Ty's TJ. - Page 137 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Ty's TJ.
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineIron Rock Offroad products - get them from Kolak!TERAFLEX JKU 2.5" Elite LCG Long FlexArm Lift Kit w/
Unread 10-26-2013, 08:09 PM   #2041
BamaJeepman21
Originally Posted by tyvanwie View Post
I will over thanksgiving break. Won't have much time until then.
Hopefully they fix the WRX and we can proceed with that deal. Not having the Jeep as a DD will be so much nicer. Then it can sit it pieces while we fix everything.
I sometimes think of getting a WK as my DD and selling the TJ...don't think I could do that though.
Wanted: Savvy/Currie 3" front springs
-Jack
BamaJeepman21 is offline   Reply With Quote Quick reply to this message
Unread 10-26-2013, 08:20 PM   #2042
tyvanwie
That thought crossed my mind about the WRX. But then I figured the WRX might end up like the TJ... Better to have a spare car lol
[SIZE="4"][B][COLOR="Red"][URL="http://www.jeepforum.com/forum/f22/tys-tj-1475530/#post14926343"]MY BUILD THREAD[/URL][/COLOR][/B][/SIZE]
[SIZE="4"][B][URL="http://www.jeepforum.com/forum/f374/tyvanwies-log-transformation-1489190/"]MY FITNESS LOG/TRANSFORMATION[/URL][/B][/SIZE]
[SIZE="4"][B][URL="http://www.jeepforum.com/forum/f127/jk-tj-parts-1525039/"]JK AND TJ PARTS FOR SALE[/URL][/B][/SIZE]
I'm pretty sure I know what I'm talking about. I think...
tyvanwie is online now   Reply With Quote Quick reply to this message
Unread 10-26-2013, 09:40 PM   #2043
jeepwrangler97
I had weird starting issues when my negative battery cable was corroded inside the cable. It wasn't grounding properly & caused weird starting issues. I could actually get it to start by grounding the battery to the engine block with a jumper cable. Since I replaced the cable, the issue is completely gone
Sent by a messenger bird
jeepwrangler97 is offline   Reply With Quote Quick reply to this message
Unread 10-26-2013, 09:55 PM   #2044
tyvanwie
Yeah I'm going to take care of some of the corrosion on the cables as well whenever I have time. Plus the jeep will get a tune up and thorough inspection.
Unread 10-28-2013, 04:36 PM   #2045
tyvanwie
So I went ahead and decided that, for now, everything suspension and driveline related is going to stay the way it is. At least until the jeep is DD worthy and problem free. It's just going to be easier and cheaper. That being said, I'm going to be replacing all of the bushings in the spare arms that I have and swapping them with the ones on the jeep now. I thought about getting replacement bushing for the trackbar, but then realized a full replacement is only like $60 tops.
I do have a couple questions though.
Should I get MOOG? Rock auto also has AC Delco, mevotech, and raybestos.
Rock auto has a MOOG trackbar that say "incl. powdered-metal gusher bearing to allow grease to penetrate bearing surfaces" is this something I want? It's $20 more than the mevotech trackbar. Moog part number is DS1235
And finally, how likely is it that a trackbar fails while wheeling? Of course I'd like to have a spare, but only if there's a good possibility. Otherwise ill just replace the bushing and save the money.
Unread 10-28-2013, 04:39 PM   #2046
Jankoid
Don't bother replacing the stock track bar unless the bushings are absolutely shot, and if they are, put that $60 towards a MetalCloak track bar. Most Moog stuff is **** by the way.
Jankoid is online now   Reply With Quote Quick reply to this message
Unread 10-28-2013, 04:42 PM   #2047
tyvanwie
Originally Posted by Jankoid
Don't bother replacing the stock track bar unless the bushings are absolutely shot, and if they are, put that $60 towards a MetalCloak track bar. Most Moog stuff is ***** by the way.
How is raybestos? Never heard of them before.
Unread 10-28-2013, 04:51 PM   #2048
Jankoid
No clue, but seriously, do not buy a stock replacement track bar. I'll give you one if you need it that badly.
Unread 10-28-2013, 04:55 PM   #2049
tyvanwie
Will do. I don't know if mine is even bad, I just figured I'd look and ask questions. It looks like for all 14 control arm bushings, a trackbar bushing, and shipping, the total is $135.95. Not bad if that company is any good. Most of them were "one of our most popular parts."
Unread 10-28-2013, 04:57 PM   #2050
sjones26573
Raybestos does brakes. Not sure how i'd feel about suspension components from a brake company.
And I agree with Jake save for a 'Cloak for when you need it. I'll be investing in a 'Cloak TB as I get my **** i have now to work, before I can even think about 4 linking and all that ****
[URL="http://www.jeepforum.com/forum/f22/yellowtail-build-1262933/"][COLOR="Yellow"]The Yellowtail Build[/COLOR][/URL]
[QUOTE=Jeremy Clarkson - Top Gear Botswana Special]Why don't all cars have no doors? When I come to power I'm going to make it a rule because this is just better.[/QUOTE]
sjones26573 is online now   Reply With Quote Quick reply to this message
Unread 10-28-2013, 05:13 PM   #2051
Imped
Imped's Avatar
Those aren't OE-quality replacements. They'll be cheaper knock-offs with faux 'Clevite' bushings. I know parts pretty damn well and even the 'high end' Moog stuff isn't up to OE quality. Spending the money on one makes no sense when there are people that have good-condition stockers sitting on the shelf taking up space that they'd let go for next to nothing. I've given away and thrown away stock control arms, track bars, sway bars, etc.
Either upgrade or have some nice people send you some stock stuff. If you're gonna upgrade, the MC bar is an excellent choice.
OlllllllO
Float Test Build
IndyORV
Imped is offline   Reply With Quote Quick reply to this message
Unread 10-28-2013, 05:19 PM   #2052
tyvanwie
Is there nowhere that sells OE-quality replacements? Ill start look on here and CL for some takeoffs.
Unread 10-29-2013, 06:04 PM   #2053
tyvanwie
Are crown bushings any better?
Unread 10-29-2013, 06:11 PM   #2054
sjones26573
I have a good guess but I've never used crown bushings before.
Unread 10-29-2013, 07:38 PM   #2055
tyvanwie
I guess a plus to using them is they come with a 12 month, 12,000 mile warranty.
nc guys
