Ty's TJ. - Page 116 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Ty's TJ.
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 08-16-2013, 02:40 PM   #1726
Jankoid
Originally Posted by tyvanwie View Post
I used Seth's the first time I went wheeling. It's sweet. Should be here next week.
And Seth used mine the first 10 times he went wheeling.
Jankoid is offline   Reply With Quote Quick reply to this message
Unread 08-16-2013, 02:48 PM   #1727
tyvanwie
I feel bad using other people's stuff.
tyvanwie is offline   Reply With Quote Quick reply to this message
Unread 08-16-2013, 03:14 PM   #1728
JCJeep97
It's OK if it's Jake's stuff
My Build: http://www.jeepforum.com/forum/f22/back-black-2000-tj-build-1237980/
JCJeep97 is offline   Reply With Quote Quick reply to this message
Unread 08-16-2013, 03:27 PM   #1729
Jankoid
Seriously though, that tire deflater spends more time deflating other people's tires than my own.
Unread 08-16-2013, 04:33 PM   #1730
tyvanwie
at least you don't need to worry about me using it.
Unread 08-17-2013, 03:42 PM   #1731
tyvanwie
Just got under the jeep and found some lateral movement in the TRE on the knuckle. This is probably the culprit.
Unread 08-17-2013, 03:56 PM   #1732
tyvanwie
Advanced auto parts has one (I know) so I'm going to get it.
Unread 08-17-2013, 04:31 PM   #1733
JCJeep97
Don't buy the cheap **** brand. Not worth their weight in zombie flesh.
Unread 08-17-2013, 04:33 PM   #1734
tyvanwie
Bought a Moog...
Unread 08-17-2013, 05:12 PM   #1735
tyvanwie
The front and rear LCA's are the same right?
Unread 08-17-2013, 05:19 PM   #1736
tyvanwie
So I'm in the middle of the TRE install and I can get the castle nut past the hole for the cotter pin easily. Should I stop, or continue until its tight?
Unread 08-17-2013, 05:24 PM   #1737
Kodiak17
Torque it to spec... If its not lined up then see if you can tighten or loosen it an itty-bitty bit so they line up. At least thats what I do.
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline   Reply With Quote Quick reply to this message
Unread 08-17-2013, 05:42 PM   #1738
tyvanwie
What is it on the zj?
Unread 08-18-2013, 09:36 AM   #1739
Imped
Imped's Avatar
Correct, minus the whole loosen thing. You should never loosen a castle nut on a tapered fitting to line up the hole, otherwise you completely lose the advantage of a tapered fitting.
OlllllllO
Float Test Build
IndyORV
Imped is offline   Reply With Quote Quick reply to this message
Unread 08-18-2013, 09:38 AM   #1740
tyvanwie
I got it torqued last night. The wobble is still there, but is definitely better. Heading back to school today, so it'll be a couple weeks before I can do anything else.
nc guys
