Ty's TJ. - Page 57 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Ty's TJ.
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineWIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ
Unread 03-31-2013, 07:27 PM   #841
mcannon111
The stock LSD is pretty well worthless. I have it, and the only time it ever pulls is when the tires have close to the same traction. It worked alot better when I first put it in, but after wheelin on it the way I wheel I think the clutches are worn out.
However I'd still take a stock LSD over an open diff any day of the week. Trust me you don't want a lunchbox rear locker, your jeep will drive like a full on piece of ****.
no doors, no top, no problems
live in sc? join [COLOR="Blue"]OffroadSC.com[/COLOR]
[URL="http://www.jeepforum.com/forum/f22/silver-bullet-1249782/"][COLOR="Silver"]The Silver Bullet[/COLOR][/URL]
mcannon111 is offline   Reply With Quote Quick reply to this message
Unread 03-31-2013, 07:31 PM   #842
tyvanwie
So is it general consensus that I should get a front locker, then leave the rear open until I get the money for a good locker? Thoughts?
Sent from my iForum using JeepPhone
tyvanwie is offline   Reply With Quote Quick reply to this message
Unread 03-31-2013, 07:32 PM   #843
sjones26573
Sure. For the rear, whatevers cheapest.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline   Reply With Quote Quick reply to this message
Unread 03-31-2013, 07:36 PM   #844
tyvanwie
Just trying to figure out what route to go with this. I haven't researched lockers much.
Unread 03-31-2013, 07:46 PM   #845
Kodiak17
Thats what i'm doing. Unless I can get the LSD free of charge...
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline   Reply With Quote Quick reply to this message
Unread 03-31-2013, 07:48 PM   #846
tyvanwie
True. I'm thinking of an Aussie up front, but I don't know yet.
Unread 03-31-2013, 08:02 PM   #847
Jankoid
Lockright for the front. Currently the cheapest and it's the highest quality of the available lunchbox lockers. For the rear the cheapest you should go on a locker is a grizzly or detroit. A lunchbox locker is trash in the rear. Selectables are nice, but for the money a detroit/grizzly is the way to go IMO. I agree with Mason though, even a crappy stock LSD is better than being open. Open diffs are weak too, the spider gears become the weak point in the axle.
IMO, a rear locker provides more benefit than a front locker. However, it is cheaper to lock the front first, and it is still a HUGE improvement over stock, so I would throw a lunchbox in the front first if I were you.
Jankoid is offline   Reply With Quote Quick reply to this message
Unread 03-31-2013, 08:06 PM   #848
NYGLT56
Your Local Body Builder
I was going pretty simple. LSD, refurbished internals, and maybe upgraded brakes. Do they have a website?
I wouldnt go simple on a whole axle purchase. Save the hassle spend the extra $$ and have it done right the first time.
Do a selectable locker
Shafts
Whole 9 yards.
The rear end is probably the most important to beef up seeing it sees 5x more stress than the front. Build it and forget about it. That's the way I like it.
Instagramin --> @thatonebeardedbro
2014 TJOTY Winner
NYGLT56 is offline   Reply With Quote Quick reply to this message
Unread 03-31-2013, 08:11 PM   #849
tyvanwie
Alright. If it comes with an LSD I'll take it, but I'll have to consider not getting it depending on how much extra it is, because that money would towards a good locker.
Unread 03-31-2013, 08:12 PM   #850
tyvanwie
Shafts
Whole 9 yards.
Good point. If I can snag a job I will for sure.
Unread 03-31-2013, 09:24 PM   #851
Kodiak17
My Aussie has worked awesome... can't beat it for $250.
Unread 03-31-2013, 09:28 PM   #852
tyvanwie
That's what I've been thinking.
Unread 03-31-2013, 11:55 PM   #853
mcannon111
I would definitely go with an Aussie up front, a 30 ain't worth enough to put anything else in. And if I were you and getting a ecgs 8.8. I'd definitely Atleast get it geared.
If you can make friends with someone with a welder though then you can save a whole ton of cash. I have less than 300 in my 8.8 from gears to brackets to truss. But I also geared it myself.
Unread 04-01-2013, 06:38 AM   #854
tyvanwie
Good point.
Stupid question of the day: if I eventually swap in an HP30 will the Aussie still work in it?
Unread 04-01-2013, 07:12 AM   #855
JCJeep97
Good point.
Yes, it will. I swapped my Spartan from my LP30 directly into my HP30.
My Build: http://www.jeepforum.com/forum/f22/back-black-2000-tj-build-1237980/
JCJeep97 is offline   Reply With Quote Quick reply to this message
nc guys
