Ty's TJ. - Page 96 - JeepForum.com
post #1426 of 2548 Old 07-14-2013, 09:04 PM
Kodiak17
The Rokmen's wrap under more than the Crown's.
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline
post #1427 of 2548 Old 07-14-2013, 09:18 PM
EugeneTheTJ
Tar Heel
EugeneTheTJ's Avatar
A to z
2016 TJ of the Year
Founder,
EugeneTheTJ is offline
post #1428 of 2548 Old 07-15-2013, 06:16 AM
Imped
Imped's Avatar
You don't want any that mount to the body mounts......the ones you want go around the body mounts and fasten securely to the bottom and side of the tub.
OlllllllO
IndyORV
Imped is offline
post #1429 of 2548 Old 07-15-2013, 06:20 AM
EugeneTheTJ
Tar Heel
exactly why I don't have PSC
2016 TJ of the Year
Founder,
post #1430 of 2548 Old 07-15-2013, 07:03 AM
Jankoid
So what? It doesn't make any difference...
Jankoid is offline
post #1431 of 2548 Old 07-15-2013, 07:13 AM Thread Starter
tyvanwie
Why? Is it because a hit could rip out the body mounts?
tyvanwie is offline
post #1432 of 2548 Old 07-15-2013, 07:21 AM
AngryTJ
Rokmen are built very strong I love mine
AngryTJ is offline
post #1433 of 2548 Old 07-15-2013, 07:45 AM
Imped
Imped's Avatar
That, and why would you want body armor mounted between the body mount bushing and the tub? That's the cheap, easy way to secure the slider to the bottom of the tub and it's not very friendly on the either the tub or mounts. I went that route early on as well and I can tell you that it's a PITA and not the right way to do it. Get something worth buying, don't take the cheap way out.
Properly fastening a slider to the tub involves preload. You don't get that with body mounted sliders.
OlllllllO
IndyORV
Imped is offline
post #1434 of 2548 Old 07-15-2013, 07:48 AM
Jankoid
I'd say its more because they are a pain in the *** to install.
Jankoid is offline
post #1435 of 2548 Old 07-15-2013, 08:27 AM
Kodiak17
Maybe to you it doesn't.
Kodiak17 is offline
post #1436 of 2548 Old 07-15-2013, 08:36 AM Thread Starter
tyvanwie
Okay looked at a few of the mmore closely.
Metalcloak attaches directly to the rocker panel. Didn't see anything about underneath mounting though, I could have missed it.
Rokmen has side and underneath mounting with cutouts for the body mounts.
And I can't really tell on the crown ones.
tyvanwie is offline
post #1437 of 2548 Old 07-15-2013, 08:57 AM
Jankoid
Maybe instead of making vague derogatory comments you should explain your reasoning.
Regardless of if the rock slider wraps under only 2 inches or runs all the way to the frame rail, I've never seen a rock that was shaped just perfectly so that it would hit the tub under there before hitting the slider or frame first. Even if you did somehow manage to hit the tub, its not gonna hurt anything. It is double walled there and isn't visible.
Jankoid is offline
post #1438 of 2548 Old 07-15-2013, 09:02 AM
mcannon111
Yeah you're gonna be dragging your body mounts long before you hit the tub at that point. Mine wrap up pretty far, but i can take a picture and show you that the majority of the dings and dents are down the side of the rocker, not way up underneath where you're thinking it matters.
no doors, no top, no problems
live in sc? join OffroadSC.com
mcannon111 is offline
post #1439 of 2548 Old 07-15-2013, 09:03 AM Thread Starter
tyvanwie
Do you have the moabfab ones?
tyvanwie is offline
post #1440 of 2548 Old 07-15-2013, 09:06 AM
Jankoid
They dont mount underneath at all, only to the side.
Jankoid is offline
nc guys
