Ty's TJ. - Page 165 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Ty's TJ.
Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiRing & Pinion's, Lockers, 4340 Axles, Install Kits, BaSavvy Billet LED Tail Lights
Unread 05-16-2014, 09:30 PM   #2461
ucffootball85
nice build!
ucffootball85 is offline   Reply With Quote Quick reply to this message
Unread 05-24-2014, 10:24 AM   #2462
tyvanwie
I'm going to start doing some basic maintenance on the jeep. First thing is going to be getting a new trans pan. We believe the PO over-torqued one or more of the bolts and misshaped the pan, so when we installed the new filter and gasket, it still didn't fit properly. Hopefully this will fix that annoying little leak I have. Next is a tune up since the jeep just clocked over 100k miles. Then I'm going to check u-joints, ball joints, etc. Then probably changing the rear dif fluid and adding another lube locker.
I'm going on vacation a week from today (yay!) so all of this will be happening afterwards.
I'm also still unsure about whether I want the crown steering or the currie. I know which is best, I just don't know if I want to spend the money or not.
[SIZE="4"][B][COLOR="Red"][URL="http://www.jeepforum.com/forum/f22/tys-tj-1475530/#post14926343"]MY BUILD THREAD[/URL][/COLOR][/B][/SIZE]
[SIZE="4"][B][URL="http://www.jeepforum.com/forum/f374/tyvanwies-log-transformation-1489190/"]MY FITNESS LOG/TRANSFORMATION[/URL][/B][/SIZE]
[SIZE="4"][B][URL="http://www.jeepforum.com/forum/f127/jk-tj-parts-1525039/"]JK AND TJ PARTS FOR SALE[/URL][/B][/SIZE]
I'm pretty sure I know what I'm talking about. I think...
tyvanwie is offline   Reply With Quote Quick reply to this message
Unread 05-24-2014, 07:49 PM   #2463
sjones26573
Offroad NC State
sjones26573's Avatar
Well, I have no complaints with the Crown for the 20 hrs it's been mounted. But it's not permanent so not much of a risk for me.
The Yellowtail Build
Originally Posted by Jeremy Clarkson - Top Gear Botswana Special
Why don't all cars have no doors? When I come to power I'm going to make it a rule because this is just better.
sjones26573 is offline   Reply With Quote Quick reply to this message
Unread 05-25-2014, 01:08 PM   #2464
tyvanwie
Also seems like my AC is going out. Set at this is barely cool and no where near cold.
Unread 05-25-2014, 01:34 PM   #2465
Mulvihill64
Mulvihill64's Avatar
Try recharging it with one of those canisters you can get at autozone
My Build Thread
Instagram: Mulvihill64
Jeep-Owner.com
Mulvihill64 is offline   Reply With Quote Quick reply to this message
Unread 05-25-2014, 11:55 PM   #2466
BamaJeepman21
My AC has never worked. No idea what the issue is. I swear sometimes the air from outside blows colder through the vents than the AC.
Wanted: Savvy/Currie 3" front springs
-Jack
BamaJeepman21 is offline   Reply With Quote Quick reply to this message
Unread 05-26-2014, 12:02 AM   #2467
8pitcher
Take it to a shop to recharge. The one gauge on the ac pro stuff will not get your charge right.y dad charged my sisters xj with gauges he bought for 100
[URL="http://groups.jeepforum.com/built-not-bought/"][COLOR="Black"]Built Not Bought #640[/COLOR][/URL][/FONT][/SIZE][/COLOR][/CENTER][/COLOR]
8pitcher is offline   Reply With Quote Quick reply to this message
Unread 05-26-2014, 08:38 AM   #2468
Cavasar
No Longer DD
Cavasar's Avatar
AC...
Cavasar's TJ
Cavasar is offline   Reply With Quote Quick reply to this message
Unread 05-26-2014, 11:20 AM   #2469
jeepwrangler97
I miss my ac....it hasn't worked in a while. I love having ac when it works...especially in fl
Sent from AutoGuide.com Free App
jeepwrangler97 is offline   Reply With Quote Quick reply to this message
Unread 05-26-2014, 11:32 AM   #2470
Cavasar
No Longer DD
Cavasar's Avatar
My AC works fine, I just don't have the top on enough to use it. When you put the hard top on, it's like a microwave sometimes.
Cavasar's TJ
Unread 05-28-2014, 02:33 PM   #2471
EugeneTheTJ
Tar Heel
EugeneTheTJ's Avatar
If your AC isn't blowing cold a recharge isn't going to fix it for long. There is a reason the coolant isn't there anymore. Need to find and repair the leak or you are just throwing your money away. Trust me on this!
EugeneTheTJ is online now   Reply With Quote Quick reply to this message
Unread 05-28-2014, 02:40 PM   #2472
jeepwrangler97
Yup! What he said.
I've had so many leaks on my a/c system, it would've been cheaper to buy an a/c kit & just do everything. Haha, I've replaced every part except the condenser on mine.....it's now leaking again...
Unread 05-28-2014, 08:30 PM   #2473
tyvanwie
Didn't even think about leaks. Thanks for that, ill look for them whenever I work on the jeep next.
Unread 05-28-2014, 09:03 PM   #2474
xrunndonex
1994 ZJ
I contradict. Mine stopped blowing cold one day they vacuumed it and recharged it. Worked ever since. 2 years
xrunndonex is offline   Reply With Quote Quick reply to this message
Unread 05-28-2014, 09:35 PM   #2475
EugeneTheTJ
Tar Heel
A lot of times the coolant has particles in it that serves to clog the leaks. Guarantee if you asked the shop that did it they would say the same.
nc guys
