Ty's TJ. - Page 96 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Ty's TJ.
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 07-14-2013, 10:04 PM   #1426
Kodiak17
The Rokmen's wrap under more than the Crown's.
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline   Reply With Quote Quick reply to this message
Unread 07-14-2013, 10:18 PM   #1427
EugeneTheTJ
Tar Heel
EugeneTheTJ's Avatar
A to z
EugeneTheTJ is offline   Reply With Quote Quick reply to this message
Unread 07-15-2013, 07:16 AM   #1428
Imped
Imped's Avatar
You don't want any that mount to the body mounts......the ones you want go around the body mounts and fasten securely to the bottom and side of the tub.
OlllllllO
Float Test Build
IndyORV
Imped is offline   Reply With Quote Quick reply to this message
Unread 07-15-2013, 07:20 AM   #1429
EugeneTheTJ
Tar Heel
exactly why I don't have PSC
Unread 07-15-2013, 08:03 AM   #1430
Jankoid
So what? It doesn't make any difference...
Jankoid is offline   Reply With Quote Quick reply to this message
Unread 07-15-2013, 08:13 AM   #1431
tyvanwie
Why? Is it because a hit could rip out the body mounts?
tyvanwie is offline   Reply With Quote Quick reply to this message
Unread 07-15-2013, 08:21 AM   #1432
AngryTJ
Rokmen are built very strong I love mine
[SIZE="5"][COLOR="Blue"]Follow me on Instagram @ Tarantula_TJ[/COLOR][/SIZE]
[URL="http://www.jeepforum.com/forum/f22/angrytjs-97tj-05-rubicon-build-1271051//"][SIZE="4"][B]
Tarantula_TJ Build[/B][/SIZE][/URL]
AngryTJ is offline   Reply With Quote Quick reply to this message
Unread 07-15-2013, 08:45 AM   #1433
Imped
Imped's Avatar
That, and why would you want body armor mounted between the body mount bushing and the tub? That's the cheap, easy way to secure the slider to the bottom of the tub and it's not very friendly on the either the tub or mounts. I went that route early on as well and I can tell you that it's a PITA and not the right way to do it. Get something worth buying, don't take the cheap way out.
Properly fastening a slider to the tub involves preload. You don't get that with body mounted sliders.
OlllllllO
Float Test Build
IndyORV
Unread 07-15-2013, 08:48 AM   #1434
Jankoid
I'd say its more because they are a pain in the *** to install.
Unread 07-15-2013, 09:27 AM   #1435
Kodiak17
Maybe to you it doesn't.
Unread 07-15-2013, 09:36 AM   #1436
tyvanwie
Okay looked at a few of the mmore closely.
Metalcloak attaches directly to the rocker panel. Didn't see anything about underneath mounting though, I could have missed it.
Rokmen has side and underneath mounting with cutouts for the body mounts.
And I can't really tell on the crown ones.
Unread 07-15-2013, 09:57 AM   #1437
Jankoid
Maybe instead of making vague derogatory comments you should explain your reasoning.
Regardless of if the rock slider wraps under only 2 inches or runs all the way to the frame rail, I've never seen a rock that was shaped just perfectly so that it would hit the tub under there before hitting the slider or frame first. Even if you did somehow manage to hit the tub, its not gonna hurt anything. It is double walled there and isn't visible.
Unread 07-15-2013, 10:02 AM   #1438
mcannon111
Yeah you're gonna be dragging your body mounts long before you hit the tub at that point. Mine wrap up pretty far, but i can take a picture and show you that the majority of the dings and dents are down the side of the rocker, not way up underneath where you're thinking it matters.
no doors, no top, no problems
live in sc? join [COLOR="Blue"]OffroadSC.com[/COLOR]
[URL="http://www.jeepforum.com/forum/f22/silver-bullet-1249782/"][COLOR="Silver"]The Silver Bullet[/COLOR][/URL]
mcannon111 is offline   Reply With Quote Quick reply to this message
Unread 07-15-2013, 10:03 AM   #1439
tyvanwie
Do you have the moabfab ones?
Unread 07-15-2013, 10:06 AM   #1440
Jankoid
They dont mount underneath at all, only to the side.
nc guys
