Quantcast UCC 2005 Jeep Wrangler Unlimited Build... - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > UCC 2005 Jeep Wrangler Unlimited Build...
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire CarrierThe Original 3/8" Ruffstuff Diff Cover!
Old 11-26-2009, 07:11 AM   #1
UltimateCC
Before picking up the 2005 Jeep Wrangler Unlimited I had been building a 1987 Jeep Wrangler with an endless amount of mods including 7 inches of lift, waggy 44s, aussie lockers, etc but my younger brother was driving it and got into an accident and that ended that build.
During the build
After the accident
So I began looking for a 2004-2006 Jeep Wrangler Unlimited because I wanted a bit more room and to have the ability to tow 3500lbs. I eventually picked up a 2005 Jeep Wrangler Unlimited in Patriot Blue (fully loaded) with only 19,100 miles from a couple in CT. It came with both a hardtop and the factory softtop. The carfax came back clean and had been regularly serviced by Jeep. So sent out our tow truck and picked it up for 15,500 which for NY was a pretty good deal.
For more pictures and to follow the complete build check out:
Zenfolio | Ultimate Collision Center | Dan's Yeep- 2005 Jeep Wrangler Unlimited
My goal for this build is to keep it with a LCG because the last jeep was fun but it wouldn't have flipped if it hadn't been lifted so high. I want to tastefully modify it with function in mind. I will update this thread regularly and many more pictures will follow as parts arrive.
To start I knew I wanted the MetalCloak system on the Jeep. I called up Matson at MetalCloak and ordered:
MetalCloak Overline Tube Fender
MetalCloak Overline Flat Flare - 6"
MetalCloak Low Profile LED Marker Lights
MetalCloak Removable Rear Flare- 6"
MetalCloak Rocker System
MetalCloak Modular Flip Step
After getting those ordered I knew I wanted a beefy front bumper and rear tire carrier/bumper. So after some research I called up Preston at TuffDesigns and ordered:
Tuff Designs Front Bumper
Tuff Designs Rear Bumper/Swing Out Tire Carrier
I also purchased some TKH Fabrications Frame Tie Ins to add more strength to the rear bumper and some Moeller Scepter ECO Jerry Cans for the rear bumper.
Now that I had the big items ordered and waiting for them to arrive I ordered a Fumoto Oil Drain Plug Valve (F101N) to help make oil changes easier.
Then I ordered some items for my differentials:
Riddler Differential Cover Dana 30
LubeLocker "Reusable" Differential Gasket for Dana 30 Axle
Aussie Front Locker
Riddler Differential Cover Dana 44
LubeLocker "Reusable" Differential Gasket for Dana 44 Axle
Then I decided that I didn't want to run any lift on the Jeep so I ordered a 0.75" Front Coil Spacer to account for the weight of the front bumper.
Then I ordered some interior pieces:
Rugged Ridge Sport Bar Grab Handles in Red
Rugged Ridge Sport Bar Fire Extinguisher Holder in Red
Then I ordered some new headlights (Autopal H4 E-Code) and plan to order the DDM HID kit for it after I get most of the current modifications installed.
Then I got the itch to pick up a MetalCloak Frame-Built Bumper system which I will have pics of shortly.
Then I couldn't decide what tires and wheels to run so in the meantime I ordered a set of your typical jeep Cragar Soft 8s to mount my BFG A/T KO's (35x12.5x15) from my wrecked YJ.
FUTURE MODIFICATIONS:
V-Series Contura II Sealed rocker switch. Winch
ORF Sport Cage, Dash bar, Overhead Streamer Bars
DDM 55W H4 Hi/Lo 5000k HIDs
Winch
TUFFY Security Glove Box
Scrublade Wiper- 11"
The Black Rat Pulley Block
Black Rat Towing Kit
Black Rat Tree Trunk Protector
Black Rat Snatch Strap
Double Ripper Beadlocks
Cobra 75 WX ST CB Kit
Harbor Freight 12v Air Compressor
ELECTRONICS
Cobra 75 WX ST CB
4' Wilson FLEX CB Antenna
3-Way Vertical Surface & Mirror Kit
Compact External Speaker
ENGINE
4.0L I-6 242 cu in
FUEL
TRANSMISSION
NSG370
AXLES
Dana 30
Aussie Front Locker
Dana 44 With Trac-Lok LSD
TRANSFER CASE
NV231 Command-Trac
LIFT AND TIRES
Rough Country 2.5" Lift
Rough Country Rear Track Bar Bracket
Rough Country Performance Steering Stabilizer
Cragar Soft 8 Wheels (15x8 5x4.5 4BS) x 5
BF Goodrich AT 35x12.5x15 x 5
AUDIO
Griffin iTrip Auto Universal FM Transmitter
DPL Windshield Mount For Iphone
Premium 7 Speaker System
INTERIOR
Two Toned Interior
Rough Country 1" Seat Risers
Rugged Ridge Front Floor Liner
Rugged Ridge Rear Floor Liner
Rugged Ridge Sport Bar Flash Light Holder in Black
EXTERIOR
Factory Hardtop
Factory Softtop
Autopal H4 E-Code Headlights
MetalCloak UCC Bumper
Moeller Scepter ECO Jerry Can x 2
Simple Siphon
Rugged Ridge Front Euroguards
Rugged Ridge Rear Euroguards
Rugged Ridge Steering Box Skid Plate
Rugged Ridge Hood Lock
Hidden Hitch Class III Basket Carrier
UltimateCC is offline   Reply With Quote
Old 11-26-2009, 07:12 AM   #2
UltimateCC
Started with these
And added this
Then I got tires and rims balanced
Started to strip the jeep down for the build
MetalCloak Frame Built Bumper
Front coming together now...
A couple hours later and this was the result...
Then it rolled back into the shop to get detailed and install a few more parts that were left...
Old 11-26-2009, 07:13 AM   #3
UltimateCC
And ended the two days with this...
Old 11-26-2009, 07:13 AM   #4
UltimateCC
*Reserved for pictures to follow 3
Old 11-26-2009, 07:14 AM   #5
UltimateCC
*Reserved for pictures to follow 4
Old 11-26-2009, 07:15 AM   #6
UltimateCC
*Reserved for pictures to follow 5
Old 11-26-2009, 07:16 AM   #7
UltimateCC
*Reserved for pictures to follow 6
Old 11-26-2009, 07:17 AM   #8
UltimateCC
*Reserved for pictures to follow 7
Old 11-26-2009, 07:18 AM   #9
UltimateCC
*Reserved for pictures to follow 8
Old 11-26-2009, 09:18 AM   #10
mg2000xj
This will be AWESOME!!!
-Morgan
'00 Silverstone 2 Door XJ
Utah Jeep Crew Member #119
My Webshots
New Build
Old Build
mg2000xj is offline   Reply With Quote
Old 11-26-2009, 09:32 AM   #11
UltimateCC
Thanks, I can't wait to get this build going
Old 12-03-2009, 08:45 PM   #12
UltimateCC
Well the stuff for this build keeps arriving to the house and shop. I have been swamped at work and haven't had time to work on the LJ let alone put NY plates on the it. Maybe this weekend I will get around to installing some of these parts. I also have a new metalcloak front bumper coming. In the picture is the tuffdesigns front bumper.
Old 12-03-2009, 09:32 PM   #13
Martinsc
That is a lot of stuff and a lot of money. Its gonna look sick man.
Martinsc is offline   Reply With Quote
Old 12-03-2009, 09:43 PM   #14
UltimateCC
Yea a lot of reading and planning went into this build, learned a lot from the past and other projects we have done and want to do this one right the first time around...
Old 12-03-2009, 11:08 PM   #15
03Jeeper
03Jeeper's Avatar
Oh my god! Christmas came early for you!!
Can't wait to see those parts thrown on the jeep!!
Sienna Pearl Coat Club Member #24
/l ,[____],
l---L-OlllllllO-
()_)-()_)-o-)_)
My totaled TJ rebuild
03Jeeper is offline   Reply With Quote
Glock Forum
