Ty's TJ. - Page 86 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Ty's TJ.
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 06-17-2013, 12:36 PM   #1276
LifeProof
SEMPER FIDELIS
LifeProof's Avatar
You haven't been in real mud yet if you think those tires don't gum up. Try URE when its wet, then try making that statement.
yeah, my tsl/sx's were full of that clay. one guy passing by me even asked if my tires were bald
but that day of wheeling was just all about sliding around and dodge the trees lol
LifeProof is offline   Reply With Quote Quick reply to this message
Unread 06-18-2013, 09:14 AM   #1277
tyvanwie
I know it's still about a week away, but do you guys have any tips for replacing these parts?
I will be taking the coils out to measure for bumpstops but I'm not sure if that will help when I replace the arms, or if I should put the coils back in for that.
Anything special for the tierod?
And should I put the quick discos on while the jeep is on it's own weight? Or have the front axle droop?
Thanks guys, I'll actually have some good updates soon
Sent from my iForum using JeepPhone
tyvanwie is offline   Reply With Quote Quick reply to this message
Unread 06-18-2013, 07:38 PM   #1278
Kodiak17
Tie rod: big pipe wrench and a bench vise. Discos: on its own weight so you can set the swaybar angle at ride height.
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline   Reply With Quote Quick reply to this message
Unread 06-18-2013, 07:57 PM   #1279
tyvanwie
Thanks. What about the arms? Does it matter what order they go in? Should I take them all out at once or pair by pair?
Unread 06-18-2013, 07:59 PM   #1280
sjones26573
Not all at once but otherwise shouldn't matter. The pinions going to be in the same spot. They're fixed length arms. If you have a jack and at least one pair in you're set. You can take 2 rear and 2 front out. But you definately want to chock the wheels on both sides.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline   Reply With Quote Quick reply to this message
Unread 06-18-2013, 08:43 PM   #1281
Kodiak17
A big ratchet strap might help. A jack placed in the right spots on the axle helped more than anything though.
Unread 06-19-2013, 06:51 AM   #1282
tyvanwie
Would taking the coils out help when I replace the arms?
Unread 06-19-2013, 07:11 AM   #1283
sjones26573
I never did, with the exception of the 8.8 swap obviously.
Jeep-Owner.com
Unread 06-19-2013, 07:18 AM   #1284
Kodiak17
It would make moving the axle around easier...
Unread 06-19-2013, 07:29 AM   #1285
tyvanwie
What I'll probably do is just work my way back. Swap the tierod and quick discos, pull the coils, replace the arms, and check the bump. Then pull rears, swap those arms, and check bump.
Unread 06-23-2013, 05:09 PM   #1286
tyvanwie
Got the new to me sway bar with quick disconnects on today. Install was a breeze.
Unread 06-23-2013, 05:25 PM   #1287
Jankoid
Make sure you check the nuts holding the disco to the sway bar periodically. They had a tendency to loosen up sometimes.
Oh, and those 2 brackets I gave you are for storing the discos when connected. They attach to the sway bar cover, but I dont recommend putting them there. The tires will hit the discos when flexing and turning. Thats how I bent one of them. Clay moved his brackets to the inner fender above the coil bucket, they seemed to work pretty well there.
Jankoid is offline   Reply With Quote Quick reply to this message
Unread 06-23-2013, 05:27 PM   #1288
tyvanwie
Will do. The drivers side link comes off easier than the passenger side. Is there something I can do to make the passenger looser, or should I even worry about it?
Unread 06-23-2013, 05:29 PM   #1289
Jankoid
I say dont worry about it. It's a cheap disco, what do you expect?
Also, check the edit to my last post.
Unread 06-23-2013, 05:36 PM   #1290
tyvanwie
I was wondering about those. Can I not just ziptie the links to the swaybar when disconnected?
nc guys
