Ty's TJ. - Page 102 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Ty's TJ.
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 07-21-2013, 04:41 PM   #1516
tyvanwie
Originally Posted by sjones26573
What? The Fall Jamboree?
August 16-18
tyvanwie is offline   Reply With Quote Quick reply to this message
Unread 07-21-2013, 04:46 PM   #1517
sjones26573
Originally Posted by tyvanwie View Post
August 16-18
Pretty sure I move in that weekend
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline   Reply With Quote Quick reply to this message
Unread 07-21-2013, 04:47 PM   #1518
tyvanwie
:thumbsdown:
Unread 07-21-2013, 05:32 PM   #1519
tyvanwie
Been puttsing on the jeep a bit. Took off my rear bumper. Not sure I like it though. Plus I have that wire from the hitch hanging down.
Unread 07-21-2013, 05:42 PM   #1520
Jankoid
You need a rear tow point. If you are staying bumperless I can show you a $10 solution.
Jankoid is offline   Reply With Quote Quick reply to this message
Unread 07-21-2013, 05:44 PM   #1521
tyvanwie
What is it?
Unread 07-21-2013, 06:00 PM   #1522
Jankoid
What is it?
Pick up a tow hook from your local advance auto or autozone, they are usually somewhere around $10. Bolt it to the side of the frame in the rear. You can do one or both sides. I've only done the passenger side on mine but plan to do the driver side too. If you had a factory hitch one of the bolts should already be there, then you just need to drill and tap the other. Simple to do and works great. I've used mine many times to pull people out of sticky situations.
Unread 07-21-2013, 06:03 PM   #1523
tyvanwie
Cool. Sounds like an easy plan.
I also took off my doors, but then realized my dome light stays on. Can I just remove that bulb and be fine? Or will there still be power to it?
Unread 07-21-2013, 06:05 PM   #1524
sjones26573
Pull the fuse
Jeep-Owner.com
Unread 07-21-2013, 06:07 PM   #1525
tyvanwie
Which one is it?
Unread 07-21-2013, 06:08 PM   #1526
sjones26573
Which one is it?
Look at your diagram.
Jeep-Owner.com
Unread 07-21-2013, 06:14 PM   #1527
wfochris
Nice, your first post in this thread looks very similar to my plans.
Keep up the progress!
Build thread:
http://www.jeepforum.com/forum/f22/3rd-times-charm-02-4-cyl-tj-1548852/
wfochris is offline   Reply With Quote Quick reply to this message
Unread 07-21-2013, 06:22 PM   #1528
tyvanwie
Got it.
Unread 07-21-2013, 06:23 PM   #1529
tyvanwie
The plan has changed a little bit since then (I obviously don't have soft 8's) But thanks!
Unread 07-22-2013, 10:04 AM   #1530
tyvanwie
Okay so, as I was looking at the sliders again, the Rokmen's actually come out cheaper than the A to Z. Plus I don't see where I enter the discount for A to Z?
nc guys
