Ty's TJ. - Page 116 - JeepForum.com
post #1726 of 2548 Old 08-16-2013, 02:40 PM
Jankoid
Originally Posted by tyvanwie View Post
I used Seth's the first time I went wheeling. It's sweet. Should be here next week.
And Seth used mine the first 10 times he went wheeling.
Jankoid is offline
post #1727 of 2548 Old 08-16-2013, 02:48 PM Thread Starter
tyvanwie
I feel bad using other people's stuff.
tyvanwie is offline
post #1728 of 2548 Old 08-16-2013, 03:14 PM
JCJeep97
It's OK if it's Jake's stuff
My Build: http://www.jeepforum.com/forum/f22/back-black-2000-tj-build-1237980/
JCJeep97 is offline
post #1729 of 2548 Old 08-16-2013, 03:27 PM
Jankoid
Seriously though, that tire deflater spends more time deflating other people's tires than my own.
Jankoid is offline
post #1730 of 2548 Old 08-16-2013, 04:33 PM Thread Starter
tyvanwie
at least you don't need to worry about me using it.
tyvanwie is offline
post #1731 of 2548 Old 08-17-2013, 03:42 PM Thread Starter
tyvanwie
Just got under the jeep and found some lateral movement in the TRE on the knuckle. This is probably the culprit.
tyvanwie is offline
post #1732 of 2548 Old 08-17-2013, 03:56 PM Thread Starter
tyvanwie
Advanced auto parts has one (I know) so I'm going to get it.
tyvanwie is offline
post #1733 of 2548 Old 08-17-2013, 04:31 PM
JCJeep97
Don't buy the cheap **** brand. Not worth their weight in zombie flesh.
JCJeep97 is offline
post #1734 of 2548 Old 08-17-2013, 04:33 PM Thread Starter
tyvanwie
Bought a Moog...
tyvanwie is offline
post #1735 of 2548 Old 08-17-2013, 05:12 PM Thread Starter
tyvanwie
The front and rear LCA's are the same right?
tyvanwie is offline
post #1736 of 2548 Old 08-17-2013, 05:19 PM Thread Starter
tyvanwie
So I'm in the middle of the TRE install and I can get the castle nut past the hole for the cotter pin easily. Should I stop, or continue until its tight?
tyvanwie is offline
post #1737 of 2548 Old 08-17-2013, 05:24 PM
Kodiak17
Torque it to spec... If its not lined up then see if you can tighten or loosen it an itty-bitty bit so they line up. At least thats what I do.
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline
post #1738 of 2548 Old 08-17-2013, 05:42 PM Thread Starter
tyvanwie
What is it on the zj?
tyvanwie is offline
post #1739 of 2548 Old 08-18-2013, 09:36 AM
Imped
Imped's Avatar
Correct, minus the whole loosen thing. You should never loosen a castle nut on a tapered fitting to line up the hole, otherwise you completely lose the advantage of a tapered fitting.
OlllllllO
IndyORV
Imped is offline
post #1740 of 2548 Old 08-18-2013, 09:38 AM Thread Starter
tyvanwie
I got it torqued last night. The wobble is still there, but is definitely better. Heading back to school today, so it'll be a couple weeks before I can do anything else.
tyvanwie is offline
nc guys
