Ugly Betty - TJ Magnum V8 Conversion and more - Page 17 - JeepForum.com
post #241 of 746 Old 01-06-2013, 09:13 AM Thread Starter
Jason
The grille painting didn't go that well. Couldn't get the primer to stick / dry / seal. Started over this morning.
Buddy that I bought the Ram truck from came over last night and we replaced the final brake line and bled the rears. Now all the steel lines have been replaced.
I'm going to keep working the paint today, and research what fan I can use.
We're men! We don't need no stinkin directions!
Jason is offline
post #242 of 746 Old 01-06-2013, 11:42 AM
Rubicon0311
Done yet?
Rubicon0311 is offline
post #243 of 746 Old 01-06-2013, 11:47 AM Thread Starter
Jason
Paint is going on better today, probably because I'm not rushing it. I'm still researching the fan thing. Because the water pump isn't close enough to center, I need to run an electric. But, I need to find an electric that is thin enough to fit with the clearance I have available, ~4.25 inches.
Jason is offline
post #244 of 746 Old 01-06-2013, 11:54 AM
Rubicon0311
You can paint my bumper and cloaks when I get them
post #245 of 746 Old 01-06-2013, 11:58 AM Thread Starter
Jason
As long as you want a spray bomb job....
Jason is offline
post #246 of 746 Old 01-06-2013, 12:04 PM
Rubicon0311
So you finally decided to go electric...is there a reason why you don't want to just trim the fan you have?
post #247 of 746 Old 01-06-2013, 12:08 PM Thread Starter
Jason
This is why. Basically, I feel that putting a fan small enough to fit will degrade my cooling capacity.
I tried putting the Jeep fan on just for fitment, and it contacts the top of the fan shroud. I measured from the threaded snout on the water pump pulley to the top and bottom of the shroud and it's way off. 8" to the top, about 10.75" to the bottom. It's as if the engine is sitting way too high. The engine mounts were installed exactly as AA spec'd, and as low as I'd ever want them. In fact, they are a little too low for my liking, but I wasn't going to try to move them.
So even if I cut that Dodge fan down to 9" or less, that leaves over 2" at the bottom of the shroud open with no fan blowing across. I'm not sure what affect that would have on my cooling? I have a little room at the top where I could move the shroud up by redrilling the holes, but I'd estimate that only gaining me about 0.5".
Maybe I could build my own shroud?
Jason is offline
post #248 of 746 Old 01-06-2013, 12:11 PM
Rubicon0311
Might be cheaper haha.
post #249 of 746 Old 01-06-2013, 12:17 PM Thread Starter
Jason
Maybe. I might still have other clearance issues to worry about too.
Jason is offline
post #250 of 746 Old 01-06-2013, 12:18 PM Thread Starter
Jason
But I do like the idea of the two speed fan with a defeat switch.
Jason is offline
post #251 of 746 Old 01-06-2013, 01:00 PM
bangintin
I would look at fan designs, the shroud is only there to channel the air, an oscillating fan has no shroud and it still pushes air, the shroud is only there to prevent the fan from taking air from the surrounding areas and only allowing air to be drawn from across the radiator, as well as a safety feature to prevent contact with the fan blade when the engine is running...the fact that it is not centered or that it sits higher or lower is a non issue. Whether you build a shroud, or modify one, whether you trim the arc at the bottom of the shroud, you will be fine. Most shrouds are not centered, most clutches do not sit in the center of the radiator either....
I think you may be over thinking this fan thing...
I also think you may be convinced you want the electric fan, but can't commit :laugh
bangintin is offline
post #252 of 746 Old 01-06-2013, 01:07 PM Thread Starter
Jason
You are probably correct on all counts, especially the inability to commit.
Anyone know how deep the Taurus fan is?
Jason is offline
post #253 of 746 Old 01-06-2013, 01:10 PM
bangintin
I guess I think about failures, if you are out wheeling and your electric fan tanks, whether your motor is running or your wheels are turning, it's gonna leave you in a bad way, with a mechanical fan if your motor is running, and the wheels are turning, your engine is cooling(assuming your other cooling system components are doing their job) and a thermal fan clutch failure is almost a never happening event... When it fails, it typically seizes to always on..
This is the angle I am coming from when building my jeeps, what is gonna work and is least likely to fail... Electric motor fail rates are higher than thermal clutches
post #254 of 746 Old 01-06-2013, 02:55 PM
Copperhead89
When you say "defeat switch", do you mean a manual on/off switch?
Are you too far along to move the engine back, in order to gain more room for an electric fan? I had to do that with my V8 magnum conversion, but my engine is more old school, it just has the magnum heads. I relocated mine back because I was dead set on using a '95 Ford T-bird fan, which is the same as the vaunted Lincoln MKVIII fan, except it has a 2 speed motor instead of a variable speed motor. It's 5-1/2" deep, and I have 3/16" clearance at the water pump pulley bolts.
My YJ/CJ V8 Magnum Build: http://jeepforum.com/forum/f22/magnum-force-mopar-mans-build-1412306/
Copperhead89 is offline
post #255 of 746 Old 01-06-2013, 03:00 PM
Copperhead89
And for that reason, I'll have a spare fan motor packed away in my rig when I hit the trails.
magnum , ugly betty , v8 conversion
