Ty's TJ. - Page 98 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Ty's TJ.
KrawlOff-Road.com Sale EventFS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light Ba
Unread 07-15-2013, 09:07 PM   #1456
Jankoid
Originally Posted by tyvanwie View Post
What is the point? Cushion, keeps water/dirt out, seal?
Supposedly everything you listed, but if you ask me its a solution to a problem that doesn't exist.
Jankoid is offline   Reply With Quote Quick reply to this message
Unread 07-15-2013, 09:09 PM   #1457
tyvanwie
Originally Posted by Jankoid
I see absolutely no point in that upgrade.
Hey, if it saves me money I'm all for it $219 is very tempting for them.
Also, where is this decal they mention? Is it just a sticker we get or is it on the rocker? I can't find a pic.
tyvanwie is offline   Reply With Quote Quick reply to this message
Unread 07-15-2013, 09:12 PM   #1458
Kodiak17
Maybe instead of making vague derogatory comments you should explain your reasoning.
Regardless of if the rock slider wraps under only 2 inches or runs all the way to the frame rail, I've never seen a rock that was shaped just perfectly so that it would hit the tub under there before hitting the slider or frame first. Even if you did somehow manage to hit the tub, its not gonna hurt anything. It is double walled there and isn't visible.
Apologies for not thoroughly explaining myself.
The idea behind bringing the slider closer to the framerail is more to negate the prying force from a step recieving resistance from a rock. If you don't include a step in the design I assume its not as important.
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline   Reply With Quote Quick reply to this message
Unread 07-15-2013, 09:16 PM   #1459
sjones26573
Probably the same stickers that came with my steps.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline   Reply With Quote Quick reply to this message
Unread 07-15-2013, 09:18 PM   #1460
tyvanwie
That's what I figured because the steps come raw. So I wouldn't imagine they'd put a decal on it...
Unread 07-15-2013, 09:25 PM   #1461
sjones26573
We're using out thinking caps.
Jeep-Owner.com
Unread 07-15-2013, 09:27 PM   #1462
tyvanwie
It's cuz I are colleg studant
Unread 07-15-2013, 09:33 PM   #1463
Jankoid
I suppose that could be an issue depending on design, but it would take one helluva hit to damage the slider in that way. My MetalCloak sliders don't attach under the tub at all, and they've taken serious abuse with no deformation to them or the tub. In fact, Ive watched the guy in front of me hit his Savvy sliders hard on a rock and dent the chromoly step thing, and my MetalCloak sliders took no damage from the same hit. Not trying to say anything bad about Savvy sliders, just saying you are gonna bend the slider before prying it loose with a hit that hard.
Unread 07-16-2013, 05:38 AM   #1464
EugeneTheTJ
Tar Heel
EugeneTheTJ's Avatar
Sticker is separate. The gasket helps seal the slider. Not needed but for $30 I opted for it.
A lot of people just run a caulk bead across the top after install to keep water/dirt out.
EugeneTheTJ is offline   Reply With Quote Quick reply to this message
Unread 07-16-2013, 08:15 AM   #1465
tyvanwie
Quick question. I believe my steering stabilizer is leaking. And I have JKU shocks just sitting in the basement. Could I use one as a stabilizer?
I know they're cheap and a dime a dozen, just curious if it would work.
Unread 07-16-2013, 08:26 AM   #1466
EugeneTheTJ
Tar Heel
Does it have 50/50 valving? Probably not
Unread 07-16-2013, 08:26 AM   #1467
mcannon111
It won't be the same valving as a steering stabilizer, so it probably won't work. If you really want a new one kyb makes a stellar one for 30 bucks. But you really don't need a steering stabilizer for your jeep to drive good. I haven't ran one in about a year now.
no doors, no top, no problems
live in sc? join [COLOR="Blue"]OffroadSC.com[/COLOR]
[URL="http://www.jeepforum.com/forum/f22/silver-bullet-1249782/"][COLOR="Silver"]The Silver Bullet[/COLOR][/URL]
mcannon111 is offline   Reply With Quote Quick reply to this message
Unread 07-16-2013, 08:27 AM   #1468
mcannon111
Also aren't stock jku shocks charged? If so that would make your jeep pull like a mother****er.
Unread 07-16-2013, 08:35 AM   #1469
tyvanwie
I have no idea about the valving or anything. I know I don't need one, I just figure if I could do an easy solution I would. I'm guessing a TJ shock wouldn't work either? If not, **** it. Not a big deal.
Unread 07-16-2013, 08:46 AM   #1470
MountainMan864
Another vote. TNT guardian sliders.
MountainMan864 is offline   Reply With Quote Quick reply to this message
nc guys
