Ty's TJ. - Page 165 - JeepForum.com
post #2461 of 2548 Old 05-16-2014, 08:30 PM
ucffootball85
nice build!
ucffootball85 is offline
post #2462 of 2548 Old 05-24-2014, 09:24 AM Thread Starter
tyvanwie
I'm going to start doing some basic maintenance on the jeep. First thing is going to be getting a new trans pan. We believe the PO over-torqued one or more of the bolts and misshaped the pan, so when we installed the new filter and gasket, it still didn't fit properly. Hopefully this will fix that annoying little leak I have. Next is a tune up since the jeep just clocked over 100k miles. Then I'm going to check u-joints, ball joints, etc. Then probably changing the rear dif fluid and adding another lube locker.
I'm going on vacation a week from today (yay!) so all of this will be happening afterwards.
I'm also still unsure about whether I want the crown steering or the currie. I know which is best, I just don't know if I want to spend the money or not.
tyvanwie is offline
post #2463 of 2548 Old 05-24-2014, 06:49 PM
sjones26573
Well, I have no complaints with the Crown for the 20 hrs it's been mounted. But it's not permanent so not much of a risk for me.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #2464 of 2548 Old 05-25-2014, 12:08 PM Thread Starter
tyvanwie
Also seems like my AC is going out. Set at this is barely cool and no where near cold.
tyvanwie is offline
post #2465 of 2548 Old 05-25-2014, 12:34 PM
Mulvihill64
Try recharging it with one of those canisters you can get at autozone
Instagram: Mulvihill64
Mulvihill64 is offline
post #2466 of 2548 Old 05-25-2014, 10:55 PM
BamaJeepman21
My AC has never worked. No idea what the issue is. I swear sometimes the air from outside blows colder through the vents than the AC.
-Jack
BamaJeepman21 is offline
post #2467 of 2548 Old 05-25-2014, 11:02 PM
8pitcher
8pitcher's Avatar
Take it to a shop to recharge. The one gauge on the ac pro stuff will not get your charge right.y dad charged my sisters xj with gauges he bought for 100
8pitcher is offline
post #2468 of 2548 Old 05-26-2014, 07:38 AM
TexasTJ
No Longer DD
TexasTJ's Avatar
AC...
May TJ of the Month 2015
TexasTJ is offline
post #2469 of 2548 Old 05-26-2014, 10:20 AM
jeepwrangler97
I miss my ac....it hasn't worked in a while. I love having ac when it works...especially in fl
Sent from AutoGuide.com Free App
jeepwrangler97 is offline
post #2470 of 2548 Old 05-26-2014, 10:32 AM
TexasTJ
No Longer DD
TexasTJ's Avatar
My AC works fine, I just don't have the top on enough to use it. When you put the hard top on, it's like a microwave sometimes.
TexasTJ is offline
post #2471 of 2548 Old 05-28-2014, 01:33 PM
EugeneTheTJ
Tar Heel
EugeneTheTJ's Avatar
If your AC isn't blowing cold a recharge isn't going to fix it for long. There is a reason the coolant isn't there anymore. Need to find and repair the leak or you are just throwing your money away. Trust me on this!
2016 TJ of the Year
Founder,
EugeneTheTJ is offline
post #2472 of 2548 Old 05-28-2014, 01:40 PM
jeepwrangler97
Yup! What he said.
I've had so many leaks on my a/c system, it would've been cheaper to buy an a/c kit & just do everything. Haha, I've replaced every part except the condenser on mine.....it's now leaking again...
post #2473 of 2548 Old 05-28-2014, 07:30 PM Thread Starter
tyvanwie
Didn't even think about leaks. Thanks for that, ill look for them whenever I work on the jeep next.
tyvanwie is offline
post #2474 of 2548 Old 05-28-2014, 08:03 PM
xrunndonex
1994 ZJ
I contradict. Mine stopped blowing cold one day they vacuumed it and recharged it. Worked ever since. 2 years
xrunndonex is offline
post #2475 of 2548 Old 05-28-2014, 08:35 PM
EugeneTheTJ
Tar Heel
A lot of times the coolant has particles in it that serves to clog the leaks. Guarantee if you asked the shop that did it they would say the same.
2016 TJ of the Year
Founder,
nc guys
