Ty's TJ. - Page 115 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Ty's TJ.
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineForever Wave Flags at JeepHutRubicon Express lift kits w/shocks are on sale!
Unread 08-14-2013, 09:25 AM   #1711
tyvanwie
Originally Posted by Kodiak17
People are finding Moog isn't what it used to be. Any Spicer brand stuff near you?
Im not sure. I haven't seen anything yet. I've just started looking and pricing.
I still need to do a dry steer test and see what's actually wrong. But when we installed the locker the only steering we touched was the tie rod and then this started.
tyvanwie is offline   Reply With Quote Quick reply to this message
Unread 08-14-2013, 11:27 AM   #1712
Kodiak17
I went with XRF brand. A lot of truck guys beat on them and are happy. Mine have held up so far.
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline   Reply With Quote Quick reply to this message
Unread 08-14-2013, 12:04 PM   #1713
tyvanwie
Where'd you get them?
Unread 08-14-2013, 12:31 PM   #1714
Imped
Imped's Avatar
Go Spicer. There are some good vendors on eBay. You can get both sides for $100.
OlllllllO
Float Test Build
IndyORV
Imped is offline   Reply With Quote Quick reply to this message
Unread 08-14-2013, 02:07 PM   #1715
Kodiak17
www.thetireclub.com, I'd go with Spicer for the peace of mind.
Unread 08-14-2013, 02:08 PM   #1716
tyvanwie
Got another question about my brakes. It seems like I'm gathering more dust on my rims? Could bad rotors be causing this? The pads seemed fine.
Unread 08-15-2013, 06:49 AM   #1717
tyvanwie
Gonna be diagnosing my steering this weekend. Do you guys see any reason why I would need my tires on do it? The reason I ask is because I could get them road force balanced while we're looking at the steering.
Unread 08-15-2013, 07:06 AM   #1718
Jankoid
Tires need to be on the Jeep and sitting on its own weight.
Jankoid is offline   Reply With Quote Quick reply to this message
Unread 08-15-2013, 07:08 AM   #1719
Imped
Imped's Avatar
Tires on, motor off. You need something to provide enough resistance (friction of the tires against the ground) to expose any play in the linkage connections.
OlllllllO
Float Test Build
IndyORV
Unread 08-15-2013, 07:19 AM   #1720
tyvanwie
Okay, that does make sense now that I think about it.
Another question. When I got my wheels and tires they were at 38psi. And I'm guessing they were balanced at that psi. Would running them at 28psi need them to be rebalanced? Basically does the psi effect the balance?
Unread 08-15-2013, 07:20 AM   #1721
Imped
Imped's Avatar
On a very small scale, yes it matters. Will it ever be noticeable? Probably not. Lower them down. Next time, tell them to set them to a certain pressure.
OlllllllO
Float Test Build
IndyORV
Unread 08-15-2013, 07:27 AM   #1722
tyvanwie
Okay. I have them at 28 now. I'll just tell them not to change it whenever I get them rebalanced.
Unread 08-16-2013, 02:07 PM   #1723
tyvanwie
Just remembered and ordered something else I wanted. Currie tire deflator.
Unread 08-16-2013, 02:24 PM   #1724
Imped
Imped's Avatar
I don't leave home without mine.
OlllllllO
Float Test Build
IndyORV
Unread 08-16-2013, 02:29 PM   #1725
tyvanwie
I used Seth's the first time I went wheeling. It's sweet. Should be here next week.
nc guys
