Unlimited LJ - JeepForum.com
post #1 of 128 Old 03-13-2014, 01:41 PM Thread Starter
BLACK04WJ
Unlimited LJ
Yes, this is another LJ rubicon build yet slightly different. Different due to the fact that it will be an unlimited LJ not an unlimited TJ I bought the jeep from an auction in Colorado after it was rear-ended. The damage to the jeep was worse than the pictures made it look but I still feel that I made a great purchase. So let the rebuild begin!
The passenger side frame rail pretty much went through the tub when the jeep was hit.
Here are a few shots of the jeep on the frame machine before we started pulling on it.
We pulled on the frame with the body on still in hopes that the body would somewhat straighten out at the same time.. and it did
Then we brought it back to the shop to pull the body off and take the frame back to the frame machine.
Due to the frame being kinked right at the arch, we came up with a plan to make the frame work a little bit easier. We had a wrecked TJ frame with front end damage and decided to hack the back of it off and section it into the LJ frame. As most of you know, that will stretch the LJ wheelbase 5" hence the "Unlimited LJ"
I didn't get a chance to take any pictures of the two frames cut in half but I did get a few of them being sectioned back together. Pics are just tacked, not fully welded.
Due to the stock tub being pretty beat up from the wreck, I decided to cut the tub right behind the doors and use the rear half of another LJ tub to section in (would have just used the whole tub but it had firewall damage already) Yesterday, the frame and half of the original body were put back together and the jeep is yet again headed to the frame shop to have the rear tub sectioned to the front. After the tubs are fully welded back together, the outside of the tub will be re-painted white. I have decided to bed-line the interior so there is no sense in painting the inside.
After the body is back in 1 piece, there won't be much left to do before I can start driving it. I will be ordering Poison Spyder front highlines w/ 3" flare and daddy longlegs rockers/rear corners. once those are on, I have a set of 35" BFG A/T's to throw on and then I will be able to start driving the jeep. The first thing on my to do list (after I start driving the jeep) is to do a small BL and MML to allow for a tummy tuck. I have other plans after that but they always seem to change
Here is what the jeep looked like as of yesterday
I plan on using this jeep as my DD/ mild trail rig/ expo vehicle. I am also currently build a TJ that will be a Trail only jeep.. more on that later.
I live only 2 hours from Moab and its my favorite place to wheel! I was hoping the jeep would be done in time for EJS but thats not going to happen.
Well that pretty much catches this build up for now. I will post some pictures when the jeep come back in 1 piece.
Comments are very welcome and if you are ever near moab and want some new trails to wheel, hit me up!
06 LJ Rubi / 97 TJ / 04 WJ
Oct '12 GCOTM
http://www.jeepforum.com/forum/f22/unlimited-lj-2212193/
BLACK04WJ is offline
post #2 of 128 Old 03-13-2014, 08:05 PM
G Beasley
This is going to be a nice build , look forward to the updates .
G Beasley is offline
post #3 of 128 Old 03-14-2014, 02:05 AM
311LJ
311Popo
311LJ's Avatar
I didn't know about the rear tj section! That will be awesome!
John
04 TJ Unlimited, GenRight Armor, 37's
89 XJ Laredo, 31's
07 WK Overland, Hemi, Chrome bug deflector
[SOLD] Jimmer 01 WJ *2009 GCOTY*
I ♡ John
311LJ is offline
post #4 of 128 Old 03-14-2014, 07:27 AM
tyvanwie
Sub'd opcorn:
tyvanwie is offline
post #5 of 128 Old 03-14-2014, 01:07 PM
85IrocZ-28
Its cool to see the pics, it will be cool to see what it looks like all stretched out. In the pic below, are those drill holes from removing some type of mount, or did you insert plate inside of the frame rail and plug weld it?
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, Uniden/Firestick, Flowmaster, Smittybilt 8k Synthetic Line Winch.
My Jeep is Organic - Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY ---
85IrocZ-28 is offline
post #6 of 128 Old 03-14-2014, 03:06 PM Thread Starter
BLACK04WJ
The frame has been internally sleeved and it was plug welded
I shouldn't ever have to worry about that section of the frame being weak.
Oct '12 GCOTM
post #7 of 128 Old 03-25-2014, 02:13 PM Thread Starter
BLACK04WJ
Making some progress.
Oct '12 GCOTM
post #8 of 128 Old 03-25-2014, 02:20 PM
311LJ
311Popo
311LJ's Avatar
Sweet man!
John
89 XJ Laredo, 31's
I ♡ John
311LJ is offline
post #9 of 128 Old 03-25-2014, 03:27 PM Thread Starter
BLACK04WJ
Originally Posted by 311LJ View Post
Sweet man!
Thanks!
Also, forgot to mention I threw a 1.25" body lift on in preparation for the tummy tuck. I only needed a 1" BL but we already had the 1.25" laying around so it will work. Should hopefully be ordering armor with a week or 2.
Oct '12 GCOTM
post #10 of 128 Old 03-25-2014, 09:51 PM
Cashcrazy
1983 CJ7
What did you use for the internal sleeve? I may need to do something similar.
1982 CJ7(sold), 1983 CJ7(sold), 1989 YJ(sold), 1983 CJ7 undergoing frame-off.
Cashcrazy is offline
post #11 of 128 Old 03-26-2014, 09:24 AM Thread Starter
BLACK04WJ
I'm honestly not positive since I did not do the frame work but it was just a rectangle tube that slid inside the frame.
Oct '12 GCOTM
post #12 of 128 Old 03-26-2014, 10:34 AM
jforse
Cool project! I'm interested to see how it comes together.
1997 TJ - Build in process.
2004 WJ Freedom Edition 4.7HO
jforse is offline
post #13 of 128 Old 03-30-2014, 08:53 PM Thread Starter
BLACK04WJ
Welded frame section.. can't even tell where the weld is. The TJ body mount was also cut off as it isn't needed.
The body still isn't lined up 100% but its close and coming together quick.
and some random shots.
Oct '12 GCOTM
post #14 of 128 Old 04-03-2014, 10:41 PM Thread Starter
BLACK04WJ
Custom poison spyder daddy long legs armor was ordered today. Also traded a stock soft top and my 5 Rubicon wheels straight across for an LJ hard top
Oct '12 GCOTM
post #15 of 128 Old 04-03-2014, 11:32 PM
rckchucker
I don't understand your first post...Jeep never designated the LJ as an LJ. It is still a TJ in the dealer system. Just an unlimited TJ... Hurry up and get this Roller Skate done so we can go play.
rckchucker is offline
