Ty's TJ. - Page 104 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Ty's TJ.
WIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,
Unread 07-22-2013, 02:26 PM   #1546
Imped
Imped's Avatar
OK, I guess I'm just talking out of my *** then.
OlllllllO
Float Test Build
IndyORV
Imped is offline   Reply With Quote Quick reply to this message
Unread 07-22-2013, 02:59 PM   #1547
marcus01tj
I guess so..
#notoffroadsc
marcus01tj is offline   Reply With Quote Quick reply to this message
Unread 07-22-2013, 03:08 PM   #1548
Imped
Imped's Avatar
Originally Posted by marcus01tj View Post
I guess so..
I'm not.
I spent a lot of time un-denting my body mount channel and lower edge of the tub to prove it. The devil is in the details and at a certain point, they will make a difference.
OlllllllO
Float Test Build
IndyORV
Unread 07-22-2013, 03:22 PM   #1549
marcus01tj
I'm not.
Mind explaining?
#notoffroadsc
Unread 07-22-2013, 08:56 PM   #1550
wfochris
Mind explaining?
I'll second the request as I'm about to install some myself.
Build thread:
http://www.jeepforum.com/forum/f22/3rd-times-charm-02-4-cyl-tj-1548852/
wfochris is offline   Reply With Quote Quick reply to this message
Unread 07-22-2013, 10:23 PM   #1551
Kodiak17
Blaine has explained why preloading your sliders is important... theres a thread on slider design.
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline   Reply With Quote Quick reply to this message
Unread 07-22-2013, 10:32 PM   #1552
tyvanwie
Do you have a link? I tried searching for it.
tyvanwie is offline   Reply With Quote Quick reply to this message
Unread 07-22-2013, 10:41 PM   #1553
Kodiak17
I think its actually a picture request thread about sliders on JF.
Unread 07-23-2013, 05:56 AM   #1554
JCJeep97
Mind explaining?
I'm curious too, if you have time.
I've gathered you know a little about suspension design
My Build: http://www.jeepforum.com/forum/f22/back-black-2000-tj-build-1237980/
JCJeep97 is offline   Reply With Quote Quick reply to this message
Unread 07-23-2013, 07:22 AM   #1555
Imped
Imped's Avatar
Sorry for the delay. You preload the sliders so that when they are exposed to the high dynamic forces of dropping off a ledge onto a rock (or similar), the fasteners don't distort. When fasteners distort, the plate moves and the tub goes with it.
Still one of the best slider design/theory threads ever: http://www.jeepforum.com/forum/f9/in...s-pics-134553/
You can see the early days of Blaine's design coming to fruition.
OlllllllO
Float Test Build
IndyORV
Unread 07-23-2013, 07:43 AM   #1556
Kodiak17
Yup thats it. You'll also read why mounting from the bottom is important especially when you have a tube/step on the outside for leverage.
Unread 07-23-2013, 08:58 AM   #1557
tyvanwie
Thanks for the link man. Ill read through that today.
Unread 07-23-2013, 09:31 AM   #1558
tyvanwie
Okay I think I understand it now. You're basically just making it so the sliders are as close to being part of the tub as possible, right? You don't want any gaps or space.
Unread 07-23-2013, 10:04 AM   #1559
tyvanwie
So apparently my tires only measure out to ~31.5".
Unread 07-23-2013, 10:13 AM   #1560
Imped
Imped's Avatar
Well, that....but you're actively forcing the two together to create a single assembly. You can install sliders to have no gap very easily without preloading at all.
Here's the best indicator for preload vs. none. If you unbolt the sliders then try to bolt them up by hand with no other force acting on them, the bolt hole in the slider and the hole in the tub will not fully line up. That also goes for nutserts. A greater force than what you can apply by hand needs to be exerted on the assembly to allow installation. In order to get that, you have to drill all holes when the slider is vertically and laterally preloaded.
OlllllllO
Float Test Build
IndyORV
nc guys
