawl underneath and see if anything else might be causing it
#58 |
after further inspection the list continues to grow as to what the knocking could be. now its either the TBS, front CV joint, or one of the bolts from the torque converter has come loose. tomorrow i shall spend my day figuring it out and fixing it so that i can go wheeling this weekend
#59 |
well we figured out what the noise was. my cat was rattling against the skid. when i had it put in it had the drop on so it just needs to but raised a little. thankfully it wasnt something more serious or expensive
#60 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
