Ty's TJ. - Page 43 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Ty's TJ.
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 02-22-2013, 09:55 AM   #631
8pitcher
8pitcher's Avatar
Originally Posted by sjones26573
About $60. $8 in a Blockbuster in TX, the rest in a clothing store in NJ.
Crap you found out? Damn
Built Not Bought #640
8pitcher is offline   Reply With Quote Quick reply to this message
Unread 02-22-2013, 09:56 AM   #632
Jankoid
Originally Posted by tyvanwie View Post
I'll be putting the lift on tomorrow at 9am, will any of you be on stand-by incase I run into an issue?
Also, I'm getting a couple buddies to help with the install. Would it be a problem if we put the jeep on stands, and my dad does the mml while we work on the suspension? Trying to get done in a timely manner.
Sent from my iForum using JeepPhone
You can do them at the same time but you'll be tripping all over each other.
Doing the install in Charlotte? I'm free-ish if you run in to something you absolutely can't handle yourself.
Piece of advice, crawl under there tonight and give the rear upper shock bolts a good dousing of pb blaster. They are going to be seized up tight.
Jankoid is offline   Reply With Quote Quick reply to this message
Unread 02-22-2013, 09:59 AM   #633
tyvanwie
Well our house is in iron station. And I'll the pb blast. We have a pretty huge garage so we have room, I just figure we could get to work on the suspension while my dad does the mml, then do the bl together. Idk lol.
tyvanwie is offline   Reply With Quote Quick reply to this message
Unread 02-23-2013, 09:21 PM   #634
tyvanwie
Okay so today all we got done was the body and motor mount lift. Fan shroud was a pita, body bolts would line up right at first, and lost a nut for like an hour. It was a mm nut and it bounced off the garage floor and somehow landed on the block on the jack while it was up. There was barely enough space for the nut and it somehow landed in there. Anyways, doing the suspension tomorrow.
Here's a pic of the mml, didn't get on of the bl, I forgot lol.
Unread 02-23-2013, 09:40 PM   #635
sjones26573
Your overpriced MML looks good!
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline   Reply With Quote Quick reply to this message
Unread 02-23-2013, 09:43 PM   #636
tyvanwie
Ah, it's worth it to me. Even if it is overpriced.
Unread 02-23-2013, 09:52 PM   #637
sjones26573
One could say it costs M.O.R.E.
Jeep-Owner.com
Unread 02-23-2013, 09:53 PM   #638
tyvanwie
True dat. These things way like twice as much as the stock ones.
Unread 02-23-2013, 09:58 PM   #639
Jankoid
Are they heavier than stock too?
Unread 02-23-2013, 10:00 PM   #640
tyvanwie
I really said way... too tired lol. But yes that do WEIGH more
Unread 02-24-2013, 01:54 PM   #641
Jankoid
I totally didn't vote for you!
I'm not going to either
Someone is a liar!
Unread 02-24-2013, 02:01 PM   #642
tyvanwie
Someone is a liar!
I felt left out
Unread 02-24-2013, 02:23 PM   #643
tyvanwie
Guys I NEED your help. My rear track bar will not line up.
Unread 02-24-2013, 02:37 PM   #644
tyvanwie
Never mind we got it
Unread 02-24-2013, 02:39 PM   #645
Jankoid
Gonna need more info than that to help.
nc guys
