Ty's TJ. - Page 110 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Ty's TJ.
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 08-02-2013, 01:08 PM   #1636
JCJeep97
Well, do you want the tire hanging off the *** end or not? Go from there.
Me, no thanks. Unsightly, ungainly, heavy. I prefer the opposite.
This.
After running with the spare inside, I think the spare on the gate looks like butt.
Speaking of that, anybody got a CJ gate they want to sell?
My Build: http://www.jeepforum.com/forum/f22/back-black-2000-tj-build-1237980/
JCJeep97 is offline   Reply With Quote Quick reply to this message
Unread 08-02-2013, 01:11 PM   #1637
tyvanwie
That's probably what I'll end up doing. Why make it complicated..?
I may still get a genright or Rokmen crossmember though.
tyvanwie is offline   Reply With Quote Quick reply to this message
Unread 08-02-2013, 01:28 PM   #1638
Jankoid
Barnes 4wd.
Jankoid is offline   Reply With Quote Quick reply to this message
Unread 08-02-2013, 01:35 PM   #1639
tyvanwie
Originally Posted by Jankoid
Barnes 4wd.
Half the price? Why have I not seen this
Unread 08-02-2013, 01:37 PM   #1640
JCJeep97
Barnes 4wd.
That's a really good deal.
Unread 08-02-2013, 01:43 PM   #1641
Jankoid
He just released it.
Unread 08-02-2013, 01:46 PM   #1642
tyvanwie
Ah. Ill probably be picking that up as well thanks for the find.
Unread 08-02-2013, 02:08 PM   #1643
Imped
Imped's Avatar
It doesn't look like it registers with the rear body mounts and you'll need gussetted frame tie-in plates if you intend to use those recovery mounts. Otherwise, looks good.
OlllllllO
Float Test Build
IndyORV
Imped is offline   Reply With Quote Quick reply to this message
Unread 08-02-2013, 02:41 PM   #1644
sjones26573
Originally Posted by EugeneTheTJ View Post
as far as the stinger styles I like the look of this the best:
dat asssss
So do I. Too bad it's JK only. If I was getting another one, I'd probably get the Genright body mount one that looks like that. But I'm ditching it.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline   Reply With Quote Quick reply to this message
Unread 08-02-2013, 04:32 PM   #1645
Kodiak17
Exogate from GR8TOPS.
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline   Reply With Quote Quick reply to this message
Unread 08-03-2013, 01:34 PM   #1646
tyvanwie
LubeLocker shipped yesterday so it should be here sometime this week. Just in time to install the locker next weekend, and URE the following weekend to test it out
Also, I figure out an INGENIOUS solution to my tire carrier problem. Now try to keep up, it's about to get very technical.
I take the tire, and put it in the back. brilliant right?
Unread 08-03-2013, 04:10 PM   #1647
jeepwrangler97
It will make the jeep smell like tire when the top is on...but that's what I do sometimes
Edit: also..
LubeLocker is great. ..worth it to me; much less messy, & I've not had leaks with mine
Sent by a messenger bird
jeepwrangler97 is offline   Reply With Quote Quick reply to this message
Unread 08-03-2013, 04:15 PM   #1648
tyvanwie
I'd only be putting the spare in when I go wheeling and I won't have the top on then.
Unread 08-03-2013, 04:24 PM   #1649
jeepwrangler97
Even for awhile its not so bad. ..just on hot days it can make the jeep smell a bit
Unread 08-03-2013, 04:32 PM   #1650
JCJeep97
You're gonna love the locker!!!
nc guys
